3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pneumatic Squib For On-Actor Film Blood Effects
This Instructable is derived from available Internet resources on fabricating special-effect blood-shooter devices from hand-pumped garden sprayers. It seeks mainly to minaturise the design.
This particular design grew out of a general dissatisfaction with the restrictions the garden-sprayer style of blood-shooter placed on the staging and choreography of blood effect shots.
The goal was to create a device that could replace the garden-sprayer design in all situations, and add flexibility in staging effect shots.
Step 1Building the Control Hose
The Control Hose carries air between the hand-held remote section of the device and the effect section of the device. It is the simplest element to construct, so we'll build it first.
The control line consists of only two unique components: the hosing and identical fittings at either end. The hosing is 1/8" OD urethane line. The fittings are 90º universal fittings with 10-32 threads
Clippard Parts List:
2x UT0-2
1x 1/16" internal diameter polyurethane hose.
Substitution Option:
2x Beswick Engineering MLS-1008-1-303 instead of the UT0-2
Beswick makes the smaller, square swivels with countersunk screw-heads that work just as well as the hexagonal UT0-2 fitting from Clippard, but they don't sell them individually.
49 comments
1-40 of 49next »
Feb 2, 2012. 5:43 AMMFXPYRO says:
Hi, what's purpose of using a separate quick exhaust valve rather than a switch with an accessible exhaust port? Is it purely for greater flow rate?
Jun 7, 2011. 5:42 AMkanzume says:
Hi Crosius, do you think you're able to write up a new and improved version combining what's been mentioned in the comments (e.g. daisy chain, whisker valve, schrader valve etc) with parts readily available on eBay and/or RS online? I'm in Australia and getting parts from Clippard isn't really possible.
Cheers!
Nov 28, 2009. 11:00 PMScubaSteve says:
Where might i find all of these?
Nov 2, 2009. 6:14 AMRavingMadStudios says:
Well, we're now in tech rehearsals for our little stage production using 8 of these marvelous devices, and I thought I would post a few "lessons learned" type tips that may be helpful for those doing stage work (as opposed to film, which can be more forgiving of "oops" moments).
1. Adding a tee fitting (Clippard # 15002-3) to move the check valve next to the cylinder and substituting a 2-way valve (Clippard # TV-2S) for the three-way valve greatly increases the concealability of the trigger.
2. We have found that using small amounts of poster-tack style removable putty adhesive to seal the hole in the effect tube (rather than the low-tack masking tape), seems to reduce premature blood leakage when the actors have to wear their loaded squib for extended periods before firing it, or when they have to move around a lot onstage before activating the effect. The effect still works perfectly with the poster-tack, as long as you don't use way too much.
3. I highly recommend purchasing extra screw plugs (Clippard # 11755, the same as used to seal the top of the air cylinder) for use as a safety. Actors can be kind of clumsy sometimes, and the last thing you want during a performance is someone accidentally triggering a squib backstage. The screw plug is used to seal the exhaust hole in the toggle valve, and prevents the squib from firing even if the toggle switch is flipped. A stagehand simply removes the plug with a screwdriver at the appropriate time to "arm" the device. You could also use a second toggle valve attached into the trigger line for this purpose, but this would increase the expense a bit. Either way, a safety of some kind is a very good idea.
Anyway, this is a great effect, and it's really giving our production a very polished and professional look. Thanks once again to Crosius for sharing it with us.
Jul 27, 2009. 8:00 AMRavingMadStudios says:
Hi there, it's me again. I was just noticing that the effect assembly in the intro page picture seems a bit different than the one in the rest of the Instructable. Is that a check valve in place of the 1/8" ID hose between the quick exhaust valve and the bulkhead fitting, or just a section of tubing? Also, just out of curiosity, do you know how long the circuit will hold pressure and still fire correctly? As I mentioned in a previous comment, I'd like to use this effect in a stage production, so there could be an appreciable gap between pressuring the device and firing it (probably about 30 minutes at the absolute longest, most likely much shorter). Do you think this would be an issue? Thanks once again for a great design.
Sep 11, 2009. 7:15 AMRavingMadStudios says:
Thanks for the update. I built one last week, and after the initial "just playing with it" phase, I let it sit for about 6 hours, and it fired beautifully. Nice to know they can go up to at least 24 without losing pressure, though. I've got parts for 7 more coming in the mail next week. This is a great device, and it's going to make the show look fantastic. I've made a couple of very minor mods to your design: I put in the T (as we discussed earlier) to move the check valve closer to the cylinder, I added a push-fit splice connector to the effect tube to make it easier to fill the tube with blood and banana plugs, and I'm sealing the end of the effect tube with vinyl glue instead of tape. So far, everything works even better than advertised. I highly recommend that anyone who needs bullet hits for a film or show just go ahead and build a few of these. They work very well, and are totally worth the expense. Just do it, you won't be sorry.
Sep 12, 2009. 6:25 AMRavingMadStudios says:
Yeah, I'll actually have nine total (including the first one I made, and an alternate version made from a CO2 bike tire inflator), and we're reloading at intermission to reuse them all in Act II. Plus several "wall splatter" effects to simulate headshots, a garroting, mouth blood packs, a slit throat, and a severed ear. Bloodbath indeed. I'm suggesting that the audience bring tarps. The push-fit splice was kind of an afterthought, but it does make reloading very convenient. It's a straight union, more like PQ-SU12. I got it from Lowe's on a whim while I was buying the vinyl tubing for the effect tube. I like the idea of a reducer, though. I think I'll try that next time. By the way, if you're ever in Statesboro GA, drop me a line. I want to buy you a beer or something.
Sep 12, 2009. 10:18 AMRavingMadStudios says:
Indeed. Funny thing is, I should really be using 15 squibs, but I had to scale back for budgetary reasons. What makes this funny is that the point of the show is about how violent, vengeful behavior is a Very Bad Thing (tm). The playwright has chosen to convey this message via an orgy of bloodshed. The really funny thing is, it works. Anyway, thanks again. I'll post some pics of the show somewhere when the time comes and send you a link so you can see what your creativity has wrought.
Aug 12, 2009. 8:48 PMSruggiero86 says:
So I made this following all of the directions and the chamber wont fill up...could my mini exhaust vale be faulty....it feels like only 2 psi comes out
Aug 13, 2009. 11:28 PMSruggiero86 says:
I think it's me... I guess 100psi feels like a lot less pressure then I though...are there bigger volume chambers that will hold a greater psi for a more powerful effect, or could i use a thinner tube to fill with the stage blood?
Jul 2, 2009. 2:03 PMpoppamies says:
where did you get the mini exhaust valve?
May 27, 2009. 8:53 AMRavingMadStudios says:
This is amazingly elegant. I was looking for a compact non-pyro effect for use in live theatre, and this looks to be an ideal solution. Thanks very much for sharing it. One question: Have you given any thought to modifying the trigger to use a solenoid valve, which could then be triggered with an r/c relay? I ask becasue I'm trying to avoid actor-triggering (don't want the audience to see the trigger), and I can't have a control line running offstage. Any reason you can think of that something like that wouldn't work?
May 27, 2009. 5:59 PMRavingMadStudios says:
$75 bucks? Holy guacamole. Add in the RF gear, relays. battery packs, etc. and your elegant, compact and inexpensive design becomes way too bulky and expensive for a cash-strapped theatre company to consider. I think you were right the first time. Maybe actor-triggered isn't so bad after all.... I might still be willing to try it if I didn't need 12 of the things (it's a very bloody play). Oh well, perhaps for another project. Anyway, thanks again for a great tutorial and a beautiful design.
May 28, 2009. 5:57 AMRavingMadStudios says:
Interesting. I'm not familiar with whisker valves, but I'll definitely check it out. I am assuming that if you T the whisker valve into the signal line, you'd then have two options for firing - the whisker or the toggle. This is just an assumption, but it could be useful if it pans out. As far as the daisy-chaining goes, that could be very useful as well. I may wind up needing a couple of rapid hits for this show, depending upon the staging. I'm guessing something like a schrader valve in place of the solid plug on the reservoir (and an appropriately fitted connector line) would do the trick, with the added benefit of making the daisy-chaining a "modular" option rather than a hard-plumbed design choice. Come to think of it, if there's a schrader valve on the reservoir, couldn't the device be pressurized that way as well, thereby avoiding having to pressurize from the trigger end? This is where my limited knowledge of pneumatic valving comes in, but if the squib can be pressurized from the reservoir end, wouldn't that allow the 3-way toggle on the signal line to be replaced with a simple 2-way valve (maybe just a whisker valve by itself?), and eliminate the need for the check valve assembly altogether? That would be really cool for my purposes, because it would make the trigger assembly smaller, and thus more easily concealable onstage. Or perhaps I'm missing something critical in the valving, and it wouldn't work at all? As I said, I'm no expert. Thanks very much for all your great ideas, and sorry to be such a pain in the hinder.
May 28, 2009. 10:31 AMRavingMadStudios says:
OK, I get it now. I had my brain in backwards there for a minute, I do like the idea of adding the T and putting the check valve closer to the reservoir. I think I'll give that configuration a try, and maybe pick up a couple of whisker valves to play with, too. Based on the specs from the Clippard website, the whiskers might be a little too sensitive for what I need, but it's definitely worth testing. Thanks very much for all of your help. You rock.
Mar 29, 2009. 2:38 PMwangxiao says:
This is by FAR the best, most elegant design I've seen for a non-pyrotechnic squib. I do have some questions though.
It seems that the UT0-2 fitting costs $11 for one, with a minimum order quantity of 5, so it comes out to five fittings for $55 dollars, approximately. I found that part EA-LB10 from Pneumadyne seems to be comparable (10-32 threads with 1/16 inch barb), but for a little over $2.00 a piece, with a MOQ of 25... so for a similar price, it seems you can get 25 instead of 5. Is this really a comparable part?
Also, I think it would be a nicer design if the 3-way valve that triggers the effect used a push-button actuator instead of a flip-switch. The push-button 3-way toggle valves I found seem to be listed as either "normally open" or "normally closed." My assumption would be that the TV-3S is normally closed, but I'd like to know for sure which one I should buy.
Thanks again for the excellent tutorial!
Mar 30, 2009. 12:56 AMwangxiao says:
I see. In that case, perhaps the toggle valve would be best. I am curious, however--suppose I have a situation where it's impractical or impossible for the talent to trigger the effect (ie, 3+ consecutive hits, shots where their hands must be open and in-frame), is there a limit to the length of the signal line which would preclude the possibility of an assistant triggering the effect?
Nov 2, 2008. 12:14 PMkanzume says:
...great stuff! I saw this on another forum and found this here again -- but anyway that's not my point. So basically if I cut my costs down and use a 2 litre coke bottle with the appropriate adaptors instead of the air chamber (which the coke bottle must be on the ground with longer tubing, and other stuff that cost so much, I can reduce the cost... how much is this whole rig? and which store sell all of these stuff -- I don't want to buy over-the-net (I don't live in US so shipping is expensive) or go to 10000 stores to pick up all these parts... a hardware store doesn't sell all of them under 1 roof (or am i wrong?) -- and they usually sell in bulks e.g. 20 valves (well, I can get shot 20 times in 1 go but that, again, raises the costs).
Nov 3, 2008. 10:51 AMkanzume says:
Yes, I saw that -- that's where I got the coke bottle idea from, but it can't be actor-triggered. This is why I want to combine yours and Indymogul's together...
Nov 5, 2008. 4:01 AMkanzume says:
yeah, I liked yours more because it can be actor-triggered with a flip switch. Do you think you can build 1 like that and make a tutorial with the least number of parts required?
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Crosius
