3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Sized Lantern
Step 5Final Product:
Final Product:
All that's left now is to light it up. You'll notice I took it off of the wooden board I built it on for this part ;).
And that's pretty much it. A full jar of lamp oil is usually more than enough to get me through the time the power is out. This simple little lantern has helped me out quite a bit when I've needed it. It takes next to no time to make and doesn't require much to make. When it comes time to transport it, I just replace the lid with one that has no hole in it, this way it won't leak in my pocket. Hope everyone has enjoyed my first Instructable, and don't forget to vote if you liked it. Thanks.
34 comments
Jul 31, 2011. 9:03 PMthe.rollie says:
take the bottom off a soda can cut it to fit just around the top of the jar and use silicon to glue the bowl shaped part on the top of the jar, then insert wick and add another hole for refuleing. use original jar lid as, well, the lid
Jul 6, 2011. 5:37 PMpemas35 says:
really liked it reminded me of when I lived in the countryside, did it with diesel
Aug 13, 2009. 3:30 PMultracanery says:
how do you light it
Jul 6, 2011. 10:19 AMOliveman says:
FIRE.
Feb 2, 2011. 12:25 PMFlonine says:
um a match or lighter what kind of question is that?
Jul 1, 2010. 5:04 PMKynan4th says:
i beleive a match might work
Jan 9, 2011. 12:31 PMdragonsniper says:
lol thats kinda obvious
Feb 5, 2011. 3:01 AMNecroVoid says:
maybe there would be a way to make a "valve" to shut the hole with the wick in it by using another jampot lid section, especially if you offset the hole from the center?
May 2, 2011. 12:35 PMsaritali says:
You could use some cork? But it would have to be pretty small, which you can sometimes find by the bag in craft stores.
Aug 4, 2009. 11:44 PMdelusional says:
What are the Physics principles applied here?
Feb 20, 2010. 6:34 PMDoc Holliday says:
Simple:
Determine what is to measured,
Organize the entities of interest,
Find  them,
What do we/they need, or provide,
Get the stuff moving,
Know what stuff is important.
Now, think backwards!
Aug 2, 2010. 2:42 PMTANZMEISTER says:
WORD!
Feb 11, 2010. 10:23 AMchuckr44 says:
If you light something flammable, you get flames (heat and light).
May 28, 2010. 8:51 PMFaquad says:
Cool idea.  Could also be used for citronella, or the like to keep bugs away when camping.   Question, however... how would you extinguish the flame if you needed to?  With an actual lantern, you just turn down the wick and the flame goes out, this... well....?
Jun 28, 2010. 10:41 PMEagleScout2007 says:
You could use a lid to extinguish the flame.
Jun 23, 2009. 11:32 AMJCoffey says:
This is a GREAT instructable. This would be great for camping too I would think. The only problem is an open flame but I wonder how hard it would be to find some sort of glass to use as a globe
Jan 31, 2010. 8:32 PMPeter Mckee says:
If you have a small bottle that is similar size as your jar you can drop a large nail in it then shake the bottle it will pop the bottom off around the seam. Then with a glass grinding bit you can grind off the burrs and make some air holes, this will allow oxygen to get in and the neck of the bottle will be like a chimney allowing the hot air to escape. Then attach it to the cap of the jar with epoxy or some other adhesive.
May 23, 2010. 3:27 PMjacob13 says:
pretty sweet idea
Jun 25, 2009. 6:58 AMskipernicus says:
You could always use a tin can with decorative holes punched in it.
Jun 23, 2009. 12:09 PMtcup says:
I thnk some sort of globe can be found online or in some craft stores. You won't find one for an exact fit but there are larger ones that are use for full sized oil lanterns. Maybe set the jar inside a Mason jar, could fill the Mason jar with sand fo stability. Perhaps some creative person, on this site will think up something clever. This is a group of creative people.
Jun 23, 2009. 7:54 PMzvillesurfer says:
You could take an ordinary jelly jar and glue the pocket sized lantern to the underside of the lid. drill some holes in the jar, then when you light it, put the lid on the jar, and turn it upside down.
Jun 23, 2009. 1:07 PMJCoffey says:
Actually the Mason jar full of Sand is a PERFECT idea. Stability, windproof, and good amounts of light. Im going to have to try this out soon!
Jul 1, 2009. 2:26 PMGracer says:
fire needs oxygen.
May 12, 2010. 12:56 PMdungeon runner says:
Oh my word! We need to alert the presses immediately of this astoundingly astute observation! Clearly the guy that works in a lab has no clue about these things.
May 13, 2010. 4:13 PMGracer says:
Right...  Hang on while I get this wooden shoe off my foot.
Aug 14, 2009. 8:52 PMimagicalgreek says:
Really cool idea. I'm thinking I need to do this the next time I go camping... I'm thinking I might modify the design for this by adding a floating wick holder cut from the side an aluminum can or something like that, that will sit just under the cap, which I won't poke a hole in, to make this more immediately portable...(so the wick can stay in with the lid on) But if I was stuck without electricity, I can see where you wouldn't really need that. Really nice Instructable, ingenious idea. Thanks!
Jan 31, 2010. 8:43 PMPeter Mckee says:
If you cut around a jar lid so that you can squeeze it into the jar but so that it won't come out if you pull on it then while its in the jar squeeze on some glue and pull it tight to the inside rim(where the jar narrows down to the threads) and wait for the glue to set to where tohe preasure isnt needed. Then isert your wick and drill a small hole in the inner lid for refuleing (you should make a plug for it) then cap it with the original lid for that jar. Now you can just cap and uncap it when you need it.
Sep 20, 2009. 12:07 PMLonelydad1962 says:
Do not use vegtable type oil, many aminals of the 4 legged type also like the smell and come looking
Sep 28, 2009. 9:34 AMsa-adib says:
Thanks, it a lot good idea.
Aug 22, 2009. 4:32 PMtonic4 says:
Finally a use for all those left over baby food jars.
Aug 20, 2009. 7:55 PMweaponscollector94 says:
i love pocket sized things and i love fire, this is the greatest invention of all time and i just made one! thanks for the idea!
Aug 18, 2009. 5:52 AMBandit535 says:
Can I use olive oil?
Aug 20, 2009. 2:43 AMsharlston says:
yep i did it burned for 8 hours i used a old t shirt for the wick
Jun 23, 2009. 12:06 PMtcup says:
That's terrific! What a great way to recycle.
Jun 25, 2009. 5:46 AMCatskinner01 says:
For maximum recycle prowess, filter used cooking oil as the fuel (once through a paper towel would be more then sufficient). The result will be smoky and have more of a scent, but is effectively free and is certainly recycling.
Jun 25, 2009. 7:07 AMtcup says:
mustard oil--what is that? I've never heard of it.
Aug 2, 2009. 12:09 PMshannnn says:
Mmmmmm, mustard oil! You can find it on Devon Street in Chicago,and it smells & tastes delicious. Opens up one's sinuses, too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:smh
