loading
Step 2: Cut Through the Chainsaw Blade
First thing you'll have to do is cut through the blade with the metal cutter. This can be kind of tricky since each joint of the blade pivots. You'll definitely want to wear safety glasses for this part. Once your through the blade move on to the next step.
<p>UPDATE: The &quot;open D rings&quot; I used were actually &quot;hog rings&quot; as someone called them (open link, trapezoid shaped) and I put them to the test with some heavy cutting and sure enough, they held! Pic later!</p>
<p>UPDATE: Don't use keychain rings. They can't handle the pulling stress that I put on the chain. Instead, I found these open D-rings and pinched them shut with the curve on the chain part. The pinched side I retied the cord using a slipknot so it would tighten the more I use it and not slip out. Will post pics as soon as I get it perfected!</p>
<p>Yeah, when I read the original article on how to make it, I didn't like the glue on handles (no disrespect to the original author, just a preference), so I went with the more ergonomic wooden grip handles instead and it works for me like a dream! My chain is a little on the bulky side (16&quot; chainbar length, but I can stand and work with it without hunching over and potentially hurt my back in the process. But being able to quietly cut a log without having to prep my chainsaw just for a couple seconds of cutting is pretty nice!</p>
<p>Hello! This is my first post here on Instructables.com and I would like to say that I made my own version of this pocket chainsaw as well (pictures to later follow!).</p><p>However, my design was slightly different with instead of using the garden hose pieces on the ends glued to the chain, I took two keychain rings and put them through the holes as similar to below, but took 2 pieces of broomstick handle and 4&quot; long and drilled two holes in them near center and threaded some cord through that I got at Harbor Freight (on a freebie coupon!) and then back through the rings on the chainsaw chain using a &quot;lark's head&quot; knot. So with the handles set perpendicular to the chain, you get a better grip and more pull to your cutting stroke.</p><p>Hope someone else gives it a go and tell me how they like it!</p>
<p>thanks for your post. the hand chainsaw is great idea but when i saw the glue i hung my head. this is a great mod to the original idea</p>
Fotos
Here's what I was talking about. Took me about 10 minutes to get the pins out and attach the rings. Make sure to get thicker gauged rings so you have a nice strong connection. The holes in the links where the pins go are actually larger than I was expecting. They're bigger even than regular bike chain pins. The rings I used were 1-1/2" and fit two fingers nicely. Once I get where I'm going (the campsite) it should be no problem finding two sticks to make more comfortable handles if I choose to go that route. The only downside of this method that I see is that the rings sit perpendicular to the chain (which you want when in use) but if you we're to put something heavy on the top of the ring it could torque the chain and break or bend it. Smaller rings might be more useful if that turns out to be a problem. Or you could take the rings off when you're not using the chainsaw.
I just got a chainsaw chain to try this and I'm going to attempt this awesome ible with a few modifications. The &quot;official&quot; pocket chainsaw actually just has little metal loops on the ends. If you're in a rush, you can loop them around your fingers... Orrrr if you have a minute, you can just find two stick, chop them down to about 6&quot; and stick them in the loops. Seems like it would make the system a little lighter, and if you find strong enough metal wire, you don't even need glue. You can just loop the wire through the holes left from the missing chain pins (I think). You could also make a few loops out of paracord and attach them to the metal rings. So you have a comfortable option if you don't have sticks the right size for handles. <br> <br>I got an Oregon chainsaw blade, and then realized that (duh) it's made to cut traveling one direction. Does this seem to effect anything? Are there any chainsaw blades out there that would be better than others for this?
I live on a Greek island, Skopelos. Late Autumn, I start my annual chore of cutting/chopping logs for our wood-burners. This seems a great idea for fiddly bits rather than using my large, heavy chain-saw. Will give it a try this year.
Hi.. Good information about the pocket chainsaw. It can be easily carried inside your pocket as it is very much light-weight and portable. There is also a USB powered chainsaw (iSaw) available in the global market which can be used for official purposes.&nbsp;<br> <br> - <a href="http://www.homeinout.com/chainsaw" rel="nofollow">Indian chainsaw products</a>
Isn't something like this sold on camping stores? i believe i;ve seen something like this.
Ya, its similar to these, smaller teeth though, and more pocket-ble
as long as it keeps the zombies away
More POWER!
Hey, if you make the handles out of wood and longer, you can make these into saw chucks!
If your name were Terry, they would be Terry's saw chucks
lol
Go to the bike store and get a chain break tool. <br />
better yet, go to a local Stihl store and get a break tool made for chain saw chain
should be easily accomplish able with any sort of grinder, pin punch and vice. If someone came to our Stihl store, we would likely just break it for them.
Best yet use the tools already in your shop that will do the job. :) Unless one plans to work on chain saw chains a lot a tool for such chain isn't a good investment, if the ubiquitous bench grinder can get the job done.
bestest yet just get a machete <br>
It's even better go to the local chainsaw garage and ask to break the chain with their machine, and pay a buck or two for the job, or nothing.
Oh! Good idea!
nice ok!
if you heated the ends of the pipe (or the middle if you do a perpendicular handle) and squashed it around the blade it would probably grip better and prevent crud getting inside the handle :)
It would seem more ergonomic to have the handles perpendicular to the chain, instead of parallel. Just a thought.
i agree...its how the military wire saws are they have a metal grip made out of a ring...the design is very simple but effective although i doubt its comfortable after long periods of use i have seen some with loops of nylon strapping and ones with mini coat hangers for the handles...these could be attached to the ring of the wire saw
great job in the contest
easier method- most places that sharpen chainsaw blades also have rolls of the stuff for making them in the shop, you should be able to buy any length you want and just ask them to leave it open so you don't have to cut it.
Thanks for giving me a fantastic use for two broken chainsaw blades I have kicking around. Keeping a chainsaw running is a pain but after seeing this I realized 60% of the things I use it for would be better accomplished with this device. Well done sir.
there is a link on the chain that has a cir clip that holds a pair of pins through a link in just about every one of the hundreds of chain saw chains I have ever used, just remove it after a careful search for it.
when i made my chainsaw i used the small hose clamps on the ends of the garden hose and tightened as tight as possible and then wrapped the base of the handles and the clamps in gorilla tape, and it only took me 10 min to make and they work great. i must say i love you simplistic design, but i first saw this concept on a infomercial, but the only difference on the commercials pocket chainsaw was it had the handles attached perpendicular to the chain. but once again i love your simplistic design and straightforward guide, you did a good job and i will be using my pocket chainsaw on my upcoming camping trip!
third line correction *your
You do realize your instructable is based entirely upon my previously submitted one please ask before ripping off someone else's idea
You can buy this at Harbor Freight for $16.99
So totally cool!! I voted for you! :)
Sorry to see that every one wants to bash on your instructable. Everyone has to start somewere. Keep building your ideas no matter what everyone else thinks. Keep up the good work.
Bash? No way, this instructable rocks!
I agree I also like the instructable but, Many of the comments were bashing him. Which I think is wrong to do to anyone. I have been in supervisory roles and a little encouragement goes a long way.
yep! i really appreciated your comments
There were some bashing comments at the time I left my comment. They must have been removed because they are not there anymore.
ya i know...it's ok. Thanks for the encouragement!
i like the idea. i don't know much about chain saws, but can you use this with a back and forth sawing motion? i thought chain saws, the chain goes in one direction. or will it only cut on one side of the back and forth? <br />thanks for your help, i want to saw some high branches too, like dabooge
Most carpentry saws only cut in the forward stroke. <br /> <br />you can get something like what I made on ebay. Search for: <br />HIGH REACH ROPE WOOD SAW SURVIVAL CHAINSAW <br /> <br />Wish I saw them on ebay when I needed one.... oh well
thanks for the info. that is an awesome saw on ebay
so removed my comment huh,why? because i was right thats why
If your comment was removed it was probably for a good reason. Play nice kids!
no...i didn't remove it, Instructables might have
typically a chainsaw has only one side of each of the teeth sharpened for cutting since they alway spin the same direction. As this saw will be going back and forth, did you sharpen the other side of the teeth to cut both ways? Or have you felt the need to?
About This Instructable
113,006views
579favorites
License:
Bio: A country boy...live on forty acres, shoot guns, hike, hunt, fish, play soccer, and more!
More by machoturtle:The Ultimate Altoids Survival Kit Roadkill Huntin' Redneck Pen Set
Add instructable to:
