Pneumatic Lift Kit
Published
Introduction: Pneumatic Lift Kit
About: My name is Babak Eshghi and I am currently operating ScienceKitShop.com, a retail and wholesale distributor of science education products, based in Clifton, NJ.
Pneumatics is a branch of technology, which deals with the use of pressurized gas to affect mechanical motion. In this project you will make a mechanical lift using two syringes. One used to create pressurized air and the other used to create a mechanical movement and lifting a load.
This particular set contains 19 pieces of pre-cut woods, two syringes, rubber rings, plastic tubing, eye screws and a plastic clamp. You will need wood or multi-purpose glue to complete your pneumatic lift.
Step 1: Kit Contents
6 - 7” long wood (4 with hole)
6 - 3.5” long wood
4 - 1.5” long wood
2 - Wood dowels
1 - Flat Wood (base for clamp)
2 - Syringe (1 with hole)
1 - Clamp (to hold syringe)
1 - 12” Tube (to connect syringes)
10 - O rings
1 - Metal Hinge with Matching Screws
Step 2: Make the Top Frame (Moving Frame or Lift)
Locate two of the 7” long wood blocks with holes and two of the 3.5” wood blocks. Place the pieces next to each other as shown in this diagram. Make sure that the holes on the 7” wood blocks are lined up and the width of the frame is 3.5". Also make sure that the pieces are connected in a right (90º) angle. Glue the pieces together to make your first frame. Give it enough time for the glue to dry (usually more than one hour).
Step 3: ​Make the Main Frame
The main frame consists of two separate frames connected to each other using 4 of the 1.5" wood blocks. Start by making one frame exactly the same as the top frame. Then make another frame similar to the top frame but without holes. Finally use the 1.5" long wood blocks to connect these two frames to each other. The completed main frame must look like the image on the right.
Step 4: ​Prepare the Mounting Base for the Clamp and Lower Cylinder
Insert a wood dowel in the holes of the main frame and center it. Place the flat wood block under the wood dowel and center it as shown. Apply glue to both sides of the wood dowel touching the flat wood block. Allow the glue to dry before moving the main frame. Once the wood dowel and the flat wood block are glued together, you can lift the base and turn the wood around and mount the clamp on it. Note that the clamp has a self-adhesive bottom. Remove the protective film of the adhesive pad and place the clamp on the wood block. Apply some pressure to secure it. The glue at the bottom of the clamp is not very strong. It's a good idea to wrap the clamp base and flat wood block with cable tie or steel wire for additional strength.
Step 5: ​Connect the Two Syringes
In one of the syringes (with hole on the shaft) push the piston all the way in to empty all the air. In the other syringe (with no hole on the shaft) pull the piston outward until it stops. Use the clear plastic tube to connect the two syringes to each other. Push the plastic tube and syringe firmly into each other to form a strong sealed connection.
Step 6: Attach the Hinge
You may use one large hinge or two smaller hinges to connect the lift (top frame) to the base (main frame). Start by placing the lift frame on the main frame and align all the sides. Place the hinge so that the axle of the hinge is right over the seam between the two frames. Mark the holes for the screws. Then use a pin to punch pilot holes for the screws and then mount the hinge. Installation of the hinge requires attention and precision. If you have one hinge, place it in the center. If you have two hinges, mount them near the sides.
Note that the holes on the lift (top frame) must be close to the hinge while the holes of the base are toward the ground and away from the hinge.
Step 7: Wood Frame
In this image you can see the completed wood frame without the plastic clamp and syringes.
Step 8: ​Mount the Lifting Cylinder
The syringe with a hole on the shaft is used as a lifting cylinder and must be installed inside the main frame. Pass the lifting cylinder through the front small opening until the hole of the shaft is aligned with the hole on the lift. Pass a wood dowel from the holes to connect the shaft to the lift.
Step 9: Secure to Mounting Base
Now secure the lower part of the syringe with the plastic clamp on the mounting base. If you have not already attached the clamp to the mounting base, you can do it now. You may need to practice with the clamp and see how it can hold the syringe snugly before mounting it.
Step 10: Strengthen Connection of Base
At this time you may also use other methods to tighten the contact of the clamp with its base. The image on the right shows how cable ties may be used for this purpose. Some may use strong glues or steel wires for this purpose. The pressure on the clamp is high and it is a good idea to use additional materials to strengthen its connection to the base. This may not be needed if you are not testing your pneumatic lift with heavy loads.
Step 11: ​Test Your Pneumatic Lift
The syringe outside of the main frame is used as a pump to control the air pressure (gas pressure). Move the shaft of the outside syringe in and out to see how your lift works. This will also allow you to see and fix any minor issues that the lift may have. Once it is properly working, put a light object on your lift and see how the lift performs!
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    This is an interesting project. While I can't see this holding too much weight, you could increase the load by using water as the medium for actuation. Using water would also be a great idea because it's easier to detect leaks. Just my two cents. Great instructable. ;)
