3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket-Sized Fishing Rod and Reel
I love to go fishing, it is fun, and it can be very exciting; one can go fishing with a group of friends or the family. Whether you are camping, or just on a day trip, fishing is a great way to pass the time. As Doug Larson said, "If people concentrated on the really important things in life, there'd be a shortage of fishing poles."
However, conventional fishing poles are long, fragile, and hard to carry, or otherwise transport. This Instructable will show you how to construct a fishing pole, complete with a reel, that will fit nicely in your pocket. You can keep it handy, and go fishing any time water is nearby.
Step 1Materials
Materials
  • last photo ←
These are the materials you will need for your fishing pole:
  • A Telescoping Radio Antenna - This will be used for the pole part of the pole
  • A Pen - One of the cheap kind you get for free at hotels or wherever
  • A Small Binder Clip - The smallest one you can find that will clip over the barrel of the pen
  • Three Very Small Washers - Again, smaller is better
  • Some Thin Wire - The length is not important, this will be used just to attach stuff
  • One Thin Bolt - This should be as long as the distance between the handles on the binder clip and thin enough to fit through the holes in the...
  • Four Medium Sized Washers - Large enough to cover the round parts on the top of each binder clip handle
  • Two Nuts - Square nuts are better than hex nuts, but hex nuts will work fine. These must screw onto the bolt.
  • One Small Nail - Any short, fairly thick piece of metal will work, however
  • Super Glue - Obviously, this is used to attach things
  • Hot Melt Glue - This is used to attach parts to other parts as well
  • Fishing Line - A very critical part for any fishing pole
  • A Swivel - A small, rotating metal clip used to attach the hook
  • A Hook - Used to catch the fish
  • Optional: A Worm
If this list is a tiny bit confusing, take a look at the pictures , they are worth 1000 words each.
68 comments
1-40 of 68next »
Feb 11, 2012. 3:20 PMbass pro says:
This is a great tutorial. Easy to follow and a clear step by step instructions. Thanks.
Aug 21, 2011. 9:36 AMdoublequick says:
a stronger antenna can be procured by going to the junk yard and buying one from a junked car
Aug 6, 2011. 4:36 PMyaly says:
Did anyone catch any fish if yes please pm me so i can make one to use when at the north coast there is a fishing treasure there.
Jun 7, 2011. 1:44 AMvektor says:
One question. When reeling, the bolt turns but it does not remain in one place. it moves to one side and stops once it comes in contact with the side of the clip. Please explain what i have done wrong and correct me.
Aug 6, 2011. 4:33 PMyaly says:
you need two more nuts to secure the two bolts that were glued together between them or/and add glue.
Jun 18, 2011. 11:25 AMGawane88 says:
thanks so much!
I'll see if i can find radio shack.
thanks again!
Aug 2, 2011. 8:17 AMAkask says:
Why can't you just glue the washer to the pole?
Jul 22, 2011. 10:16 AMsculptur says:
istead of hot glue or super glue wouldnt jb weld be much stronger and last longer?
Jan 1, 2011. 5:48 PMArc Trooper 5555 says:
I made my own version using the pen ink cartridge instead of a radio antenna.
Jun 29, 2011. 6:22 PMCaseBoy says:
wouldn't the rod be very short
Mar 20, 2011. 3:44 PMbruleyer says:
i actally think thats a smarter idea
May 29, 2011. 7:41 PMGawane88 says:
Whare do you get the radio antenna?
cool fishing rod though.
Jun 4, 2011. 8:55 AMtrainz222 says:
Radio shack, but if you cant find a single one buy a cheap or second hand radio and screw off the antenna
Jun 18, 2011. 11:20 AMGawane88 says:
thanks so much!
I'll see if I can find radio shack but if i cant just buy a cheap hand radio like you said.thanks again though!
Feb 19, 2010. 6:09 PMxadevox says:
How do you cast?
Jul 29, 2010. 12:28 PMphanjonathanm says:
im guessing you just puul it out and throw it O.o
May 17, 2011. 10:47 AMalways2theleft says:
thats what she said
Mar 20, 2011. 3:43 PMbruleyer says:
well i was just wondering have u actually tried this wont the antena bend
Dec 19, 2010. 2:58 PMaeray says:
I think you should make an 'able just about the palomar knot itself. It is extremely strong, little-known and underutilized. I use it when fishing for steelhead and sturgeon.
Nov 12, 2010. 10:47 AMMcGyver2 says:
Excellent Idea with this. Although I am against editing this one myself with just about everything, would it be prehaps possible to use many diferent sizes of PVC pipe for extra strength, yet still being portable?
Jul 23, 2010. 11:08 AMRobot Lover says:
I think this is a great idea but, I think that the line would snap because of the threads on the screw that holds the reel together
Apr 25, 2010. 9:57 AMpogoman12345 says:
this is pretty cool but there is already a mini pen fishing rod with telescoping rod and fully functional reel, but im sure that you already knew about it (Hint: its made by coleman)
Mar 18, 2010. 7:01 PMnorthernmagnet says:
 ok so couldent i just use one of the teloscopc pens (sorry for my spelling)
and find a way to make a reel?
Mar 7, 2010. 12:31 PM11richie21 says:
 lol u can make this in an office and fishing for fish in your desk aquarium jk that would be messed
Jan 29, 2010. 9:06 AMThe_DonuT says:
I made a simular mini rod and it works gr8 , thx for the idea
Jan 20, 2010. 8:48 PMDude567 says:
 okieman has a good point, wouldn't any fish capable of applying a force higher than the poles breaking strength destroy the pole? Couldn't you use something with more give?
Jan 17, 2010. 12:50 PMzipzapper859 says:
how far did you push the antenna in
Nov 18, 2009. 7:22 AMLokisgodhi says:
 They used to make low end fishing rods out of telescoping steel and aluminum back in the 1930-40s, so there's no problem with this concept.
I think that using actual guides and wrapping and epoxying them on the antenna would greatly improve this. Cut off the tip and replace it with an actual rod tip that fits the end's diameter. Then hot melt glue it and wrap it as well. That's what's done on real rods.
The reel needs a serious redesign.
Maybe a threaded insert in the end of the handle so you can screw in a threaded piece of steel with an L bend. Mount a spool made out of an old small diameter sewing thread thread with two body washers epoxied on to the ends.  Make sure it's in line with the guides.
www.shopchampiontrailers.com/prodinfo.asp
Nov 1, 2009. 4:19 AMminhazwaris says:
 how can you cast?
Jul 14, 2009. 4:08 PMpdub77 says:
Not to be negative, but wouldn't a fish of any decent size bend the antenna?
Sep 27, 2009. 1:05 PMmo5 says:
unless your fishing for minnos
Jul 19, 2009. 10:45 PMbrowncar says:
yeah I was thinking of a design for a fishing pole myself and thought the same thing that an antenna wouldn't work too well. Maybe a dowel rod or metal rod would be better.
Jul 20, 2009. 1:49 PMpdub77 says:
How about some telescoping bamboo? Not sure where to get something like that other than making it, but bamboo is strong and can be made to telescope. Obviously we've all seen bamboo poles before so this isn't new. If you can't get pieces that will telescope maybe just some pieces that will fit together and when broken down attached together with some rubber bands or a velcro cable wrap. Just one thought.
Jul 20, 2009. 4:15 PMbrowncar says:
Yeah I was thinking dowel rods with metal ends that would screw together. I just haven't thought of the pieces yet entirely . But bamboo would work if you could find the pieces like your describing . It would be lightweight.
Aug 22, 2009. 8:05 PMcdousley says:
i have been trying to solve the problem ind i realized it dose not need to be a fishing ("pole") im in the early stages of an Altoids tin fishing device
Aug 23, 2009. 10:49 AMpdub77 says:
Let me know when you post it. I'm intrigued.
Jan 15, 2010. 3:45 PMcdousley says:
sorry bout the late reply it needs a little sanding but ill post pictures
Jan 15, 2010. 5:32 PMpdub77 says:
Do so.  I will be all ears.  (so to speak.)
Jan 16, 2010. 11:14 AMcdousley says:
im gonna post it today when i find my laptop bag with my memory card it dosent have line yet but it works
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:Toglefritz
I am an undergraduate student at the University of Wisconsin - Madison. I am majoring in engineering mechanics and astronautics with a certificate in technical communication.
