3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket-Sized Do-it-all multi-tool Shiny Light (aka Laser)
Step 3Laser Module
Laser Module
In this step, you will finish the laser module. You are going to have two options. They are:
  • Use an unregulated power supply. This will shorten the lifetime of the diode but make it much more powerful.
  • Use the supplied driver board. This will extend the lifetime of the diode but make it weaker. It also requires additional soldering/desoldering.
Option 1:
You should see three leads on the diode. Use the diagram below to solder a wire to the ground and positive leads.
Next, unscrew the Aixiz module in the middle. A sticker is covering the seam. Use a hammer and screwdriver to remove the laser diode that is already in place. Once removed, replace it with your new diode. Put the module back together and you are done!
Option 2:
Unscrew the Aixiz module in the middle. A sticker is covering the seam. Use a hammer and screwdriver to remove the laser diode that is already in place. A circuit board will be attached to the diode. Desolder the circuit board and put your new diode exactly where your old one was and solder it in place. Put it back in the Aixiz module and you are done!
6 comments
Jan 19, 2010. 9:01 AMloorJackal says:
can you use the diode from a orignal xbox??
Feb 17, 2010. 1:42 PMdisturbedreaper says:
probaly not thaey would most likey be infared which we cant see and since it only reads the discs and wont be that powerful
Aug 9, 2009. 7:30 AMdmhjah says:
Hi, How do you orient the diode (since it a circle) so that you know where + and - are? Is the circuit board in the Aixiz the driver? Thanks David
Oct 16, 2008. 3:12 PMLiberty92 says:
the prongs you get out of the DVD burner are no where near that long, its annoying
Jan 2, 2009. 11:17 AMOpalinus says:
No of course not. But with a piece of cable you can solve the "problem" ;-)
Jul 16, 2009. 7:11 PMBriguy9 says:
now that's thinking outside the burner, lol.
Feb 2, 2009. 2:58 PMskatepark13 says:
you should add a diagram of the two processes
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:icinnamon
