3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Sized Lantern
Step 4Finishing Up:
Finishing Up:
Slowly pour in your Lamp Oil, Kerosene, Vegetable Oil, whatever, making sure not to spill any. Screw on the lid with the wick in it. The wick should be long enough to where it's resting on the bottom of the jar, but no so long that it curls up.
Make sure you don't overfill the jar. I usually don't fill more than about halfway and it lasts plenty of time.
4 comments
Oct 14, 2010. 3:19 AMkube60 says:
There used to be a show when I was a kid called Mr. Wizard's world. In one episode, he poured some veg oil into a dish, tied a piece of string to a nut to weight it and lit the string. Instant candle. Veg oil most certainly will work. You can even run a car on it.
Apr 15, 2010. 10:24 AMmarlton2010 says:
Vegetable Oil not work for fire, but lamp oil, it work!!
Apr 24, 2010. 7:37 PMfascist says:
Vegetable oil certainly will work. I have made similar lamps and have tested them with both canola and olive oils. Canola is just a modified low acid version of rapeseed oil, which has been used for lamp oil for centuries. Olive oil was extensively used as a lamp oil in Mediterranean countries where olives are plentiful. I have heard that "vegetable oil" will leave a residue and not burn as cleanly as canola or olive oil, but will still work. Dissolving some salt into the oil or a dried brine solution on the cotton wick helps the lamp to burn brighter when using canola and olive oils.
Jun 26, 2009. 9:07 PMzipzapper859 says:
will rubbing achohol work ?
Jul 24, 2009. 10:06 PMRaNDoMLeiGH says:
I think it would burn way too HOT for this type of jar.
Jul 9, 2009. 8:00 AMwehrlzz77 says:
what els could be an alternative
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:smh
