Step 11Making the Measuring Cup
1.) There's no need to be too exacting here. Just set the small can next to the penny stove, and draw a line approximately the same height. (Image 1)
2.) Cut off the top (with the dremel, unless you're fortunate enough to own a large tube cutter) so it's close to even.
3.) Sand all of the edges of the cup so it's not sharp.
4.) "Pinch" the lip of the cup so it looks a bit like a spout (Image 2).
The measuring cup can be marked, though I just know by looking how much fuel I need to use in my stove. The ribbed lines around the edge can be used to figure out approximately how long the stove will burn through testing (it will be different for every stove).
I found that this cup was necessary, since the containers of fuel seldom want to pour smoothly, and I didn't feel like having a large fireball in my tent. (Yes, you can use this indoors, with the proper fuel and stability!)
![Priming Wick for Alcohol Stove [and Pot Stand]](http://img.instructables.com/files/deriv/FK2/8VFR/GP7IFJ91/FK28VFRGP7IFJ91.SQUARE.jpg)
Holes (jets) are in the top since this stove burns vapor. If you try to jet it in the bottom it will quickly become a fountain of nightmare-y OMG, if it will hold fuel at all! (also a very good reason NOT to over fill these things...) I have made them with both the outside can on the top and on the bottom with little difference noticed between the two.
If you don't use JB Weld, put your seam up so any gas that leaks out will create useful heat. If you are going to add the fiberglass wrap some use to help preheat make your seam at the bottom and hide it behind the fiberglass wick.
Also I reccomend carrying an extra so when johnny stumble foot wrecks your stove you can insult his mother and throw it at him instead of trying to choose between eating raw broccoli and rice or start that protective coating of pitch on your cook set.*
*yes wood guys, I know you can rub soap on 'em
