Step 10Making the Penny Stove (Final Steps)
1.) Slide the top into the bottom piece. (Image 1)
2.) Very, very carefully, start pressing the two pieces together evenly, a little bit at a time. When it starts to get tight, you will find that at the top of some of the holes that were punched you will need to use a shim cut from the spare parts of the can (Image 2) to work the two pieces down. Again, do this very, very slowly, a very small amount at a time. Do not use a lot of pressure. If the two parts seem to be too hard to push together, simply wait for a few more seconds. The two cans will slowly stretch ever so slightly allowing you to eventually work them together. I cannot stress enough how delicate you have to be, making sure that all sides evenly go in tiny fractions of an inch at a time. Attempting to force them too quickly will make either one of the cans split, or one end will pop out of the bottom while the other end goes in too deep. Slow and steady here.
3.) Gently, slowly, and evenly press the cans together until the bottom is even with the curve in the top. (Image 3)
Notes:
- I say again, you do not want to sand the paint off of the top piece. As the paint heats up, it will actually act like "glue" and seal the top to the bottom piece the first time you use it.
- As said above, you also do not need to use glue to make this.
- Since this stove will not recieve ANY weight, it does not have to be reinforced, or otherwise made any stronger. (After its initial lighting, the paint on the inner can adhering to the outer can will still make it fairly sturdy.)
- Note that I did not use any fillers such as cloth, fiberglass, etc.
![Priming Wick for Alcohol Stove [and Pot Stand]](http://img.instructables.com/files/deriv/FK2/8VFR/GP7IFJ91/FK28VFRGP7IFJ91.SQUARE.jpg)
do i put it in before i connect the two pieces?
sorry if it's a dumb question
While 0.002 in. might seem small, it's enough to greatly simplifiy the assembly. Here are my calculations... http://www.editgrid.com/user/mwarren/Aluminum_can_walls
One other thing I've started doing that might account for it: after pouring fuel into that central hold, and covering it with the penny I wait a little longer before igniting it. That way anything I spilled evaporates off. That might have been the cause too.
I haven't had a detonation yet (fingers-crossed) but I had one tip over. The penny fell off and that central flame ignited. It was on a concrete patio so no harm was done, and it looked pretty cool. One nice long (about 2 foot) flame jet out of the middle that burnt out in 5-10 seconds.
I'll put some pictures up. I gave away my best ones at Christmas, but I'm determined pull together everything I've learned and make one more nice one just for me.
Thanks again, these have provided hours and hours of entertainment.
Christopher
I just went to the store and bought two cans of A&W root beer like in the instructions - maybe they will work better. Apparently not all cans are the same as I first tried two energy drinks from Aldi and could not cut them cleanly and then switched to two off brand tropical juice cans from Wal Mart and they cut easily with a razor blade but the the paint didn't glue the cans together. I am in North Carolina BTW to answer your question.
You need to read the instructions here very carefully. The holes punched in the cans with the thumb tacks and the holes punched in using the hole punch are very, very different things. Please read every step of the instructable and make sure you understand it completely before attempting ANY build. You're clearly reading something wrong that I couldn't possibly make any clearer.
If so, where do you put it in there?
[This is the first instructable about a Penny Stove that I've read, sooo...I'm not really sure what's goin' on with that part. Sorry. C: ]
The weight of the penny is perfect to act as a safety valve as the heat from the stove generates the vapor that burns. It also seals the hole for starting.
With the penny in place, a couple of tablespoons in the 'cup' around it heats the whole apparatus to start the alcohol liquid-to-vapor trick
It is this vapor that will allow a pop-can stove to burn for nearly an hour on a half-cup of denatured alcohol.
