3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Scrolls
Step 4Third Step: Putting it all together
Now what were going to do is get the paper on the wood. I suggest to wrap one end of the paper arround the wood just so it gets the general shape. After that, go ahead and put glue on the end of the paper that you pre-curled and wrap it around the wood so that there is an even length of wood on both sides. There is likely to be a little mess left over, so go ahead and do some clean up, then let it dry.
1 comment
Jul 9, 2009. 8:22 AMmistercow.pnoy says:
Suggestion: use a very small pencil with a rather blunt tip and slice a little groove down the side. Shove the paper in the slit, then roll from there. The pressure from the slit should hold the paper from slipping out and you'll always have something to write with.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Edge
