So i had a fairly large air cylinder, a solenoid valve, a bit of boredom and an air compressor. The result? A metal-crushing, comically large pneumatic claw :D  Who wouldn't want one?
The claw took me about a day to build, and cost me nothing to build. However, since it is relatively unlikely that you will have the required pneumatic parts ready, so it will probably cost you a bit more.
Step 1: Materials
You will need the following:
- Pneumatic cylinder- make sure it has a large diameter, something over 2 inches is probably best. stroke length around 4 inches, and     pressure handling of 110psi to be safe. check ebay. mine is a bimba stainless steel 2in diameter, 4 in stroke length.
- Plywood - i used 1/2 inch, 4ply for the gripper parts, and some thicker, 10ply? dense hardwood plywood i had laying around. the thicker stuff is mechanically indestructible. got the thinner stuff for a different project at lowes.
- 4 way poppet valve - i got mine for free, mine is a bosh rexroth type 840. check ebay. they are made specifically to extend and retract pneumatic cylinders.
-pneumatic tubing. size depends on your valve.
-pneumatic fittings: three hose barbs, depending on your tubing size. one coupling, one pneumatic quick connect.
-electrical switch and some wire.
- random (thick (3/8)) nuts, bolts and wood screws.
- 13.74g of common sense
monty324 says: Apr 14, 2013. 2:51 PM
haha, 13.74 g of common sense
biolethal (author) in reply to monty324Apr 15, 2013. 2:22 PM
lol you'd be surprised... most people only have about 7.86 g.
monty324 in reply to biolethalApr 20, 2013. 2:21 PM
i just weighed mine and i have 10.04 g. is it ok for me to build it
rgeelen says: Sep 5, 2011. 11:30 AM
you could use a solonoid for a cheaper alternative
hossweightlifter says: Sep 5, 2011. 11:06 AM
I'm doing something similar to this except I'm doing it with metal for removing trees and stuff
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
