3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pneumatic Muscles
Pneumatic Muscles
Pneumatic Muscles, or Air Muscles are simple, cheap and extremely powerful. Applications range from machinery, robotics to wearables. Air muscles have no stickction and have a weight to strength ratio like no other linear actuating mechanism. It's weakness is in speed. The speed at which air muscles contract is controlled by how fast air is pumped into the muscle (cfm). So, in order to achieve high actuation speeds, you need large tubes and air controls to get enough air into the muscle quickly.
The assembly I've outlined below is experimental. Pipe fittings weren't meant to be used for this purpose, so please take caution when pumping pressurized air into these assemblies. The muscles I made were used for my Soft Pneumatic Exoskeleton. Air muscles work and are easy to build.
Specifications
max air pressure: 120 psi
suggested lengths: 6"-30"
weight: n/a
strength: n/a
Materials (prices as of 6/29/2008) (materials listed below can be purchased at mcmaster.com)
High-Temperature Silicone Rubber Tubing Soft, 3/8" ID, 1/2" OD, 1/16" Wall
mcmaster.com # 5236K15 | $1.31 per foot
Heavy Duty Polyester Expandable Mesh Sleeving 1-1/2" ID, 3/4" to 2" Bundle Dia, 3'L, Black
mcmaster.com # 9142K34 | $5.83 each
Standard Brass Compression Tube Fitting Adapter for 1/2" Tube OD X 1/4" NPTF Female Pipe
mcmaster.com # 50915K226 | $3.86 each
Standard Brass Compression Tube Fitting Long Nut for 1/2" Tube OD
mcmaster.com # 50915K106 | $2.36 each
Moisture-Resistant Acetal Push-to-Connect Adapter for 5/32" Tube OD X 1/4" NPTF Male Pipe
mcmaster.com # 51055K8 | $1.45each
Standard Brass Compression Tube Fitting Tube Support for 1/2" Tube OD
mcmaster.com # 50915K246 | $7.37 for a pack of 10
Low-Pressure Brass Threaded Pipe Fitting 3/8" Male X 1/4" Female Pipe Sz, Reducing Bushing
mcmaster.com # 4429K522 | $1.78 each
Brass Yor-Lok Tube Fitting Cap for Tubing, 3/4" Tube OD
mcmaster.com # 5272K146 | $8.70 each
Choose-A-Color Flexible Nylon 11 Tubing .106" ID, 5/32" OD, .025" Wall Thickness, Red
mcmaster.com #5635K62 | $0.21 per foot
For each muscle you want to assemble you need:
(1) Silicon tubing cut to length (ex. 12")
(1) Braided sleeving cut to length -1/2" ( ex. 11.5")
(2) Tube Supports (1 pack comes with 10)
(1) Tube Fitting Cap
(1) Tube Fitting Long Nut
(1) Reducing Brushing
(1) Brass Compression Tube Fitting Adapter
Average price per muscle: ~$30
Note: The Tube Fitting Long Nut replaces the Hex nut that the Compression Tube Fitting Adapter comes with.
Pneumatic power and control parts
Valves (mechanical or solenoid)
Pressurized air source ( air reservoir or air compressor)
For pneumatic controls, vexrobotics has a nice starter kit. http://www.vexrobotics.com/vex-robotics-pneumatic-parts.shtml
Step 1Place silicon tube into braided sleeve
Cut the silicon tube to your desired length.
Cut the braided sleeve to the same length minus 1/2 inch.
Burn the ends of the braided sleeve with a lighter to prevent it from fraying and to give it a lip in the compression sleeve assembly.
Shove the silicon tube into the braided sleeve.
33 comments
Dec 29, 2011. 7:34 PMjehan60188 says:
any more pictures of the air-inlet assembly?
thanks!
Aug 20, 2011. 7:02 AMnidobrito says:
Any alternative to the expensive solenoid valves?
Apr 20, 2010. 9:15 PMbowmaster says:
Do you think a 25 CFM compressor is good enough for a full body suit if I want decent speed?
Apr 21, 2010. 1:18 PMbowmaster says:
I was think around 20-30 muscles and the ability to jog at slow speeds. I guess I'll have to find a better air compressor. ~50CFM.
Feb 3, 2011. 1:08 PMlordl9999 says:
hello i was thinking about the same, kind of a body suit with pneumatic muscles.
did you have any thoughts about how to deliver portable power(e.g. batteries) to the air compressor?
i was thinking about just having a couple of air tanks on the back (kind of like a diver) instead of the compressor, but that might not be enough air if your going for a walk ;) (didn't do any actual calculations yet, so i'm just laying out thaughts/ guessing)
well, did you have any thoughts about that subject?
- and to the guy making this instructable; nice work ;)
Jul 9, 2010. 5:25 PMPooloop says:
and thanks for previous answer.
Jul 9, 2010. 5:22 PMPooloop says:
what kit of vex did you used, and what Microcontroller. grateful peter
Apr 30, 2010. 3:48 PMR3mus says:
I bought all the components, and attempted to fit it together as your instructable shows, but some things dont work. First, the mesh sleeve cant possibly fit into the Long nut with the hose. Either one or the other fits, but not both. Second, the End cap is just too big, and it wont fit snug on the end. If the air comes on, its just gonna pop off the end.
Im going to attempt a mash between this instructable and the other air muscle instructable to get a working device. Now that I know how easy they are to make, I wont spend so much to get one working.
Jul 9, 2010. 3:58 PMPooloop says:
why did you put this : Choose-A-Color Flexible Nylon 11 Tubing .106" ID, 5/32" OD, .025" Wall Thickness, Red and this: High-Temperature Silicone Rubber Tubing Soft, 3/8" ID, 1/2" OD, 1/16" Wall tubes. grateful Peter
Jun 27, 2009. 2:21 AM007 dragonnel says:
I like how you built your air muscles and I intend to build some very much like yours, to help me improve my prosthetic leg. May ask you where did you buy your 3-way valve and 3-way solenoid valve?, what kind of device are you using for pumping air into the muscles?, and finally how much did they cost you?.
Jan 20, 2009. 9:37 AMlongineus says:
Is that electronics board necessary?Can't you just connect the valve to a switch or something like that?
Jan 20, 2009. 9:19 PMlongineus says:
these valves can retain the pressure on both muscles at the same time?Like, keeping both half full?
May 6, 2009. 8:16 PMshyguy567 says:
May I ask where you got that one/which model it is?
Jan 10, 2009. 8:26 AMbenip90 says:
nice application, despite it being a copy of other Instructables I liked the link to your project and more influence should have been on the system used to make both the muscles operate in synchronisation
Dec 9, 2008. 10:14 AMegriff says:
I would enjoy an instructable on how you got the muscles to work in unison, where one contracts and the other expands.
Dec 9, 2008. 8:42 PMegriff says:
thank you, you and Honus have been very helpful.
Jul 30, 2008. 3:59 AMspry981 says:
Any idea how much force the muscles exert? I'm thinking of using this idea on a new robot project, but I want to make sure they muscles will actually be able to move the parts. I would want them to be able to move about 40lbs.
Dec 7, 2008. 2:41 PMegriff says:
they are strong, they can have a lift to weight ratio of 400:1
Jul 15, 2008. 10:09 AMbombmaker2 says:
did you mean very soft silicone tubing
Jul 16, 2008. 8:15 PMbombmaker2 says:
thanks
Jul 2, 2008. 8:06 PMokura says:
This is a copy of another Instructible http://www.instructables.com/id/How-to-make-air-muscles!/?ALLSTEPS
Even that is a copy of various DIY articles on the net. You can Google for it as ' Mckibben air muscle latex silicone '.
You do'nt even have the courtesy to acknowledge the 'copied' original sources!
It is not correct to enter this for any competition.
Jul 1, 2008. 9:22 PMMrShifty says:
Very slick! I built one of those out of almost exactly the same materials a couple years ago (we used latex surgical tubing instead of silicon). Have you tried letting the tube hang loose inside the mesh? That's what we did, though mostly because we didn't have a good way to terminate the ends... If anything else, it's probably safer that using the compression fittings as described...
Jul 2, 2008. 8:25 AMMrShifty says:
The assembly is in storage :( I'll post an image when I can get to it, though. But to answer your question, the end of the tube was folded over and tied with zip-ties.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:cheewee2000
