3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket-Sized Do-it-all multi-tool Shiny Light (aka Laser)
This Instructable will show you how to create a pocket sized tool capable of doing almost anything! It can cut paper, light matches, set newspaper on fire, point out objects that are far away, save your life in a natural disaster, and can even be 100% waterproof.
Now you may ask "What can do ALL of these things?"
Well the answer is pretty simple - a LASER.
In this Instructable, you will be creating a pocket-sized laser capable of doing all of the above things... and more. And the best part? It costs less that $10 to make. So even if you don't have an immediate use for it, you might as well build one and keep it with you - It may just save your life one day.
Step 1The Parts
The Parts
One of the best aspects of the "Do-Anything" Tool is that it is so cheap! This entire project can be built for a minimum of $6.50!
Here is a breakdown of the required parts:
  • Laser Heatsink/Driver: $4.50 - (order from here: Aixiz Module Get the "650nm 5mw 12X30mm brass case")
  • A Button: $1.00 - (you can order a fun one from All Electronics)
  • A Casing: $1.00 - (pick whatever size you want from All Electronics - this is under "Enclosures")
  • The Batter Holder: Free-$0.75 - (You can make your own or get this one)
  • Laser Diode: Free (check out step 2 to learn how to get a free laser diode).
This first image is taken by KipKay...
235 comments
1-40 of 235next »
Mar 10, 2011. 9:36 PMdamodder says:
Can I do this with my blu-ray diode?
Nov 13, 2008. 7:05 PMSparrowhawk says:
Just want to point out that this is no good as a rescue beacon. It seems a good idea but the beam is only visible when you're close to the end - get someone to shine it up and then look at it from 20 feet away, you'll see what I mean. I have both red and green lasers with visible beams and neither is visible from a distance unless you're looking along the beam.
Jan 7, 2009. 1:38 PM_soapy_ says:
A high powered green laser will scatter plenty off-axis. A red of the same power will be nearly invisible. The shorter the wavelength (the blue and violet end of the spectrum) the more scattering, and the more visible off-axis the beam will be, per mW.
Oct 17, 2010. 12:19 PM3DMHuff says:
That is why the sky is blue.
Jan 7, 2009. 3:09 PMSparrowhawk says:
You'd have to have a pretty powerful laser to be visible sideways-on from a couple of miles away though, as it would need to be for use as a beacon. A 30mW green is much more visible than a 200mW red (roughly what this is) and even that's no good.
Jan 7, 2009. 4:31 PM_soapy_ says:
I don't know - at night, my 45mW green is visible from a very long way. It is visible on the underside of clouds. I should do some actual tests of this. I live in one of the few still-dark places in England, and I've got red, green and blue diode lasers. If I can find the 45mW one and fix it, I'll test it next to a 15mW red I've got (though that's a HeNe, not a diode, the wavelength in the red is very close to the same) and the blue ones are not yet played with PS3 laser diodes, so I'll have to review my notes to drive those properly. I could compare yellow as well, but that's only a sub-mW beam from a little HeNe. (Very expensive bit of kit, though!)
Jan 7, 2009. 6:53 PMSparrowhawk says:
Yes the dot is visible from far, but not the beam if you're out to one side. Get someone to shine it up at the sky, walk away a short distance and see if you can see anything.
Blue and yellow? *drool* :p
Dec 22, 2009. 6:26 PMColonel88 says:
Yeah Okay, So I cut away MOST of the electronics on the diode, I found it, but it is covered in metal. What do I use to cut it off SAFELY? What do I use? I have Dremel but Ih ave doubts about it...
Jul 4, 2010. 5:40 AMhintss says:
surface wire cutters, or desolder it
Jan 29, 2010. 11:14 PMANDY! says:
i used pliers. may the forcebe with u.
Mar 31, 2010. 6:17 AMned98 says:
The link for the laser is broken. This one is correct: http://www.mfgcn.com/id2.html
Feb 15, 2010. 6:39 PMVulcanator says:
if i was mugging you a shiny red light is totally going to scare me away. this laser wouldn't blind anything with a widened beam. the purpose of a laser is a concentrated light beam. when you take away that concentration it essentially becomes a LED.
Feb 21, 2010. 5:06 AMbylerfamily says:
The purpose of a laser is to provide a concentrated light beam,yes.But,even if you widen the beam the light still will not spread out quickly like an LED.A laser concentrates the light no matter how big the dot.
Feb 17, 2010. 1:40 PMdisturbedreaper says:
DON'T LOOK AT THE BEAM IT CAN INSTANTLY BLIND YOU IN UNDER A SECOND AT THIS POWER that being said if you just flash this by their eye it will be enough to almost certainly permanently damage their vision
Jan 17, 2010. 10:08 AM_Scratch_ says:
what would happen if you used a 75W laser diode?
Feb 17, 2010. 1:45 PMdisturbedreaper says:
it would probably be to weak to burn
Jan 19, 2010. 9:01 AMloorJackal says:
can you use the diode from a orignal xbox??
Feb 17, 2010. 1:42 PMdisturbedreaper says:
probaly not thaey would most likey be infared which we cant see and since it only reads the discs and wont be that powerful
Nov 11, 2009. 5:02 PMColonel88 says:
Cool, I'm goinng to make one into an Altoids tin when i can.
Mar 19, 2009. 4:51 AMNicola Tesla says:
i heard that they are invisible
Sep 6, 2009. 7:34 AM555mst555 says:
only 808nm lasers.....a.k.a. infra red laserd
Apr 6, 2009. 4:37 PMcovey12 says:
lol, no the radiation is invisible, obviously becuase you cant see radiation
Apr 14, 2009. 7:11 AMLVLaserTech says:
Actually, radiation is all you can see.
What we humans call "light" is merely a teensy, tiny slice of the electromagnetic spectrum to which the rods and cones in our eyes respond. We only "see" wavelengths from about 400-700 nanometers.
"Light" is merely the term we give to visible radiation, but the public immediately thinks "radiation = bad" because of nuclear power and X-ray machines, etc. The (greatly simplified) main differences between "good" and "bad" radiation is the energy and frequency. X-ray and gamma radiation go fast enough to knock out bits of your DNA.
That's also why your microwave can't cause cancer, but they do an excellent job of vibrating water molecules....or transmitting your voice via a cordless telephone! Check the frequency on your cordless phone, then check the frequency of your kitchen microwave! If you're using a 2.4GHz phone, they're very, very similar. Every time you answer the phone, you're putting a microwave radiation transmission source RIGHT NEXT TO YOUR BRAIN!
Ironic footnote: One of the largest laser manufacturers in the world is Coherent from California. Their original name was "Coherent Radiation" because that's exactly what a laser is. They dropped "radiation" from their name because "radiation is bad" to the unwashed masses.
Aug 28, 2009. 7:56 PMDrPizza777 says:
Actually, it is actually bad for you if the Radio Frequency (RF) Radiation gets to your senses, particularly eyes and ears. That is why the signal is only sent and recieved from the back of your cell phone. if it trancieved everywhere, the radiation would cause some problems. The microwave does use some power, but it has a small frequency. it would evaperate the water in you, leaving ash. if the current was high enough.
Aug 8, 2009. 5:48 PMPsyWasabi says:
Lets just point that you are not literally "cooking" your brain... A kitchen microwave is far more powerful, in question of energy... .. Sorry for the bad English, I am a Brazilian, and i still have some grammatical errors in my writings... :)
Apr 16, 2009. 11:23 AMOwzcarde says:
now THAT was an explenation.
Apr 19, 2009. 11:28 PMsmeddles says:
amen to that!
Jul 16, 2009. 7:03 PMBriguy9 says:
I third that
Jul 17, 2009. 9:26 PMraykholo says:
and i quarter it... i quadruple it? idk lol
Oct 17, 2010. 12:06 PM3DMHuff says:
That would be fourth. I'm fifth. The person after me could be sixth if they agree. If not, it would be the one after them, if they agree. That is, if my math is right.
Aug 9, 2009. 4:38 PMdmhjah says:
Where could buy get a laser diode? No electronic stores to get a free laser from.
Aug 27, 2009. 7:45 AMK1LLZ U says:
Aug 9, 2009. 7:30 AMdmhjah says:
Hi, How do you orient the diode (since it a circle) so that you know where + and - are? Is the circuit board in the Aixiz the driver? Thanks David
Jul 23, 2009. 3:01 PMsukinmaru says:
I need to learn how to build a driver circuit so I don't destroy the diode
Apr 20, 2008. 8:23 AMKopolis777 says:
can you put in some led's to make a flashlight?probably a separate switch for the light (so you don't burn what your looking at).=Þ
Jul 17, 2009. 9:29 PMraykholo says:
yep, check out the KipKay instructable for how to do just that with a maglite...
Apr 30, 2009. 3:19 PMIan01 says:
That is a good idea; it increases the usefulness of the device. :)
Oct 14, 2009. 7:43 AMBriguy9 says:
one word: cool (that was three words. Well I guess i'm the exception that breaks the rule)
***** 5 stars!
Oct 16, 2008. 3:12 PMLiberty92 says:
the prongs you get out of the DVD burner are no where near that long, its annoying
Jan 2, 2009. 11:17 AMOpalinus says:
No of course not. But with a piece of cable you can solve the "problem" ;-)
1-40 of 235next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:icinnamon
