Pocket Sized Camp Stove (The Improved
Step 17Usage (Video)
Usage (Video)
1.) Remove rack from around stove.
2.) Remove lid/base, and empty contents (rack pins).
3.) Place lid/base upright on stable surface.
4.) Remove fuel cup and set aside.
5.) Remove stove/penny.
6.) If you created the optional hook tool, remove this.
7.) Place wind guard on top of lid/base.
8.) Insert rack pins through appropriate holes, and set them in their "nubs."
9.) Place stove (sans penny) into center of wind guard.
10.) Slowly add fuel to stove (either with fuel cup, or squirt bottle) by dumping fuel into the top of it and letting it drain.
11.) Dump small amount (will differ for each stove, experiment) of fuel into wind guard as primer.
12.) Add penny to stove, covering fuel hole.
13.) Place rack into rack pins.
14.) Light with flint striker over stove, or bring lighter near a side hole.
15.) Stove will take approximately 30-45 seconds to heat up.
16.) Use only stable flat-bottomed pan/bowl/cup to cook.
Note that if desired, the penny stove itself can be turned upside down and used to burn solid state fuels such as esbit fuel tabs.
Notes when using:
  • The pictures of the lit stove were taken in a dim room. Keep in mind that outdoors, or in bright light, you will often not be able to see the flame at all. Take care not to burn yourself.
  • Read the 2nd step's warnings.
  • Try to measure your fuel so it burns out just as you're done with it.
  • The stove can be extinguished by placing the inverted "measuring cup" over it, or blowing it out. Water will also quickly put out any alcohol fires. (Make sure the measuring cup has no fuel left in it.) Do not store the stove with fluid in it.
  • When primed, it can be started with a flint striker.
  • The thinner/smaller the utensils used to cook on it, the faster and hotter they will get. Have gloves handy.
  • If using this indoors, make sure you have a *very* stable place for it to sit where it will not get knocked over. Have a method for putting out the fire handy just in case.
  • If you cannot understand how to build it by reading these instructions, do not attempt to do so. You shouldn't be playing with fire.
The attached video shows how to unpack and use your new stove.
Enjoy!
Any comments, improvements, or any critiques are welcome!
39 comments
Jan 16, 2012. 8:48 PMcryophile says:
Awesome! It looks like this would come in handy if you were homeless.
Sep 27, 2011. 11:00 AMorion3 says:
Awesome stove! Just got mine finished. Instead of drilling holes for the rack pins, I JB welded small nuts to the bottom of the base can. After words, I was concerned that they might get in the way of the measuring cup once it was assembled but, it all fits well. Also, I used a 24 oz. tuna can for the base and riveted it to the lid instead of cutting the larger can down and JB welding together. I was a bet eager to try out the stove and didnt have any Denatured alcohol, so I used rubbing alcohol. (Not sure of the difference) I found the rubbing alcohol a bit hard to light at first (Hoping the Denatured alcohol works better). But I used a propane torch and soon got it blazing. Took a few minutes for it to settle down, then it started burning nicely. Had a problem with the fire staying lit for more then 10 minutes. (Again, could be the rubbing alcohol) I would then relight it with the torch again and it would take off again. I'm thinking the torch is heating up the alcohol in the can making it evaporate faster. All in all, A fantastic project and I plan on making more as gifts. A 10 out of 10!
Jan 5, 2012. 9:05 PM14kurbili says:
I've found that the best feul for any alcohol stove is methyl hydrate. it's sold as a gasline antifreeze for about $10 a gallon, and is something like 99.9% methyl alcohol. it works amazingly well compared to other feuls, and MEC even sells it as feul for their stoves, so you know it must be good!
Jan 7, 2012. 2:49 PM14kurbili says:
I just compared the MSDS sheets for methyl hydrate and denatured alcohol, and as it turns out, they both impose the same health risks. I'm not saying you're wrong about the dangers of using methyl alcohol, it's just that denatured alcohol isn't any better for you. now that i know the fuel I'm using isn't that great for me, i'll try to start using other types of less harmful alcohol. Thanks for the heads up!
Dec 25, 2011. 10:26 AMdontkillpenguins says:
can you use 70 percent alcohol
Sep 28, 2011. 8:15 AMorion3 says:
Awesome! Just the info I needed. This is a great build and is extremely well thought out. I will be heading to the store for denatured alcohol ASAP! I am getting started on number 2 today. I'm going to make my wind guard just a tad higher this time to more easily accommodate the nuts. I only went 1/2 inch higher then the stove last time. It fits but , just barely. I need to invest in one of those fancy side cutting can openers as well. I dremmeled the last lid off. It's passable but rough. By the way, the pot rack design, imo, is just Genius! Super strong and very sturdy! Thanks a lot for this great instructable . If I stumble across any more updates I'll post them here. \m/
Apr 29, 2011. 12:22 AMxUNMERITEDx says:
Great job!
Apr 18, 2011. 4:57 PMJRick3 says:
Do you really need the measuring cup or is it more for everything to fit nice inside when it is all packed up?
Jul 6, 2009. 11:08 PMpastprimitive says:
I like what you are trying to do. I happen to be starting a business that will be marketing these soda can stoves in stores. I thought you might find what I have done interesting. I noticed all the same design flaws with most soda can stoves as you. I took mine a bit further in the area of efficiency by using a rivet nut to completely seal off the container and using more holes that are smaller. Seems to be a better fuel to air mixture for efficient combustion. I think you will like what I did for priming. With my stove design it allows for a mere 1 ml or less of fuel to prime. I have found denatured alcohol to be the cleanest and hottest. Also as far as measuring fuel I use a 10 ml syringe I get at the drug store for .25 cents and a small 4 oz fuel bottle. Anyway the site is: www.keyholestoves.com Check it out. Hope it gives you some good ideas. Keep on inventing!
Apr 9, 2011. 1:06 AMjalspach says:
First of all fantastic instructable. I cant wait to build one this weekend.
Second, I know this ible has been up for a while so it may be too late to ask this but...
I notice in the ible you use the tacks to ouch 8 holes yet in the comments I see that you used the pin and drill press idea to punch more, smaller holes and it was more efficient. Should I stick to your instruction or go for the smaller holes?
The same goes for the idea of using a threaded stopper that I thought I read in the comments. Stick with the instruction or is it safer to switch to the rivetable thread?
Thanks again for such a wonderfully thought out instruct able. My son just crossed into boy scouts and will be doing a lot of hiking with his new troop. I this this would be a great project for us to work on...as long as this style of stove is permitted.
James
Apr 11, 2011. 10:25 AMjalspach says:
Thank you for the answers.
We actually did not get around to building it this weekend so hopefully over the next couple of nights we will.
We are both excited to see it go!
Who knows, maybe after this weekends backpacking trip, the whole troop will be building them ;-)
Thanks again!
Jul 9, 2009. 12:53 PMpastprimitive says:
Yeah that was what I found.
Jul 12, 2009. 12:46 PMSabata says:
I've found that a plain ol' sewing needle works quite well for making the holes. Hold it about 5-6mm from the tip with pliers or a hemostat otherwise the needle may bend and/or break. I liked to make about 2 dozen holes in my stoves and got some pretty decent burn times using very little fuel. Unfortunately I've misplaced my old stove notes and can't give any specifics. BTW, I had one of my very first alcohol stoves blow apart on me several years ago. Luckily, I had only a very small amount of fuel (about a teaspoon) in it for testing, it was on cement and I'd surrounded the stove with a barrier, just in case.
Jul 12, 2009. 3:14 PMpastprimitive says:
Here is what I have concluded about detonating stoves. I have yet to have this problem once. And I believe it comes from too large of holes or an uncapped fuel fill hole which will allow oxygen back into the stove which will result in detonation. If you don't have these things it's virtually impossible for the oxygen level to rise to the point of detonation inside the stove. Unless of course you found a way to force oxygen inside.
Jul 12, 2009. 6:42 PMSabata says:
Again, it's been several years since this happened so I'm going from memory here. I have a couple theories* but can't say for certain why the stove "popped." What I do know for sure is that the filler hole was closed off with a nut J-B Welded to the inside and a screw outside. Also, the holes were made with a small needle using the method I described above, so they definitely were not too large.
(*) Following some others' leads, I did not J-B Weld the two halves together. I also didn't bother to punch holes in the lower portion of the can as shown here almost halfway down the page.
Don Johnston's Photon Stove
I suppose that vapors and pressure built up but were not able to vent to the outer chamber and escape out the jets. Since the two halves were not epoxied together, they blew apart when the pressure got to a certain level.
Rather than only punching holes and trying the stove without glue to prove the pressure theory, I erred on the side of caution and punched holes and glued the stove as well.
Jul 7, 2009. 7:54 AMpastprimitive says:
I am glad to help. feel free to include the primer pan in the instructable as long as you give me some credit with a link to my site. I am not really after people who have time, desire, and interest in building the stoves themselves. So I am not too worried about it. I am marketing mostly towards physical retail locations and people who do not want to take the time to build. But thanks for the sensitivity. My secret weapons in producing awesome vent holes is a combination of 3 things. First I created a template by cutting out a bottom of a soda can right up against where it starts to bend inwards, and than cutting out the middle concave part. I than make 4 cuts up the inward wall to allow for expansion so it fits all the way down on the targeted soda can bottom. And than flange it out with a full can of soda. Then I create 24 holes. Here is the awesome simple part. I use sewing pins, the kind with the round nub of plastic, and than I snip off the tip so that it's about a half inch long. I then take this to a vice, other hard metal surface, and very carefully (as not to smash my fingers) I pound the non point end of the pin i just cut off. then I take this to my drill press and mount it in that with just about 1/8" sticking out. maybe a little more. The trick here is to put it between the teeth of the press, (Hence the pounding the non pointy-end flat, of course not too flat, we need strength) not the middle, as the middle typically will not accommodate such a small diameter shaft. Than you can go to town pushing it straight down into your target soda can, Hopefully it goes without saying... Don't turn on the drill press as you are doing this. And it will make beautiful small holes every time and without killing your thumbs. As far as the refueling issue, and exploding issue I have two solutions that I like. To avoid explosions I find that a rivet nut and a small thumb screw make a great fill hole. And the plus is that since you have a tight seal while running, and hopefully by now smaller holes:) combustion seems to have an impossible time happening in the stove itself. I haven't done a scientific study, but I believe the small jet holes for whatever reason just plain don't allow enough air in the stove at any given time to allow combustion as long as you have the fuel screw in when you light it. The only slightly dangerous experience I had was when I made my holes even smaller than what you saw, and the pressure built up too much and popped the top. I think it's that penny you use to seal your fuel hole, it just needs to be a tighter seal. You can pick up a rivet nut gun from harbor freight tools if you have one in your area for like $16-$25 bucks that includes aluminum rivets. I highly recommend the purchase. Such a handy tool. Now the refueling issue I believe has a simple solution. I think the real problem lies in not being able to transport your stove with fuel in it. Now of course I can't do that yet with my model either. but I am working on a that fits over the top of my stove, and puts a water-tight sel on it, effectively making it so you could top the stove off with fuel, cap it, pack it with you, and when you want to use it pull it out and light it up, burn as long as you want, and then blow it out, and recap it once cooled. Plus now you don't necessarily need a fuel bottle depending on trip length. My stove holds 2 oz of fuel and that gives about 20-40 minutes of burn time depending on lots of factors. So I find that more than enough time for me, but of course I could always make it an ounce or two bigger to extend the burn time.
Jul 7, 2009. 7:57 AMpastprimitive says:
Sorry, didn't catch the typo. I meant to say i am working on making a top, that will cap the stove off.
Feb 17, 2011. 6:51 PMtristin7612 says:
That was great, I think that I will have to try that out. My wife says I'm not aloud to see neat things like that because she knows that I will HAVE TO make it. Also love the cameo of the puppy.
Jul 9, 2010. 6:45 AMsabr686 says:
hey great stove, i think it's the best designed and functioning one I've seen around. I appreciate the work you put into developing it. I made one last night (took me a little longer than I thought, being the first time and all) and I can't wait for the JB to cure so I can fire it up. I put a very small notch in the bottom of the wind guard so the rack would be trained to hold the package shut tight. Just Dremel'd it. I guess that's a new word. You know what I mean. I also left about 3" of coat hanger onto the end of the rack to replace the extra bit of wire used for the handle, with a little triangle at the end for grip. Just a little personal modification. Well done, and thanks for the jumping off point! I love this kind of stuff, especially when it's well thought out and constructed.
Jul 9, 2010. 3:05 PMsabr686 says:
I will try, though I'm not real tech-y in that regard.
Aug 9, 2009. 10:47 PMtibbaryllis says:
I do not have any pictures with me but I've had luck with the refueling. In my designs you insert a needle in the bottom of the stove (such as a basketball needle) this needle fits through a hole in the bottom of the wind guard. Its connected to a long* piece of small tubing. **** For starters I recommend in the 5 foot range so you arnt in detonation range if you do it wrong. The end of this tube has a large syringe (like a basting/injection syringe) Fill the syringe with your alcohol and use that to initially fuel the stove (this is important, you dont want air trapped in the tube) then refill the syringe and push a little extra fuel in so as to clear any bubbles in the line. Now step away from the syringe and prime and light your stove. It should be burning like normal. When you want to add more fuel, done a leather glove (for safety) and SLOWLY SLOWLY SLOWLY SLOWLY inject more fuel from a safe distance. As long as you dont back off pressure from the injection system there is no air to cause the system to blow up, and the tube is not hooked to the syringe or the needle permanently so any sort of explosive reaction is likely to push the tube off. The only piece that needs to be permanently affixed is the needle into the stove bottom as so it cannot easily fall out and so that it does not create an extra inflow of air.
Extreme caution needs to be observed until you completely understand the refueling process as everything that can go wrong can go wrong. I've even had one instance where fire did manage to travel back up the tube (was a short tube) but the syringe had come loose so it effectively sprayed fire... user beware.. With a large enough injection needle (some turkey ones are pretty large) you can effectively refuel the can enough to keep it running for days... now you can mini slow cook roasts or make slow cooked soups in the woods... You can also use the technique you used to make your pot stand to make a rotisserie. Make them about.. 3x taller and form loops for a pin to go through - using this method I've made rotisserie dove breast and a mini morel kabob...
Enjoy
Jul 9, 2010. 6:50 AMsabr686 says:
Great idea. Obviously reserved for the "know-what-you're-doing" iblers. While we're at it, you could always put a valve between the syringe and the needle to act as a fuel cut-off, thus making it a bit safer. You could really take this a long way if you wanted to. I like the simplicity of the original, but add-ons are so cool, it's hard to resist!
Mar 13, 2010. 1:58 PMZeppelinfreak says:
that sounds like a good idea, but intead of injecting fuel could't you inject fuel initially to clear out air bubbles then have another line connected to the syringe in a container so it pulls of of that source?
Oct 31, 2009. 12:32 AM.happy.hippie. says:
i live in st. louis MO and i am planning on biking from stl to kansas city (and i guess back) and trying to spend as little money during the trip. so camping and using this stove would be amazing.  i'm building one this weekend
Nov 27, 2009. 6:52 PMjuanoporras says:
man let me tell you... this is awesome!!! I am going to build mine right away :P totally awesome. thanks for sharing.
Oct 20, 2009. 3:52 PMTarzanJr says:
at first i thought that the wind gaurd was much taller in the video then the picture of it sideways... when you are showing the holes you might want to show a comparison of the small medium and large cans after they have been cut so that they know what the end results look like.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
71
Author:Javin007
