Introduction: Plywood Smartphone(iPhone6) TV + Back LED Light
Since people asked me to make an english version of 'https://www.instructables.com/id/DUTCH-Wooden-Smart... I hereby upload a more detailed and English version of my project.
The idea behind this project is to combine "the old fashion way of watching tv" with new technology(iPhone). I made this project during a class named "making" this project is an initiative of Hogeschool Rotterdam in The Netherlands. The requirements for this project were to make an object that contains a hinge, a switch and we had to use three machines while producing our object. I used a lasercutter, a 3D printer and a soldering iron. Which in my case has resulted into a plywood smartphone TV, a led light will switch on when the iPhone is playing your favorite movie. My Instructable step by step explains how you can make your own smartphone TV!
What do I need to make my own plywood TV?
Software
Adobe illustrator
Materials
Plywood 600x300 mm (3mm)
LED light
Pressure-operated switch
Resistor
Battery dock
Wiring
Two small hinges
Small set of files
Wood glue
Rope
Equipment
Lasercutter
3D printer
Soldering iron
Apple iPhone 6
Websites I used(optional):
www.iprototype.nl/ for electronics
www.thingiverse.com / for pre made 3D designs
Step 1: Lasercut the File in the Attachment
Lasercut the plywood, I used a Trotec Speedy 300 in Stadslab Rotterdam.
https://www.fablabs.io/stadslabrotterdam (Stadslab Rotterdam website for location & available machines. You can check the website for your nearest Fablab)
Plywood 600x300 (3mm). Available at Fablab.
Instruction video stadslab Rotterdam (only available in Dutch).
Step 2: The Electronics
Solder the wires and resistor with the LED light and connect the two wires to the pressure-operated switch. The resistor is needed to prevent the light from breaking.
(Check picture in attachment, website for electronics www.iprototype.nl)
Step 3: Connect the Rest of the Electronics
Tip: First check if the electronics work on a breadboard before you start soldering.
Step 4: Are All the Components Available Before Assembling the Plywood TV?
Step 5: Connect LED-light on the Back of the TV.
File the hole at the back of the TV as big as needed and push the LED light through the hole.
Step 6: Assemble the Pressure-operated Switch.
I used some left over plywood to glue the pressure-operated switch onto the TV. Be creative and make your own construction!
Step 7: Assemble the Rest of the Plywood TV
You can use some wood glue for extra stability.
Step 8: The Hinges
Glue the two hinges on the corner of the TV so you can open the top.
I bought the hinges at the D.I.Y.shop and I used strong glue to connect the hinges to the TV.
Step 9: The Result! Let Me Know What You Think About My Project in a Comment Below.
(optional) 3D print your personal brand
To give your tv a personal touch you can 3D print your personal brand. I used an "UP" 3D printer.
Plywood Contest
Full Spectrum Laser Contest 2016
