Introduction: Pocket Sized Camp Stove (The Improved
Picture of Pocket Sized Camp Stove (The Improved
This instructable actually came about through necessity. I love camping, and often go hiking in the woods. How often have you spent a day fishing, and wished you could throw some fresh fish into a pan right there on the dock?
For me, this always meant carrying a bulky, expensive kerosene or propane stove which themselves can be something of a pain to get warm enough to use.
There are numerous instructables here on how to make a "Penny Stove." However, there are a series of problems with the Penny Stove concept that need to be addressed. For instance:
1.) You cannot put a large pot on a penny stove without crushing it.
2.) Penny Stoves get very hot, so must be placed on something that will not burn to be used.
3.) Putting a Penny Stove in your pocket or backpack for a hike, it will get crushed fairly quickly.
4.) Penny Stoves are either difficult to light, or do not conserve fuel well.
5.) Penny Stoves are easily blown out in the wind.
As for the commercial "camp" stoves, the *only* ones I've found are either glorified penny stoves (with all the same problems) or require you to carry bulky, heavy, expensive canisters of propane or butane. (Or a mix of the two.) I never did get the point of spending $50 for a "3 oz stove" only to have to carry a 13 oz canister to use it for 1 hour.
Most DIY Camp Stoves I've been able to find use a separate wind screen that's generally a piece of aluminum that would get bent and banged up in my backpack, or no wind screen at all.
All of these issues have been addressed with the new and improved "Penny Stove" or as I like to call it, the "Pocket Sized Camp Stove." I do honestly prefer this over any commercial stove I've yet seen (and I've seen a lot). Better still, it was free. Even a cheap commercial camp stove starts at $30 and goes up quickly from there. I've seen less useful stoves selling for over $100. Considering that commercial stove fuel is also more than twice as expensive as denatured alcohol (calculated by burn time) and harder to come by, there's just simply no reason for me to purchase anything commercial.
While this isn't the size of an Altoids tin, and won't fit in your hip pocket, it will easily carry in a cargo pocket, or in the pocket of your backpack. I keep it in one of the smaller pockets of my ruck sack whenever I go hiking.
For $1.25, you can get a bottle of HEET, and numerous other fuels are even cheaper. (Though I'll tell you from experience, you'll get odd looks buying half a dozen bottles in the middle of the summer. I think the guy thought I was cooking meth.)
Compare this to the Esbit Stove that takes solid state tablets that burn (realistically) for approximately 10 minutes at $0.50 a piece. That's $3/hr, and it's not easy to come by.
While I haven't tested it, I'm pretty sure a $1.25 bottle of HEET (that can be picked up nearly anywhere, including gas stations) lasts me more than an hour.
My preferred fuel is Denatured Alcohol. (See the "Fuel" step.)
Finally, the problem I've had with solid state fuels is the time it takes them to heat up, the amount of heat they put out, and the amount of time it takes to put them away. This stove is ready to go in 1 minute, can be extinguished by blowing it out, or putting the measuring cup over it, and cools off in less than 3 minutes.
For a quick stop to fry up some lunch, this is my stove of choice.
If anyone has suggestions for improvements, I'm all ears.
Step 1: WARNING!!!
Picture of WARNING!!!
I want to make it clear that Penny Stoves CAN detonate. This is not a minor warning, but a very serious one. Unless you take certain precautions, you *can* actually cause your stove to explode.
Just as with any gas that burns, vapors can be dangerous when you do not handle them properly. You should *NEVER* do the following:
1.) Attempt to fuel a lit stove. (Note that the flames of alcohol can be invisible.)
2.) Attempt to light a stove that is already nearly out of fuel.
3.) Bring a stove that has been saturated with fuel near fire (unless attempting to light as instructed)
4.) Bring a stove that has recently been extinguished near fire unless it has been refilled.
5.) Pack a stove that still has fuel in it.
6.) Place anything valuable (including the face) above the stove while lighting. (Generally, detonation will fire straight up.)
7.) Overfill an alcohol stove. As the stove heats up, it will spew flaming alcohol out of the vents.
Vaporized fuel lights quickly, and can actually cause the stove to detonate. While a stove this lightweight isn't likely to cause severe damage, it is possible that in the detonation, it could throw excess fuel around and catch the surroundings on fire.
Once a "Penny Stove" is extinguished (even if it "burns out") it is still hot, and thus, can still produce gas vapors. These vapors can collect in any space in the stove and detonate with force when lit. Always make sure that a stove that has been recently used is either completely refueled and set up properly prior to re-ignition, or is allowed to evaporate all fuel prior to storage.
I say again, use caution when playing with fire and fuels. Things can get dangerous when proper precautions are not taken. Watch the video, and read the instructions, and do not mess around with the stove otherwise. Always, always, always make sure no fuel is stored inside the stove.
Whenever using any kind of open flame stove, always have a method to extinguish a fire should one occur. (Well, obviously one will occur, but if it should occur where it shouldn't... erm... occur...)
Step 2: Required Materials
Picture of Required Materials
What you will need for this is the following:
  • Two (2) aluminum soda cans to make a very standard "Penny Stove"
  • Two (2) wire hangers (enamel finished, not the plastic covered ones)
  • One (1) Large Tin Can (Juice Cans work Well) - 4.25" (10.8 cm) diameter.
  • One (1) Medium Tin Can (Only very slightly smaller in diameter to the Large Can, I used the large sized refried beans can.) - 4" (10.16 cm) diameter
  • One (1) "Small" can. (Just large enough to fit around a soda can. For this, I used a diced tomato can.) 3" (7.62 cm) diameter.
  • One tube JB Weld (or any other liquid epoxy that can withstand temperatures up to 500 degrees F (260 C). For those of you outside of the U.S. who still want to use JB Weld, here's where you can find it: They should pay me for this.
** Note: It is not important to get the exact size of the cans. All that matters is that the small can fits around the soda can. The medium can fits around the small can, and the big can fits around the medium can.
Step 3: Optional Materials
Picture of Optional Materials
JB Stik Weld is also an epoxy, but in a thicker, putty format. I would strongly recommend using this as well, although for the patient individual, it *is* possible to use the liquid epoxy by waiting until it has hardened to almost a putty consistency. This will, however, give you a weaker bond with the putty than if you had used an actual epoxy putty. I would recommend keeping some of this putty handy anyway, as it has a million and one uses.
Again, any heat resistant (500 F or 250 C) epoxy putty will suffice.
Step 4: Required Tools
Picture of Required Tools
The tools shown in the image are pretty much needed for this instructable. I know not everyone owns a Dremel, but I can't stress enough just how much any hobbiest needs one. Even a cheap one.
The wire snips and needle-nosed pliers are a must-have.
The clamps and slide square are semi-optional. You will need to come up with your own rig for holding the blade and needles if you don't have them.
I'll let the picture speak for itself.
Step 5: Optional Tools
Picture of Optional Tools
While you can get away with using your wire snips and Dremel to prep the Penny Stove's top, I find it's much easier to use some heavy duty scissors and a hole punch.
Note that I have discovered that while a hole punch does will against an aluminum can, it does not fair so well against tin cans.
RIP Hole Punch... Your life was short, but productive...
The wet or dry erase marker will be invaluable for drilling all the necessary holes in the correct spots, as well as cutting the pieces to the right sizes.
Step 6: Fuel
Picture of Fuel
There are a number of fuels that can be used in these stoves, but they are specifically designed to use alcohol based fuels.
The most common fuels seen are:
"Heet" Gas-Line Antifreeze and Water Remover - Easily found in the U.S. at virtually any gas station, this is mostly Methyl Alcohol. It burns well in alcohol stoves, but does have a small amount of petroleum additives, and leaves a bit of an odor behind. Great in a pinch, but not my favorite.
Denatured Alcohol - Denatured alcohol is the best choice for most alcohol based camp stoves. This can usually be found in the paint section (as a paint thinner) of a hardware store, and seems to burn slightly hotter and cleaner than Heet. I don't know if this is found under this name outside of the U.S. In the U.S. "denatured" means "poisoned." This is regular alcohol that has had poison added to it so people can't drink it, thus it does not get the alcohol tax, making it cheaper. (Still runs roughly the same price as Heet though.)
User Tips: telboyo - in the UK denatured lcohol is called Methylated Spirits and is colo(u)red purple
Transportation of Fuel - Many people have mentioned they prefer squirt bottles to take their fuel on hikes with them. My personal favorite container are old "5-hour energy drink" bottles. These are easily cleaned out, and hold almost exactly 30 minutes worth of fuel for me.
Step 7: Making the Penny Stove
Picture of Making the Penny Stove
Penny Stoves have been covered in length on this site, but I will go through the simple steps used to make the one I use for my own stove. Many cans were sacrificed to determine which stove was the most efficient for this rig. Some stoves that are more efficient outside of this rig do not fair well inside of it due to the unique "heat channeling" of the wind guard.
The best design discovered is made with 8 thumbtack holes instead of needles. (Though larger needles can be used.)
The Penny Stove I will show you how to make is, in summary, nothing more than the bottom of two cans with holes in one that's stuffed inside the other. Nothing more. No "wicking" inside such as fiberglass, cotton, lint, etc.
IMPORTANT NOTE: Make absolute sure that your cans are thoroughly cleaned before you start work on them. If there is any soda residue in the bottom of the cans, it will be evaporated by the alcohol and clog the vent holes. You will have to start all over.
Note that while there are many stove designs that tell you to first sand the paint off of the stoves, I very specifically do not want you to do this. At least not for the "top" of the stove. The paint will act as a "glue" the first time the stove is lit adding strength and stability.
Step 8: Making the Penny Stove (Cutting the Pieces)
Picture of Making the Penny Stove (Cutting the Pieces)
1.) Using the razor blade rig (Image 1), score both cans approximately 1.5" from the bottom. Note that the score line does not have to be particularly deep, as it's just a "guide" that allows the can to split where you want it to. A couple of passes is usually sufficient. See Image 2.
2.) Once scored, poke a very small hole in the line with razor. (Image 3)
3.) Using your thumbs, gently press on the top portion of the can to cause the "hole" to continue to "tear" along the score line. (Image 4)
4.) The scoring will cause the can to continue to "tear" along the score line, giving you a very clean cut. (Image 5) Remove the bottoms from both cans this way.
Step 9: Making the Penny Stove (Prepping the Parts)
Picture of Making the Penny Stove (Prepping the Parts)
1.) Scoring the stove will cause the can to slightly bend "inward" where it was cut. While this is desirable for the top of the stove, you'll want to "stretch out" the opening of the bottom of the stove. Simply place a can inside of it, and "roll" it around a bit in a circular motion as shown in Image 1. Do not press hard or you will split the bottom. You do not need to stretch it much, just slowly work it around just enough to very, very slightly flair out the top.
That's all the prep necessary for the bottom of the stove.
2.) Using the hole punch, punch 8 evenly spaced holes approximately 1/4 of an inch (or 1 cm) down from the curve in the top of the stove. Then, using the scissors, cut a line from the bottom into each of these holes. (Image 2) The holes will keep the can from continuing to split along the line that you cut. The cut lines allow you to easily insert the top into the bottom.
3.) Using your wet/dry erase marker, put dots on the stove where the vent holes will belong. Be careful to space them evenly, and put them at the same height around the top (Image 3)
User Tips: Tetrafish - To evenly space the holes you could wrap a strip of paper around it, mark it's (circumference) length, then evenly divide them...
                    jacksteal4 - ...just fold the paper into 16 or 8 parts [using the creases to get your even spacing]...
4.) You can use needles to punch holes by holding them in a clamp (Image 4). However, keep in mind that I've found that using a thumb tack to make the 8 holes works best with this stove.
5.) Using the Dremel, drill a 1/8" (3.25mm) hole in the center of the top piece. (Image 5)
That's all the prep for the pieces!
Step 10: Making the Penny Stove (Final Steps)
Picture of Making the Penny Stove (Final Steps)
The assembly of the stove is by far the most delicate step in the instructable. Be very careful here.
1.) Slide the top into the bottom piece. (Image 1)
2.) Very, very carefully, start pressing the two pieces together evenly, a little bit at a time. When it starts to get tight, you will find that at the top of some of the holes that were punched you will need to use a shim cut from the spare parts of the can (Image 2) to work the two pieces down. Again, do this very, very slowly, a very small amount at a time. Do not use a lot of pressure. If the two parts seem to be too hard to push together, simply wait for a few more seconds. The two cans will slowly stretch ever so slightly allowing you to eventually work them together. I cannot stress enough how delicate you have to be, making sure that all sides evenly go in tiny fractions of an inch at a time. Attempting to force them too quickly will make either one of the cans split, or one end will pop out of the bottom while the other end goes in too deep. Slow and steady here.
3.) Gently, slowly, and evenly press the cans together until the bottom is even with the curve in the top. (Image 3)
Notes:
  • I say again, you do not want to sand the paint off of the top piece. As the paint heats up, it will actually act like "glue" and seal the top to the bottom piece the first time you use it.
  • As said above, you also do not need to use glue to make this.
  • Since this stove will not recieve ANY weight, it does not have to be reinforced, or otherwise made any stronger. (After its initial lighting, the paint on the inner can adhering to the outer can will still make it fairly sturdy.)
  • Note that I did not use any fillers such as cloth, fiberglass, etc.
Throw your favorite lucky penny (NOT quarters, dimes, or other ridged coins) in, and you're ready to go. This is as much as needs to be done to make the standard "Penny Stove."
Step 11: Making the Measuring Cup
Picture of Making the Measuring Cup
The measuring cup is made out of the "small" tin can and is approximately the same size as the penny stove itself.
1.) There's no need to be too exacting here. Just set the small can next to the penny stove, and draw a line approximately the same height. (Image 1)
2.) Cut off the top (with the dremel, unless you're fortunate enough to own a large tube cutter) so it's close to even.
3.) Sand all of the edges of the cup so it's not sharp.
4.) "Pinch" the lip of the cup so it looks a bit like a spout (Image 2).
The measuring cup can be marked, though I just know by looking how much fuel I need to use in my stove. The ribbed lines around the edge can be used to figure out approximately how long the stove will burn through testing (it will be different for every stove).
I found that this cup was necessary, since the containers of fuel seldom want to pour smoothly, and I didn't feel like having a large fireball in my tent. (Yes, you can use this indoors, with the proper fuel and stability!)
Step 12: Make the Rack Pins
Picture of Make the Rack Pins
The rack pins are fairly simple. Take a straight piece of hanger wire and bend a hook into it as shown. The length of the pin should be approximately 1/2" (~13 mm) taller than the wind guard. (This will actually be made in the next step.)
Step 13: Making the Wind Guard
Picture of Making the Wind Guard
The Wind Guard serves two purposes. It will not only protect the stove from light winds when outdoors, but it will also help channel the heat upwards. This means more efficiency, which means less fuel consumed.
The most important part here is how the lid is removed from your large can. A standard can opener cuts the INSIDE of the can. More modern can openers now actually cut the OUTSIDE of the can. You absolutely will have to use one of these newer can openers and keep the lid or this will not work. You will need this lid later. I recommend one of the "One Touch" can openers for the most solid, stable lid.
The wind guard is quite simple:
1.) Set the Stove next to your Large can.
2.) Measure 1/2" to 3/4" above the stove and draw a line around the "down" part of the ribbing. You will need to do this for the lid to fit. (Image 1)
3.) Cut the top of the large can off with the Dremel.
Now is when you would create your rack pins from the previous step!
4.) Drill 16 evenly spaced 1/8" (approx 3.2 mm) holes on the "bottom" of the Wind Guard. These should be a few millimeters above the bottom so alcohol doesn't leak out during priming.
5.) Drill 2 rows of 8 evenly spaced 1/4" (~5 mm) holes (note emphasis) staggered on the "top" of the Wind Guard. (Image 2) Note: I used the hole punch for these holes. As it utterly destroyed the hole punch, I would not recommend this.
You will need to refer to Image 3 for the following steps. This looks much more complex than it is. Make sure you know what you're doing before trying, as the JB Stik has a fairly quick setting (hardening) time. If you mess up, you can use water to remove the putty, dry thoroughly, sand a bit, and try again.
6.) Pick two pairs of the "lower" holes that are across from each other. (blue circles) Now, draw a wet/dry erase line (red lines) on the bottom of the can from below one circle to its opposing circle. Now, approximately 1/2" (13 mm) towards the inside, drill four 1/8" (3.2 mm) holes that intersect this line (green circles). These will be the support holes for the pegs that will hold the rack.
7.) Apply a very small (smaller than pea sized) ball of the JB Stik to each of these holes on the "bottom" of the Wind Guard (Image 4) and flatten it out so it's close to flush with the bottom of the can. You can wet your fingers a little bit to keep the weld from sticking to them, but make sure not to get water on the putty where it needs to stick to the Wind Guard. Notice that I also sanded a bit around the hole just to rough up the surface to get a better stick. You should do this with anything you use the putty on.
8.) Going back to the inside, you will see that some of the weld has pushed through. Flatten this out as well, then slide a rack pin through the corresponding large hole, and make a small indentation in the putty. You do not want the rack pin to go all the way through the putty. A small indentation is all that is necessary. The indentation will need to be deep enough that the rack pins will not "slip" when an item is placed on the stove, but not so deep as to break through the bottom of the putty. I recommend holding a finger on the putty below so you can feel the pin getting close to breaking through. This should be sufficient. (If you do not feel that the hole is able to go deep enough without breaking through, you can add a very small amount of putty to the holes on the inside of the Wind Guard. Be careful not to use too much putty, though, as it is only able to handle temperatures up to 500 F (260 C) and will need the rest of the can to act as a heat-sink for it.)
The final indentations should look like those in Image 5.
User Tip: jacksteal4 - The trick was to wet the pegs when you put them in so it didn't stick to the epoxy.
Those who have been following this instructable will notice that this is a significant improvement over the original design. Originally, the JB Stik "nubs" stuck out on the sides of the wind guard. Not only did they block priming holes, but they had a tendency to get hooked on items while in the backpack and get broken off. This new design eliminates that problem, and makes the final stove look more "sleek."
Step 14: Creating the Base/Lid
Picture of Creating the Base/Lid
The Base will also double as the lid for the stove.
The Base will allow you to use the stove on surfaces that would otherwise burn. It only ever gets lukewarm to the touch, and as you'll see in the end video, can be used to even hold the lit stove in the palm of your hand. Not sure why you would want to, other than to prove you can, though.
1.) Take your medium can, and cut the bottom of it off with a Dremel at about an inch and a half.
2.) Cut a hole in the middle of the bottom of the can large enough for the base of the small can (measuring cup) to fit through. This doesn't have to be particularly accurate, but don't make the hole so big that when put together, all the pieces will rattle around.
3.) VERY IMPORTANT: Use the JB Weld to "glue" the UPSIDE DOWN LID of the large can to the top (ie: part that was cut) of the medium can on the INSIDE. Make sure it is centered. Reread this, then look at the images to make sure you understand it. The large can lid will need to be flipped so the "lip" faces "upwards" on the base, or it will not be useful as a lid. I found that a piece of tape or clamps were handy to hold the parts in place while applying the JB Weld.
Step 15: Making the Pot Rack
Picture of Making the Pot Rack
The Pot Rack will enable you to put much larger pots and pans on your stove, making it functional for much more than just heating coffee. Between this, a mess kit, and some spices, you'll be ready to fry up some fish right out there on your little John Boat! (Do keep a fire extinguisher handy. No reason to be stupid.)
The rack doubles as both the rack that your pots and pans will rest on, as well as the "lock" for when the container is closed. (Image 2)
This is made by simply bending a piece of hanger around the stove when the lid is put on (Image 1) and then using a loop at the bottom to attach it. It's very important that this be very snug, as it will stretch over time.
(Optional)
As seen in Image 3 I like to use a small hooked piece of hanger to handle the rack when its hot. I curve it to fit inside the Wind Guard, and put a hook on it to allow me to pick up the rack when it's been heated. It's a handy tool for dealing with anything hot.
Step 16: Assembly (Packed)
Picture of Assembly (Packed)
When you're ready to put your stove in your pack, this is how it's assembled:
1.) Put your rack pins into the lid (Image 1)
2.) Put your measuring cup into the lid, and put in a coin (my lucky penny) (Image 2)
3.) Place the Penny Stove into the measuring cup upside down and put the Wind Guard over the whole rig. If you made a hook for holding your rack, this can also be put in at this point. (Image 3)
4.) Lock everything in place by sliding the rack over the whole unit. (Image 4)
That's all there is to it! You're ready to go camping!
As a final touch, to make your rig look more "professional" as well as extend its life, here's some great tips from some of the comments:
User Tip: GWESTMOR - ...you might want to paint the stove with grill paint to keep it from rusting
User Tip:  LCsDAD - I might just DuraCoat mine in a sweet olive drab or go the opposite direction with a 'hazard' orange...
Step 17: Usage (Video)
Picture of Usage (Video)
1.) Remove rack from around stove.
2.) Remove lid/base, and empty contents (rack pins).
3.) Place lid/base upright on stable surface.
4.) Remove fuel cup and set aside.
5.) Remove stove/penny.
6.) If you created the optional hook tool, remove this.
7.) Place wind guard on top of lid/base.
8.) Insert rack pins through appropriate holes, and set them in their "nubs."
9.) Place stove (sans penny) into center of wind guard.
10.) Slowly add fuel to stove (either with fuel cup, or squirt bottle) by dumping fuel into the top of it and letting it drain.
11.) Dump small amount (will differ for each stove, experiment) of fuel into wind guard as primer.
12.) Add penny to stove, covering fuel hole.
13.) Place rack into rack pins.
14.) Light with flint striker over stove, or bring lighter near a side hole.
15.) Stove will take approximately 30-45 seconds to heat up.
16.) Use only stable flat-bottomed pan/bowl/cup to cook.
Note that if desired, the penny stove itself can be turned upside down and used to burn solid state fuels such as esbit fuel tabs.
Notes when using:
  • The pictures of the lit stove were taken in a dim room. Keep in mind that outdoors, or in bright light, you will often not be able to see the flame at all. Take care not to burn yourself.
  • Read the 2nd step's warnings.
  • Try to measure your fuel so it burns out just as you're done with it.
  • The stove can be extinguished by placing the inverted "measuring cup" over it, or blowing it out. Water will also quickly put out any alcohol fires. (Make sure the measuring cup has no fuel left in it.) Do not store the stove with fluid in it.
  • When primed, it can be started with a flint striker.
  • The thinner/smaller the utensils used to cook on it, the faster and hotter they will get. Have gloves handy.
  • If using this indoors, make sure you have a *very* stable place for it to sit where it will not get knocked over. Have a method for putting out the fire handy just in case.
  • If you cannot understand how to build it by reading these instructions, do not attempt to do so. You shouldn't be playing with fire.
The attached video shows how to unpack and use your new stove.
Enjoy!
Any comments, improvements, or any critiques are welcome!
Step 18: Specs
Picture of Specs
After much experimentation, it was determined that for this particular design, the most efficient stove is one with 8 evenly spaced "thumbtack" sized holes. Even spacing is important for most efficient heat output. Also make sure your holes are all the same size.
  • The packed camp stove (when made with the same materials in this instructable) is 4.5" (11.43 cm) in diameter, and 3" (7.62 cm) high.
  • The stove with all options (cup/hook) weighs 6.5 oz (184.27 grams).
  • The stove can easily handle up to 5 lbs (2.27 kg). I did not bother testing further as you shouldn't need to cook anything over 5 lbs (2.27 kg). while camping/hiking, and I didn't want to destroy another stove.
When using denatured alcohol:
  • The stove can hold up to 2 oz (59 ml) safely.
  • 2 oz (59ml) will burn for roughly 30 minutes.
  • Stove should take 30-45 seconds to heat up enough to use.
  • Stove takes approximately 3 minutes to cool down after use.
  • 2 cups (16 oz, 1 lb, 473 ml, 453.59237 grams) of water at room temperature (70 F, 21.1111C) will boil (212 F, 100 C) in under 5 minutes (300 sec).
  • "Heet" burns slightly longer, but with less heat (ironic, no?) meaning longer boil times. It also has an off-putting odor. Not recommended, but works in a pinch.
Other Notes
The penny stove does have a good deal of "wasted space" in it. Particularly in the lid. If this stove is something you like to keep around "for emergencies" instead of to use regularly, consider using that space in the lid.
  • Rig a long, sturdy plastic bag (can be made with a FoodSaver) to hold 2 oz of alcohol, and stuff it into the empty space. Remove the "Fuel Cup" for even more space.
  • Add some waterproof matches or a small flint
  • Fishing hooks and fishing line
  • Band-Aids
  • Antibiotic ointment
  • Water purifier tablets
  • A small compass
  • Sealed toilet paper
  • Lengths of nylon cord
See what all you can stuff into all the nooks and crannies, and you'll have the ultimate emergency kit, complete with stove! The stove can be used to get even the wettest wood started burning.
Javin007 (author)2012-09-20
For anyone interested: It's been over three years since I've posted this 'ible. (And the response has been fantastic! Thank you all!)
To date, I still regularly use the stove that is in this video, and it doesn't seem any the worse for wear. I haven't even painted it or sealed it in any way. The rack pins have a small amount of rust on them, but other than that, it's still in great shape!
darman12 (author)Javin0072013-08-23
How is it holding up now?
Javin007 (author)darman122014-01-30
Still going strong! Haven't had to build a new one yet!
ryanpmcg made it! (author)2016-12-09
Like the instructions said, I had to make a few small adjustments nothing too crazy though. Also, it took a few seconds to ignite but burned pretty good once it lit. Only problem I had was the wind, I had to block the wind otherwise it would have blown out easily.
B Mac (author)2016-03-10
You have a lot of comments from people so I have not read all the way through it, but my question is would you be willing to make me one of these for me? I am currently traveling and have none of the tools listed. I can pay through PayPal if you want. Thanks.
Javin007 (author)B Mac2016-04-04
Unfortunately, it's just not an option. Between the hours I work (11+ per day) and the commute (1.5 hrs. one way) I just don't have any spare time. If I were to charge you what I get paid by the hour for the time it'd take me to make it, plus shipping, you'd already be in the hundreds of dollars. :D Kinda defeats the purpose of making a "free" stove.
willsme (author)2015-08-18
OK, made two of these things that wouldn't light, UNTIL I noticed someone mention about "priming" it. Since I have no experience with burners like this, it wasn't until I saw in the video that one dumps a small amount of fuel into the windscreen after burner is filled, and it's the fuel in the windscreen that is ignited and burns and "primes" the burner. Shheesshh, such a simple point, and my only criticism of this is that I sure wish it woulda been mentioned sooner. I just wonder how many other people like me had their stove fail to light and then wonder what they did wrong! Otherwise, the instructions are great. Thanks for sharing this!
Javin007 (author)willsme2015-08-18
:) See step 17, section 11:
"11.) Dump small amount (will differ for each stove, experiment) of fuel into wind guard as primer."
Glad you were able to get it working! Where are you located so I can add you to the map?
aronzitti (author)2015-08-15
Hello guys, it proved a little difficult scheme.
Council to put the wool of steel, as was customary in the tanks of tanks
Ronza
stoutmtc (author)2015-07-21
Love this instructable!
Do you have any recommendations for how to do a simmer ring for the stove? Seems like a can top with the middle cut out might work?
PtacoP (author)2015-05-13
Heet from the autoparts store is always under $3/bottle. Good ol' denatured alcohol. Great instructable, thanks!
kcls (author)2009-09-17
We just made one of these. We haven't actually epoxied everything together yet but we were so exited we lit it anyway. We lit it once during the day, but we couldn't see the flames so we decided to light it once it got dark out. The first time it lit fine with no problems. When we lit it again at night, I apparently put in a little to much primer and the whole thing exploded. Half the picnic table was on fire, but it was just the alcohol so that burned off quickly and no one and nothing was hurt, including the stove! we put it back together and lit it again (this time on a non flammable surface) and had a marsh-mallow roast over it. The five hour energy bottle worked like a charm, and after exactly half an hour, we were done. Thanks for this awesome Instructable!
Javin007 (author)kcls2009-09-17
LMAO @ "...the whole thing exploded...we put it back together and lit it again..." Glad to see everything worked out for you in the end. :D Can you describe the "explosion" as I've really gone to lengths to try and make this as least-detonate-able as possible. Was it more of a "fwoosh" of fumes lighting, or an actual "pop" of the stove?
kcls (author)Javin0072009-09-17
It was a little bit of both. The can flew across to the other side of the picnic table. it wasn't a design flaw, it was more because of the fact that I poured half of the alcohol into the wind guard. It was quite the explosion though, and it wasn't actually our picnic table. It belongs to the marina that we are keeping our boat at. The thing kind of burst into flame, spewing lit alcohol everywhere. The next time we lit it, we used almost no primer and it worked fine, except for one problem, where alot of flame was coming out of the hole that the penny was over. This could have been caused by one of two things: 1.by the fact that when we lit the stove earlier after we put it out we were putting our fingerprints into the penny while it was soft, possibly bending the penny, and 2. a defect in the can from it exploding. I don't think it was vent flame either because it did that the whole time
Javin007 (author)kcls2009-12-01
"alot of flame was coming out of the hole that the penny was over"
Generally, this is caused by the holes being too big, or too many, or the wind guard not having enough ventilation.  The stove works by heating up and vaporizing the alcohol into a gas.  If too much heat is channeled back to the stove, it will vaporize even MORE gas, making the flames even bigger, which in turn creates more heat, etc.  The end result is a small torrent of flame coming from underneath the penny.
Unfortunately, for each stove (windguard) the balance will be different.  You'll find you'll have to make numerous stoves with different hole configurations to find the one that's optimized for your rig.
That being said, it's not unusual for a small amount of offgassing to escape from the penny hole anyway.
jasnjules (author)Javin0072015-01-13
I lit my penny stove a few times and found that tbs or so of fuel that I splashed to get it started was different every time because of the inconsistency of the splash. I now use a bottle cap. put some fuel in there and I find the heat is concentrated to that area thus lighting the burner more quickly and predictably. I put it so roughly 2/3 is under the burner and 1/3 is sticking out so that the flame shoots up the side of the can causing the vapors to burn as soon as they escape.
NatureBoom21 (author)kcls2009-09-20
LMFAO ROFL LMFAO ROFL!!!
LOL
ac-dc (author)2013-07-29
You can make the epoxy structure thicker and stronger if you use it similar to how fiberglass is laid. That is, wet the surface with the epoxy then wrap some saturated steel wool around it. While this isn't as pretty for certain applications, for mechanical ones it is superior. Of course you could also use asbestos or equivalent heat resistant cloth, but don't snort the stuff since it is theoretically a hazard to your lungs if asbestos.
steve.oakley.10 (author)ac-dc2015-01-12
Steel Wool will BURN ! take some steel wool + D battery and instant fire starter. put a hot flame to steel wool like propane torch or lighter and it will go right up in flames. use proper temp resistant synthetic mesh or carbon fiber
122717 (author)2015-01-12
Hey, this is awesome! I was wondering if you could light it without the primer?
usefulinsight made it! (author)2014-11-11
I didn't include pics of the pot holder and such.
WARNING: This stove blew up on me with first try. Luckily it was not welded together and the pressure just blew it into 2 pieces saving my body from shrapnel. I did singe all facial hair though and got one of the biggest scares of my life. I was very scared to try again because I didn't know what went wrong. Logically, if pressure built up enough to explode, one would think there's not enough vent holes. I doubled them (not shown in pic) and tried again. Now it works. These things demand a lot of respect.
I should add that at first I added paint thinner to the stove but it wouldn't light. I shook as much out as I could and then add methyl hydrate. not sure if this was actually my problem or not. For one, paint thinner is petroleum based, just like regular gasoline. For two, who knows what concoction formed when I added the methyl hydrate after. As stated,I did empty the thinner as much as shaking the stove would empty it. I'm sure there was some residual left over when I added the hydrate. So I really don't know if the stove actually needed more venting or just less operator stupidity. In one of the posters pictures, there are a certain amount of vent holes and in another picture there are double the amount. The video and pics of the working stove seem to show the stove that has less holes(by way of counting the number of output flames). So I am still a little confused as to what really went wrong but bottom line is be very careful.
Furthermore, upon rereading the posters warnings,I realized I broke 1 if not 2 of them.
For 1, I was stupid enough to stand over the stove when first lighting it. If I would have listened to warnings then I may not have had to shave the singe off of my eyebrows.
2, it's possible I didn't add enough fuel originally. Which would break posters number 2 warning which days not to attempt to light a stove that is nearly out of fuel..
I'm just trying to spell every possibility out that may have contributed to my explosion..any insight is definitely welcome..by the way, awesome build man. It does work really nice and is so much lighter and smaller than what I was previously using. Thank you
Javin007 (author)usefulinsight2014-11-12
*heh heh* I'm glad you didn't loose any body parts that wouldn't grow back!
So there's a good number of places you could've had trouble.
1.) "I should add that at first I added paint thinner to the stove but it wouldn't light."
Bear in mind that not all "paint thinners" are made the same. Some are Mineral Spirits, others are Acetone, or in the worse case, some are turpentines (and now you're playing chemistry when you mix them with something else). So be absolutely sure that what you're using is "Methylated Spirits" or "Denatured Alcohol." Often it will even say "Marine Stove Fuel" on it. Its primary ingredient should be Ethanol (alcohol) with some Methanol (another, poisonous alcohol) added to "denature" it. Note that "Methylated Spirits" are NOT the same as "Mineral Spirits" (aka: "White Spirit" in the UK).
2.) "For one, paint thinner is petroleum based, just like regular gasoline."
This seems to be your primary problem. You most definitely do NOT want a petroleum based paint thinner (most likely Naptha, or Mineral Spirits). That will be very explodey, but worse still, you never quite know when it's going to go since it has a very touchy oxygen to fuel ratio.
3.) "In one of the posters pictures, there are a certain amount of vent holes and in another picture there are double the amount."
Yeah, I did numerous experiments with hole counts/sizes to see which would give the most consistent flame with the most efficient use of the fuel. The 8 larger holes (thumbtack) ended up working better than the 16 needle sized holes. They also clog less easily.
Back on the fuel, you mention using straight Methyl Hydrate. I don't know one way or the other if the off gassing from pure Methyl Hydrate is worse than the off gassing from Ethanol, but to be on the safe/disclaimer side, I would recommend using only fuels that specifically say "Marine Stove Fuel" or something along those lines.
I'm fairly certain your explosion came from the combination of the Mineral Spirits (assuming that's what you used) and the Methyl Hydrate. The Mineral Spirits are petroleum based, and come in 3 different "flammability" grades, with the most common consumer version being the least flammable. I assume it wasn't properly vaporizing before, and then having a small amount in your can and adding the Methyl Hydrate, you significantly lowered the flash point, allowing it to go boom.
Without question, avoid the "White Spirits" as they are not alcohol based. I would only feel safe using alcohol based fuels in this stove.
usefulinsight (author)Javin0072014-11-12
I just looked and the paint thinner I used was Mineral spirits. I will take your advice and use Methylated Spirits. I did try the 99.5 % pure Methyl Hydrate I had on hand but after some reading, I'm kind of scared of it now. Pretty nasty stuff. I'd much more prefer ethanol that is denatured with a smaller percentage of Methyl Hydrate.
Good to know about the holes. I assumed they were my biggest problem and therefore I doubled them for more, but after reading your reply, I realize my original hunch may have been more accurate (petroleum based fuel = explody). What I have working now seems pretty good though but maybe I'll make another with less holes again to experiment. Just won't use paint thinner this time. I think your right about why mine exploded. Especially considering yours worked with less holes. My paint thinner is mineral spirits and that = petroleum based. That just spells disaster. I feel so stupid. I hope others can learn from my mistake.
Thanks again. If I do anything else, I'll be sure to show you.
btw, here's some more pics. One of the stove packed away in my MSR alpine 2 cookset. Fits in there nice with 3 (2oz) bottles of fuel. The other is of the stove on it's own with flame in the dark.
Javin007 (author)usefulinsight2014-11-13
Sweet! That's a nice cook set! I'm actually going to be taking the stove that was made in this 'Ible camping this very weekend. It's slightly oxidized from use, and there's a little rust on the pins/rack, but other than that, it's still working as well as the day I made it (and that was 5 years ago!). So you can look forward to many years of use out of it!
And don't feel bad. I did mention that you could find the denatured alcohol "in the paint thinner section" of the store, so it's an easy mistake. At least you weren't like some other person (who will remain nameless - no, it wasn't me) who put straight-up gasoline in it and ended up with a fiery ball of OMG.
Thanks for the pics! It's always amazing to see other people building this stove. Where are you located so I can add you to my map?
Ontario, Canada.
jef400dread (author)2014-04-15
When I tried drilling the 1/4" holes in the wind guard, my bit ran all over the place. Even after drilling 1/8" pilot holes for the 16 staggered holes, I have 16 different looking 1/4" holes. Oh well. For me, the most difficult part of the build was getting the 8 "thumbtack" holes in the burner. I didn't attempt these holes until the 2 can bottoms were fitted together, perhaps that made it more difficult. Brass thumbtacks didn't stand a chance. I went through 2 push pins to get 8 holes. The first one in a C clamp did 3 holes before breaking. Changed to a nail that made a bigger hole for 4 and 5. Pushpin number 2 I figured out that if I rotated it as I applied pressure, it was making progress. It got to the point that I was sharpening the point of the second pushpin. Then, the pin was spinning within it's plastic handle assembly. Once I noticed that, I held that portion in place with some needle nose pliers...Finally. 8 holes.
As other commenters suggested, I JB welded bolts to the inside bottom of the wind guard to hold the rack pins. I also used the paper folding method to keep my marks evenly spaced. I could use some practice using my dremel to cut cans. Even when trying to focus on the "down" ribs of the large can, I found my dremel cut-off bit wondering off the path.
blue_phoenix (author)jef400dread2014-08-07
Regarding the thumbtacks, I took the old-fashioned brass kind, and crushed them in my needle-nosed pliers, so that the sides bent inward. Then with the thumbtacks gripped in the pliers, I put two fingers inside the can, one on each side of where the hole would poke through, and pushed the thumbtack through with a twisting motion from the outside. Worked really well (after going through the same frustration as the rest of you).
bishopfamily (author)2014-06-09
For my cooking stove all I have is a tin can slightly bigger than my stove cut about an inch taller than my stove then drilled in holes so it would be a windscreen, chimney, and pot stand. I also don't use a stand because the bottom of the tin can is enough protection that the ground doesn't burn.
keveldevel (author)2014-01-29
love it. read about it and 6 long hrs later I had my very own model just like yours. I did have to make a custom rack my pot was to slim for your design. I also made my wind guard a little taller. it works great. it really does. first try and I'm completely satisfied with it. it will be my sole cooking devise on our week long canoe trip. thanks man.
Javin007 (author)keveldevel2014-01-30
Awesome! I love to hear about people making it! Would also love to see pics!
gorth (author)2013-11-17
Good 'ible. Just a short note. Since you are using a pot rack with this setup you don't have to wait for the stove to heat up. Just put the pot on and don't waste the heat.
MrBuildalong (author)2013-10-06
I like your design so much I've started constructing my own kit. I'm looking forward to testing this bad boy out in the woods to see what it'll do. So far I've finished the penny stove and am about to do the rack pins and wind guard. Tally ho!
astral_mage (author)2013-08-31
agian harbor freight tools has them. dont buy the 10.00 dollar specail uill spend more in gas returning it. get thier 20 bock unit .
camping crazy (author)2013-08-28
I just built one of these I haven't tested it yet and all Ive built is the stove and measuring cup but the instructions are the best and easiest to follow!! Thank you so much for posting!!!!
brokenmedic (author)2013-02-27
Javin,
I read all the talk about MSDS sheets and changes folks have made to this great little life saver. I have come to believe most alcohols are dangerous and I have seen people drink liquid sterno on many occasions, well enough on that I will be making mine just like you show, simple is almost always better.
I am about to make my first "Improved Pocket Sized Camp Stove" and I give you 5/5 rating after seeing your video and puppy. I just might make a change to fit my needs and will send you pic's of the results as well as my puppy.
Almost a professional prepper I guess, retired from public safety and now a disaster services worker supporting government communications when they fail thru ham radio, our motto is "when all else fails".
Our people ( many are retired ) carry go kits and the heavy MRE's since we must be self reliant and show up in area's that may be devoid of all infrastructure, meaning we're on our own. Now old and gray, I'm gonna use the much lighter freeze dried meals so I want to heat my water with a "home brew" stove, not a $150 stove made in China.
Most of our people are volunteers on fixed incomes, so I hope to bring this to a training session to let everyone see how great your little stove works with mostly recycled can's. If it's ok with you I would like to send them a copy of the download so they can gather up what they need ahead of time.
I had everything on hand including Denatured alcohol and the same refried beans which I am using as dip for my chips, minus the METOH Kudo's!
Rob
btw, I am curious, why no fiberglass, smell or melting?
Javin007 (author)brokenmedic2013-02-28
Rob-
By all means, use it at your leisure!  I'd be proud to have the stove used in such a way.
The reason for no fiberglass is that it's simply not necessary.  In some stoves, the fiberglass supposedly helps vaporize the fuel, or "slows down" spills (neither advantage did I see in my tests).  In mine, I saw precisely zero improvement, but did find that it took up space in the can meaning I had to put less fuel in it, so got a shorter burn time per fill.  As you said, "simple is better."  I've seen and tested literally dozens of different designs of the penny stoves, and found that the absolute simplest model worked the best.
To be fair, there was ONE model that proved to give a very SLIGHT advantage.  It was almost identical but that the holes that are punched with thumbtacks here were instead drilled with a very tiny drill bit, on the top, at an angle that produced a "tornado" effect.
This was great if you wanted to quickly heat a single (thin) cup of water, and increased boil times by nearly a full 40 seconds on average.  Still, for all the extra work, I determined it wasn't nearly worth the effort, particularly in light of the fact that it would not heat a pan evenly if you were trying to cook fish (which is where this all started for me in the first place).
So yeah, long-story short (I tend to ramble) nothing goes inside the penny stove because there's no point in it.
cege (author)2013-02-19
THIS IS TERRIFFIC! THANK YOU!
kilber17 (author)2013-01-12
This Thing Is Awesome!!!!!
teaquack (author)2012-12-23
I don't get the rig, I'm finding it hard to make and even harder to use
shotgunshane (author)2012-12-22
can you explain the wind guard better? pics would be great! thank you!
shotgunshane (author)2012-12-21
it was kid of difficult building the actual stove from the two can lids, they kept tearing (yes the cans were tearing) but i got it to work on like the 8 try.
Best instructable i have ever seen, i am going to make multiple of these for natural disasters that come about. thank you very much!!!! :)
Ben_the_Sci_Kid (author)2011-02-22
what kind of alcohol is in the denatured alc.? my mom is a chemist so she can get me some without the poison!
it's methylated spirits in the uk fyi.
90%ethanol with 10% methanol to make it poisonous so no tax has to be paid on the ethanol.
thanks so much!
denatured
the natural impulse is to drink alcohol to get drunk
denatured it to mean drink this to get drunk and you will die
nuff said ?
About This Instructable
453,315views
1,051favorites
License:
More by Javin007:Home-Made Ghee (Long-term Butter Storage)The No-Weld Double-Barrel Smoker (and how to use it)How To: Capture Your Memories In Full 3D!
Add instructable to:
