3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pneumatic Air Tank for Legos
This is an Instructable for an air tank that can be used with lego pneumatic elements for powering robots without continuous pumping. This goes along with my pneumatic snake, and my bike pump adapter instructables.
Step 1Materials
Materials
You will only need a few things.
  • A plastic bottle that can hold pressure. I used a carbonated water bottle. Anything should work as long as the top seals.
  • A tube that your pneumatic hoses will fit over. I used some hard plastic ones that come in some lego sets.
  • Glue-preferably something thick. I used hot glue.
  • Something to make holes in the bottle cap about the size of the tubing. I used a drill but any sharp pointy object will work.
10 comments
Aug 9, 2011. 12:23 PMALogan97 says:
Lego also sells these if you don't want to make one.
Sep 12, 2010. 3:42 PMthe gizmoman says:
If you are willing to spend a little, "robart retracts" has alluminum air tanks and airline (for pneumatic retractible landing gear for rc airplanes ) the tanks are about 10$ for the small and 15-16$ for the large tank and about 7$ for 2 10 ft pneumatic tubing
Jan 14, 2009. 5:26 PMCapt. Fat says:
Hi I liked your instructables that involved pneumatics. I am wondering if you could make them into knex versions with hospital syringes and tubing? If you are I will give all your instructables five star ratings.
Oct 23, 2008. 5:53 PMRadioactive_Legos says:
I was wondering... Could you use a pneumatic "T" connector so you only have to use one hole?
Jul 15, 2008. 1:53 PMookid says:
What are the two smaller tanks made from? I understand that you glued Legos on the bottom but what are the actual tanks made out of?
Oct 13, 2008. 7:42 PMmasterchrisx3 says:
BUBBLE BOTTLES 1337
Jul 20, 2008. 3:17 AMrustlabs says:
LEGO, never LEGOS. it drives me nuts.
but cool pressure tank anyway.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:benthekahn
Hi, I'm Ben. I like mechanical engineering, and using free stuff/"junk".
