Pocket-Sized Do-it-all multi-tool Shiny Light (aka Laser) by icinnamon
This Instructable will show you how to create a pocket sized tool capable of doing almost anything! It can cut paper, light matches, set newspaper on fire, point out objects that are far away, save your life in a natural disaster, and can even be 100% waterproof.
Now you may ask "What can do ALL of these things?"
Well the answer is pretty simple - a LASER.
In this Instructable, you will be creating a pocket-sized laser capable of doing all of the above things... and more. And the best part? It costs less that $10 to make. So even if you don't have an immediate use for it, you might as well build one and keep it with you - It may just save your life one day.
Step 1: The Parts
One of the best aspects of the "Do-Anything" Tool is that it is so cheap! This entire project can be built for a minimum of $6.50!
Here is a breakdown of the required parts:
  • Laser Heatsink/Driver: $4.50 - (order from here: Aixiz Module Get the "650nm 5mw 12X30mm brass case")
  • A Button: $1.00 - (you can order a fun one from All Electronics)
  • A Casing: $1.00 - (pick whatever size you want from All Electronics - this is under "Enclosures")
  • The Batter Holder: Free-$0.75 - (You can make your own or get this one)
  • Laser Diode: Free (check out step 2 to learn how to get a free laser diode).
This first image is taken by KipKay...
Step 2: Obtaining a Free Laser Diode
It is actually very simple to obtain a free Laser Diode that could be sold for more than $250! These diodes range from around 100 to 300 mW in power, and emit light at 650-660 nm (red). Please note that this much power can INSTANTLY blind you if you don't know what you are doing. But if you finish reading this Instructable, you will be fine.
So to explain a free diode (without stealing it!), search Google Maps for a local PC Repair Shop. When a tech repairs a computer with a DVD burner and finds that the DVD burner has problems, he/she will usually replace the burner and then throw it out. Many people do not know that DVD burners use laser diodes... to... well... burn! So if you go to a local PC Repair Shop and ask nicely, you can probably get 5 or 6 DVD Burners for free!
But now you must learn how to extract the diode. This step isn't very hard, and is fortunately quite forgiving if you make a mistake.
STEPS:
  • Open the DVD Burner.
  • Pull out the tray
  • Remove the laser tray
  • Unscrew everything on the tray and cut away anything made of plastic
  • See the image below to identify the diode
  • Extract the diode and cut the heatsink away.
(I used pictures from other websites on this step because I'm bad at taking macro pictures :) )
Step 3: Laser Module
In this step, you will finish the laser module. You are going to have two options. They are:
  • Use an unregulated power supply. This will shorten the lifetime of the diode but make it much more powerful.
  • Use the supplied driver board. This will extend the lifetime of the diode but make it weaker. It also requires additional soldering/desoldering.
Option 1:
You should see three leads on the diode. Use the diagram below to solder a wire to the ground and positive leads.
Next, unscrew the Aixiz module in the middle. A sticker is covering the seam. Use a hammer and screwdriver to remove the laser diode that is already in place. Once removed, replace it with your new diode. Put the module back together and you are done!
Option 2:
Unscrew the Aixiz module in the middle. A sticker is covering the seam. Use a hammer and screwdriver to remove the laser diode that is already in place. A circuit board will be attached to the diode. Desolder the circuit board and put your new diode exactly where your old one was and solder it in place. Put it back in the Aixiz module and you are done!
Step 4: Solder it Together
Solder it all together using the schematics below. This is the easy part...
Step 5: Uses (aka "Why this is the "Do Anything Tool")
Here are some great uses for your laser:
  • Take it with you whenever you are hiking/backpacking/alone. There are quite a few reasons for this:
1) If an aggressive animal approaches, the very bright light will scare it away
2) If you get lost, this laser can shine for miles and miles (as in >100 miles!). At night, the beam is very visible. Just shine it in the sky to lead rescuers right to you.
3) This can light matches. If you don't have strike-anywhere matches and you need to start a fire, this laser can do it!
  • Put it in your pocket and forget about it. Why?
1) Let's say you are getting mugged. Or kidnapped. Or any other situation. Solution? Pull out your laser, expand the dot, and temporarily blind your attacker. And by temporarily, we mean you can blind him/her for hours. Now please note that this is highly NOT advised. You can get arrested for doing this... UNLESS it is self defense. So don't try it otherwise. There is a chance that it will PERMANENTLY blind you.
  • Use it for art. How?
1) You can cut objects out of black paper with this laser. You can also "drill" (aka burn) precise holes).
  • Have fun. Show it off. It can pop balloons, burn electrical tape, etc.
So what other item can you fit in your pocket that can do all of these things? A Swiss-Army Knife can't stop an attacker when he/she is more than a foot or two away. But a laser can. A GPS locater can't help you if nobody is watching your signal. But a laser will attract attention from 100s of miles away.
1-40 of 235Next »
damodder says: Mar 10, 2011. 9:36 PM
Can I do this with my blu-ray diode?
Sparrowhawk says: Nov 13, 2008. 7:05 PM
Just want to point out that this is no good as a rescue beacon. It seems a good idea but the beam is only visible when you're close to the end - get someone to shine it up and then look at it from 20 feet away, you'll see what I mean. I have both red and green lasers with visible beams and neither is visible from a distance unless you're looking along the beam.
_soapy_ says: Jan 7, 2009. 1:38 PM
A high powered green laser will scatter plenty off-axis. A red of the same power will be nearly invisible. The shorter the wavelength (the blue and violet end of the spectrum) the more scattering, and the more visible off-axis the beam will be, per mW.
3DMHuff says: Oct 17, 2010. 12:19 PM
That is why the sky is blue.
Sparrowhawk says: Jan 7, 2009. 3:09 PM
You'd have to have a pretty powerful laser to be visible sideways-on from a couple of miles away though, as it would need to be for use as a beacon. A 30mW green is much more visible than a 200mW red (roughly what this is) and even that's no good.
_soapy_ says: Jan 7, 2009. 4:31 PM
I don't know - at night, my 45mW green is visible from a very long way. It is visible on the underside of clouds. I should do some actual tests of this. I live in one of the few still-dark places in England, and I've got red, green and blue diode lasers. If I can find the 45mW one and fix it, I'll test it next to a 15mW red I've got (though that's a HeNe, not a diode, the wavelength in the red is very close to the same) and the blue ones are not yet played with PS3 laser diodes, so I'll have to review my notes to drive those properly. I could compare yellow as well, but that's only a sub-mW beam from a little HeNe. (Very expensive bit of kit, though!)
Sparrowhawk says: Jan 7, 2009. 6:53 PM
Yes the dot is visible from far, but not the beam if you're out to one side. Get someone to shine it up at the sky, walk away a short distance and see if you can see anything.
Blue and yellow? *drool* :p
Colonel88 says: Dec 22, 2009. 6:26 PM
Yeah Okay, So I cut away MOST of the electronics on the diode, I found it, but it is covered in metal. What do I use to cut it off SAFELY? What do I use? I have Dremel but Ih ave doubts about it...
hintss says: Jul 4, 2010. 5:40 AM
surface wire cutters, or desolder it
ANDY! says: Jan 29, 2010. 11:14 PM
i used pliers. may the forcebe with u.
ned98 says: Mar 31, 2010. 6:17 AM
The link for the laser is broken. This one is correct: http://www.mfgcn.com/id2.html
Vulcanator says: Feb 15, 2010. 6:39 PM
if i was mugging you a shiny red light is totally going to scare me away. this laser wouldn't blind anything with a widened beam. the purpose of a laser is a concentrated light beam. when you take away that concentration it essentially becomes a LED.
bylerfamily says: Feb 21, 2010. 5:06 AM
The purpose of a laser is to provide a concentrated light beam,yes.But,even if you widen the beam the light still will not spread out quickly like an LED.A laser concentrates the light no matter how big the dot.
disturbedreaper says: Feb 17, 2010. 1:40 PM
DON'T LOOK AT THE BEAM IT CAN INSTANTLY BLIND YOU IN UNDER A SECOND AT THIS POWER that being said if you just flash this by their eye it will be enough to almost certainly permanently damage their vision
_Scratch_ says: Jan 17, 2010. 10:08 AM
what would happen if you used a 75W laser diode?
disturbedreaper says: Feb 17, 2010. 1:45 PM
it would probably be to weak to burn
loorJackal says: Jan 19, 2010. 9:01 AM
can you use the diode from a orignal xbox??
disturbedreaper says: Feb 17, 2010. 1:42 PM
probaly not thaey would most likey be infared which we cant see and since it only reads the discs and wont be that powerful
Colonel88 says: Nov 11, 2009. 5:02 PM
Cool, I'm goinng to make one into an Altoids tin when i can.
Nicola Tesla says: Mar 19, 2009. 4:51 AM
i heard that they are invisible
555mst555 says: Sep 6, 2009. 7:34 AM
only 808nm lasers.....a.k.a. infra red laserd
covey12 says: Apr 6, 2009. 4:37 PM
lol, no the radiation is invisible, obviously becuase you cant see radiation
LVLaserTech says: Apr 14, 2009. 7:11 AM
Actually, radiation is all you can see.
What we humans call "light" is merely a teensy, tiny slice of the electromagnetic spectrum to which the rods and cones in our eyes respond. We only "see" wavelengths from about 400-700 nanometers.
"Light" is merely the term we give to visible radiation, but the public immediately thinks "radiation = bad" because of nuclear power and X-ray machines, etc. The (greatly simplified) main differences between "good" and "bad" radiation is the energy and frequency. X-ray and gamma radiation go fast enough to knock out bits of your DNA.
That's also why your microwave can't cause cancer, but they do an excellent job of vibrating water molecules....or transmitting your voice via a cordless telephone! Check the frequency on your cordless phone, then check the frequency of your kitchen microwave! If you're using a 2.4GHz phone, they're very, very similar. Every time you answer the phone, you're putting a microwave radiation transmission source RIGHT NEXT TO YOUR BRAIN!
Ironic footnote: One of the largest laser manufacturers in the world is Coherent from California. Their original name was "Coherent Radiation" because that's exactly what a laser is. They dropped "radiation" from their name because "radiation is bad" to the unwashed masses.
DrPizza777 says: Aug 28, 2009. 7:56 PM
Actually, it is actually bad for you if the Radio Frequency (RF) Radiation gets to your senses, particularly eyes and ears. That is why the signal is only sent and recieved from the back of your cell phone. if it trancieved everywhere, the radiation would cause some problems. The microwave does use some power, but it has a small frequency. it would evaperate the water in you, leaving ash. if the current was high enough.
PsyWasabi says: Aug 8, 2009. 5:48 PM
Lets just point that you are not literally "cooking" your brain... A kitchen microwave is far more powerful, in question of energy... .. Sorry for the bad English, I am a Brazilian, and i still have some grammatical errors in my writings... :)
Owzcarde says: Apr 16, 2009. 11:23 AM
now THAT was an explenation.
smeddles says: Apr 19, 2009. 11:28 PM
amen to that!
Briguy9 says: Jul 16, 2009. 7:03 PM
I third that
raykholo says: Jul 17, 2009. 9:26 PM
and i quarter it... i quadruple it? idk lol
3DMHuff says: Oct 17, 2010. 12:06 PM
That would be fourth. I'm fifth. The person after me could be sixth if they agree. If not, it would be the one after them, if they agree. That is, if my math is right.
dmhjah says: Mar 27, 2011. 1:45 PM
Where could buy get a laser diode? No electronic stores to get a free laser from.
K1LLZ U says: Aug 27, 2009. 7:45 AM
dmhjah says: Aug 9, 2009. 7:30 AM
Hi, How do you orient the diode (since it a circle) so that you know where + and - are? Is the circuit board in the Aixiz the driver? Thanks David
sukinmaru says: Jul 23, 2009. 3:01 PM
I need to learn how to build a driver circuit so I don't destroy the diode
Kopolis777 says: Apr 20, 2008. 8:23 AM
can you put in some led's to make a flashlight?probably a separate switch for the light (so you don't burn what your looking at).=Þ
raykholo says: Jul 17, 2009. 9:29 PM
yep, check out the KipKay instructable for how to do just that with a maglite...
Ian01 says: Apr 30, 2009. 3:19 PM
That is a good idea; it increases the usefulness of the device. :)
Briguy9 says: Jul 16, 2009. 7:15 PM
one word: cool (that was three words. Well I guess i'm the exception that breaks the rule)
***** 5 stars!
Liberty92 says: Oct 16, 2008. 3:12 PM
the prongs you get out of the DVD burner are no where near that long, its annoying
Opalinus says: Jan 2, 2009. 11:17 AM
No of course not. But with a piece of cable you can solve the "problem" ;-)
1-40 of 235Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
