chainsaw.tiff
The chainsaw...awesome for cutting down trees, taking out brush super duper quick, and fighting off zombies. The only thing is a chainsaw is big...and rather heavy. Definitely not pocket sized. So I recently stumbled upon some replacement chainsaw blades, and I hacked em to make me my own pocket zombie defense system... well don't know how well it'd stand up to zombies, but I do know it's handy for cutting up firewood, or clearing small trees, and after your all done just carry it in your pocket. Hope you enjoy!
Step 1: What You'll Need
1. a chainsaw replacement blade
2. a metal saw
3. an old garden hose
4. gorilla glue
5. duct tape of your preferred color
6. metal saw
7. chop saw
pretty simple...how i like it
Step 2: Cut Through the Chainsaw Blade
First thing you'll have to do is cut through the blade with the metal cutter. This can be kind of tricky since each joint of the blade pivots. You'll definitely want to wear safety glasses for this part. Once your through the blade move on to the next step.
Step 3: Cut Two Garden Hose Handles
Now cut your garden hose to a whatever length you want for a handle. What ever is comfortable for you is the best length. I used my chop saw to cut the hose.
Step 4: Glue the Handles On
Dip the hose handles in a bowl of water, and shake off the excess water. Gorilla glue sets on damp surfaces which is why you dampen the hose. Put some Gorilla Glue on the chain and some in the hose, then slip the hose over the chain. Use duct tape to hold the hose to the chain and cover the handles to get nicer looking handles. I went with camo duct tape...gives it a nice manly flavor. After the glue dries go try it out, then stuff it in your pocket for the next camping trip. Enjoy!
1-40 of 115Next »
plsharavanan says: Nov 24, 2012. 4:52 AM
Hi.. Good information about the pocket chainsaw. It can be easily carried inside your pocket as it is very much light-weight and portable. There is also a USB powered chainsaw (iSaw) available in the global market which can be used for official purposes.
- Indian chainsaw products
Daniel Zf says: Oct 21, 2012. 12:49 PM
Isn't something like this sold on camping stores? i believe i;ve seen something like this.
zigzagchris in reply to Daniel ZfOct 21, 2012. 5:26 PM
Ya, its similar to these, smaller teeth though, and more pocket-ble
Daniel Zf in reply to zigzagchrisOct 23, 2012. 8:10 AM
as long as it keeps the zombies away
repguy2020 says: Oct 22, 2012. 12:03 AM
More POWER!
kibukun says: Jul 3, 2012. 11:55 AM
Hey, if you make the handles out of wood and longer, you can make these into saw chucks!
repguy2020 in reply to kibukunOct 22, 2012. 12:01 AM
If your name were Terry, they would be Terry's saw chucks
gfry in reply to kibukunJul 14, 2012. 7:38 PM
lol
ElZorro says: Jun 28, 2012. 9:33 PM
Go to the bike store and get a chain break tool.
rbbiggs in reply to ElZorroJul 3, 2012. 12:09 PM
better yet, go to a local Stihl store and get a break tool made for chain saw chain
cerberustugowar in reply to rbbiggsOct 21, 2012. 11:50 AM
should be easily accomplish able with any sort of grinder, pin punch and vice. If someone came to our Stihl store, we would likely just break it for them.
tgferreira184 in reply to rbbiggsJul 28, 2012. 8:05 AM
It's even better go to the local chainsaw garage and ask to break the chain with their machine, and pay a buck or two for the job, or nothing.
static in reply to rbbiggsJul 7, 2012. 1:13 AM
Best yet use the tools already in your shop that will do the job. :) Unless one plans to work on chain saw chains a lot a tool for such chain isn't a good investment, if the ubiquitous bench grinder can get the job done.
ibarnett52 in reply to staticSep 6, 2012. 10:12 AM
bestest yet just get a machete
Madrigorne in reply to ElZorroJun 28, 2012. 11:44 PM
Oh! Good idea!
machoturtle (author) in reply to ElZorroJun 28, 2012. 9:42 PM
nice ok!
bcavaciuti says: Oct 21, 2012. 7:43 AM
if you heated the ends of the pipe (or the middle if you do a perpendicular handle) and squashed it around the blade it would probably grip better and prevent crud getting inside the handle :)
danny6114 says: Jun 28, 2012. 11:40 AM
It would seem more ergonomic to have the handles perpendicular to the chain, instead of parallel. Just a thought.
bcavaciuti in reply to danny6114Oct 21, 2012. 7:36 AM
i agree...its how the military wire saws are they have a metal grip made out of a ring...the design is very simple but effective although i doubt its comfortable after long periods of use i have seen some with loops of nylon strapping and ones with mini coat hangers for the handles...these could be attached to the ring of the wire saw
instructable person 9 says: Oct 21, 2012. 3:09 AM
great job in the contest
arjil says: Aug 17, 2012. 3:25 PM
easier method- most places that sharpen chainsaw blades also have rolls of the stuff for making them in the shop, you should be able to buy any length you want and just ask them to leave it open so you don't have to cut it.
dustinandrews says: Aug 14, 2012. 10:37 AM
Thanks for giving me a fantastic use for two broken chainsaw blades I have kicking around. Keeping a chainsaw running is a pain but after seeing this I realized 60% of the things I use it for would be better accomplished with this device. Well done sir.
Garry Ozols says: Aug 1, 2012. 4:59 AM
there is a link on the chain that has a cir clip that holds a pair of pins through a link in just about every one of the hundreds of chain saw chains I have ever used, just remove it after a careful search for it.
allen401 says: Jul 26, 2012. 9:47 AM
when i made my chainsaw i used the small hose clamps on the ends of the garden hose and tightened as tight as possible and then wrapped the base of the handles and the clamps in gorilla tape, and it only took me 10 min to make and they work great. i must say i love you simplistic design, but i first saw this concept on a infomercial, but the only difference on the commercials pocket chainsaw was it had the handles attached perpendicular to the chain. but once again i love your simplistic design and straightforward guide, you did a good job and i will be using my pocket chainsaw on my upcoming camping trip!
allen401 in reply to allen401Jul 26, 2012. 9:49 AM
third line correction *your
fidgety2 says: Jul 7, 2012. 8:22 AM
You do realize your instructable is based entirely upon my previously submitted one please ask before ripping off someone else's idea
rodss67 says: Jul 4, 2012. 9:32 AM
You can buy this at Harbor Freight for $16.99
pink-zebra-girl says: Jun 30, 2012. 11:58 AM
So totally cool!! I voted for you! :)
bethmwl says: Jun 28, 2012. 3:09 PM
i like the idea. i don't know much about chain saws, but can you use this with a back and forth sawing motion? i thought chain saws, the chain goes in one direction. or will it only cut on one side of the back and forth?
thanks for your help, i want to saw some high branches too, like dabooge
dabooge in reply to bethmwlJun 28, 2012. 4:47 PM
Most carpentry saws only cut in the forward stroke.
you can get something like what I made on ebay. Search for:
HIGH REACH ROPE WOOD SAW SURVIVAL CHAINSAW
Wish I saw them on ebay when I needed one.... oh well
bethmwl in reply to daboogeJun 30, 2012. 10:22 AM
thanks for the info. that is an awesome saw on ebay
zakamooza says: Jun 29, 2012. 3:02 AM
so removed my comment huh,why? because i was right thats why
SacredDemon in reply to zakamoozaJun 30, 2012. 10:03 AM
If your comment was removed it was probably for a good reason. Play nice kids!
machoturtle (author) in reply to zakamoozaJun 29, 2012. 7:29 AM
no...i didn't remove it, Instructables might have
Wroger-Wroger says: Jun 30, 2012. 7:40 AM
Other people have commented on this, - to make it a double acting saw - so it cuts in both directions.
Actually - I am not sure how marketable this is, but using a single link (side plate) type and having the teeth set much like bow saw teeth, to they cut in each direction.
foreverdisturbed says: Jun 28, 2012. 8:18 PM
Sorry to see that every one wants to bash on your instructable. Everyone has to start somewere. Keep building your ideas no matter what everyone else thinks. Keep up the good work.
Madrigorne in reply to foreverdisturbedJun 28, 2012. 11:43 PM
Bash? No way, this instructable rocks!
foreverdisturbed in reply to MadrigorneJun 29, 2012. 6:02 PM
There were some bashing comments at the time I left my comment. They must have been removed because they are not there anymore.
foreverdisturbed in reply to MadrigorneJun 29, 2012. 6:00 PM
I agree I also like the instructable but, Many of the comments were bashing him. Which I think is wrong to do to anyone. I have been in supervisory roles and a little encouragement goes a long way.
machoturtle (author) in reply to foreverdisturbedJun 30, 2012. 10:49 AM
yep! i really appreciated your comments
1-40 of 115Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
