I made it as part of the Gift Exchange.
It works by sending out a modulated infrared signal. The detector then senses any of the reflected signal, this is how it knows if anyone has passed by.
The main board contains a pickaxe chip. There is a mode select button which allows you to cycle through the different detection methods and alerts.
It runs off of 3 x AG-13 button cells and can sense up to 15cm+ in good conditions.
For a demo watch this video.
I also made a couple of instruction manuals which are attached.
Instructables reduces the image quality of uploads so I've included a PDF with all the diagram illustrations at high res.
Remove these ads by
Signing UpStep 1Materials
I've included links to techsupplies.co.uk so you can see what the pieces look like, as well as places you are likely to find the component.
Components: Likely places to find them:
- Picaxe 08M chip
- Perf / strip board
- IR sensor 38kHz
- 2mm red LED
- 5mm IR LED Any Remote control
- Piezo transducer Anything that makes a beep noise
- 6mm tactile switch Anything that clicks when you press it
- PCB mount slide switch
- Resistors with rough values of 32k, 10k, 1k, 300, 180 Ohms
- <1.2mm insulated wire
- Button cell battery contacts Anything powered by button cells
- 3 x button cell max size AG-13
- Small nut & bolt
also a Zippo style lighter, or other pocketable housing
(small altoids tin etc)
Tools:
- Soldering iron with fine tip
- Drill with 1mm, 2mm, 4mm and 12mm bits
- Small files / sandpaper
- Needle nose pliers
- Side cutters
- Tin snips
- 2 part epoxy glue / hot glue gun
- Pva glue / nail varnish
- Screwdriver
- Hacksaw
These images show what I was able to get out of a broken electronic die.
small electronic things like this are the best place to look for battery contacts.
