Now you may ask "What can do ALL of these things?"
Well the answer is pretty simple - a LASER.
In this Instructable, you will be creating a pocket-sized laser capable of doing all of the above things... and more. And the best part? It costs less that $10 to make. So even if you don't have an immediate use for it, you might as well build one and keep it with you - It may just save your life one day.
Remove these ads by
Signing UpStep 1The Parts
Here is a breakdown of the required parts:
- Laser Heatsink/Driver: $4.50 - (order from here: Aixiz Module Get the "650nm 5mw 12X30mm brass case")
- A Button: $1.00 - (you can order a fun one from All Electronics)
- A Casing: $1.00 - (pick whatever size you want from All Electronics - this is under "Enclosures")
- The Batter Holder: Free-$0.75 - (You can make your own or get this one)
- Laser Diode: Free (check out step 2 to learn how to get a free laser diode).
![[blog 2006-04-19] Laser-engraved Leathermen](http://img.instructables.com/files/deriv/FNZ/HPPQ/BAFEP27X1MZ/FNZHPPQBAFEP27X1MZ.SQUARE.jpg)
Blue and yellow? *drool* :p
What we humans call "light" is merely a teensy, tiny slice of the electromagnetic spectrum to which the rods and cones in our eyes respond. We only "see" wavelengths from about 400-700 nanometers.
"Light" is merely the term we give to visible radiation, but the public immediately thinks "radiation = bad" because of nuclear power and X-ray machines, etc. The (greatly simplified) main differences between "good" and "bad" radiation is the energy and frequency. X-ray and gamma radiation go fast enough to knock out bits of your DNA.
That's also why your microwave can't cause cancer, but they do an excellent job of vibrating water molecules....or transmitting your voice via a cordless telephone! Check the frequency on your cordless phone, then check the frequency of your kitchen microwave! If you're using a 2.4GHz phone, they're very, very similar. Every time you answer the phone, you're putting a microwave radiation transmission source RIGHT NEXT TO YOUR BRAIN!
Ironic footnote: One of the largest laser manufacturers in the world is Coherent from California. Their original name was "Coherent Radiation" because that's exactly what a laser is. They dropped "radiation" from their name because "radiation is bad" to the unwashed masses.
***** 5 stars!
