Pocket Sized Camp Stove (The Improved
Step 5Optional Tools
Optional Tools
While you can get away with using your wire snips and Dremel to prep the Penny Stove's top, I find it's much easier to use some heavy duty scissors and a hole punch.
Note that I have discovered that while a hole punch does will against an aluminum can, it does not fair so well against tin cans.
RIP Hole Punch... Your life was short, but productive...
The wet or dry erase marker will be invaluable for drilling all the necessary holes in the correct spots, as well as cutting the pieces to the right sizes.
6 comments
Feb 4, 2010. 1:55 PMtelboyo says:
Note that I have discovered that while a hole punch does win against an aluminum can, it does not fare so well against ferro cans.
Jul 27, 2009. 10:26 AMwascogrrl says:
Just wondering why a wet/dry Erase? Wouldn't a sharpie work just as well?
Jul 28, 2009. 12:20 PMwascogrrl says:
LOL Yeah, I'm probably like you so now I TOTALLY understand the need for a wet/dry Erase pen!
Sep 25, 2009. 7:52 AMemerson.john says:
No need for a wet or dry erase marker. The same alcohol that you will use for fuel removes Sharpie ink like magic from a non-porous surface.
Sep 25, 2009. 10:11 AMMig Welder says:
BUT its a bit more easier to just wipe it with your finger than cleaning it with alcohol.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
71
Author:Javin007
