Total Cost of progect: $85AUD aprox.
Hell powerfull but a little hard to aim, anyone got any ideas on sights?
3 Simple Ways to
Share What You Make
Other ways to share:
DIY, PVC Air rifle "Repeater"
by
antoman11
Homemade 400 psi airgun
by
nonickname
Rube Goldberg machine
by
BooKooDesigns
Pneumatic Rifle (Air gun)
by
mastiffman
Intermidate air rifle with interchangable stock
by
ostomesto
Powerful PVC-Marble Sniper Riffle
by
ericquins
World's Most Powerful Marshmallow Gun -- How To Make Your Own
by
shoemaker
All Steps Viewing
Now you can shoot downwards. however, its not stable enough to be stored for weeks. after a while, the cellophane open up slowly, but its not much of a problem. still cant find a viable replacement thats as cheap and easy but stable. When you can find, please share the idea. id appreciate good ideas
http://www.instructables.com/id/Repeating-airgun-ball-valve-triggering/step3/additional-modifications/
its a PET bottle neck cut from the bottle. Then I cut a notch on a side. most normal bottles fit nicely around 15mm pipes.
not sure what you would want for the rear sights. note: i prefer sights instead of scopes for less precise-homemade guns. if you get actual scopes the main challenge is to calibrate it and to keep it undisturbed
i think i have an idea. after the sprinkler valve, theres a tee right?(above the trigger handle) what if you can attach two vertical rods on both left and right of the tee. maybe pens? then you can tie horizontal strings above the tee by tying at the 2 rods. attach a few strings for different range. i.e. the lower string aligned with front sights makes the gun almost horizontal. calibrate for 10meters. another higher string aligned with the front sight makes the gun to aim slightly above horizontal. use this for maybe 20meter/30?
then after some calibrations, you can surprise people with the badass accuracy of a sprinkler valve and the variable sights. just make sure you set a standard pressure. more pressure, faster bullet, flatter trajectory. different pressure, different trajectory. good luck bro.
A cheap red dot scope might be good.
if your looking for ammo
i `m de Argentina no me hablan en Inglés muy wel
