3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pneumatic Squib For On-Actor Film Blood Effects
Step 4Using the Effect
Using the Effect
Use of the Effect:
1. Fill the effect tube and cover the output hole with the smallest possible piece of low-tack masking tape.
2. Tape the effect under the actor's clothing in the appropriate orientation. If the tube must be oriented with the output hole higher than the quick-exhaust, I recommend pushing a plug of banana down the hose before filling it with stage-blood.
3. Dress the actor in the outer costume and pass the control module down the actor's sleeve to their hand.
4. Make a very small cut in the costume over the output hole of the effect. The smaller the hole, the more blood will stay on the actor's clothes. The larger the hole, the more blood will spray away from the actor.
5. Flip the switch towards the control line fitting and connect your air supply to the air inlet. Pressurise to between 60 and 100 PSI. (use a pump with a gauge, or a compressor with a regulator)
6. Disconnect your air supply and film the scene - the check valve will keep the squib pressurised.
7. When the actor is ready, he can flip the switch and the effect will trigger.
4 comments
Aug 12, 2009. 8:48 PMSruggiero86 says:
So I made this following all of the directions and the chamber wont fill up...could my mini exhaust vale be faulty....it feels like only 2 psi comes out
Aug 13, 2009. 11:28 PMSruggiero86 says:
I think it's me... I guess 100psi feels like a lot less pressure then I though...are there bigger volume chambers that will hold a greater psi for a more powerful effect, or could i use a thinner tube to fill with the stage blood?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Crosius
