milli-AMP!
Product pitching aside, this is a pretty neat project for somebody with beginner's electronics skill that can follow a schematic. I will state now that the circuit is not of my own design, but is a modified Little Gem Mk II circuit from runoffgroove.com. I would recommend checking out the site for some other pretty cool music-related schematics. Even though the circuit is not mine, the design of the enclosure and the charging circuit is of my own creation.
The milli-AMP uses a bridged ML386N-3 amplifier circuit to produce in the neighborhood of two watts output power. It runs of a rechargable 9 volt battery, which provides about an hour of full volume play per charge. At two watts, the milli-AMP is more powerful than any commercially available amp (that I know of) of its size; its size being a very pocketable 2.25 by 3.5 by 1 inches (roughly). Volume is controlled by the volume pot on the guitar, and this adversly controls distortion as well. For an idea of what it sounds like, see the last step of this instructable.
Remove these ads by
Signing UpStep 1Parts and Pieces
Perf board: PC-1
1/4" Mono Jack: PHJ-S
12.5 VDC Wall Transformer: DCTX-1285
2.1 mm Coax Power Jack: DCJ-21
2.1 mm Coax Power Plug: DCSID
9 Volt Battery Snaps: BST-3
Black Plastic Case: 1951-MSBK
SPDT Toggle Switch: MTS-542
Miniature Full Range Speaker: SK-408
9v 250 mah NiMh Battery: NMH-925
LM386 Amp: LM386N
500 ohm Trim Pot: TPS-500
LM317 Volt Regulator: LM317T
Also needed:
MPF102 Transistor: Radioshack part# 276-2062
BC327 Transistor: I had one of these lying around. An equivalent transistor can be substituted
10 ohm, 10K ohm, 1.5M ohm, 240 ohm, 1.5K ohm, 470 ohm Resistors: Scavenged, or purchased from Radioshack/ All Electronics.
0.22 uf, 100 uf 16v, 10uf 16v (x2), 0.05 uf, 1000 uf 25v capacitors: Scavenged, or purchased from Radioshack/ All Electronics.
Hookup wire
Case for the charger circuit: I used a case from an Ipod Nano.
A note about some of the parts: The speaker listed is the only one i would recommend for this project since it has a resistance of 8 ohms (Nothing lower should be used) and can handle 3 watts. It is also about 1.5 inches wide. Unless you can find something that meets these specs, stick with the speaker listed. Also, I cannot guantee you will receive LM386N-3 amplifiers. The last number after the dash signifies power output level, with 1 being the weakest and 4 being the most powerful. While different amplifiers will lead to different performance, as long as they both have the same last digit, they can be wired into the circuit without modification.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-1126
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-1062
The second one is larger, so you eould sacrifice portablility, but is better for bass. The second one is smaller, but still larger than the speaker i used in this project.
This would be a great mini amp for me because I play the electric guitar, 24/7 if I could.
NIce Instructable
Good work, and thanks for sharing.
You're welcome.
Nice idea, though.
Make an ible when you build it...I'd like to see it...no one else has the patience to try out this chip because they are so used to 386s.
If you need the NJM2073 chip I can mail a few to you if you want.
I meant something totally different. I meant parallel. The BTL configuration just means that it has double the power. In fact, I was using one as a preamp.
