Powerful Pocket Sized Rotary Tool
Introduction: Powerful Pocket Sized Rotary Tool
I love my Dremel, but sometimes I wish it was smaller. I started looking around for a cheap, small rotary tool and found an oldDremel 7700-1/15 MultiPro Cordless at a garage sale for $8.00. Unfortunately, after about a month or two of use it the battery started to die. Rather than buy a new battery pack for it I decided to seize the opportunity and make an even smaller Dremel. At just over 4 inches it is about 2/3 of the length and the same width of the smallest rotary tool I could find online, the Dremel 754-04 4.8V MiniMite, and it provides 1.5 times more power.
Disclaimer: this could potentially destroy your rotary tool. I have only done this on the Dremel MultiPro Cordless, I don't know what will happen with other brands or tools.
Step 1: What You Need:
- Rotary tool
- Old rotary tool to cut up
- Whatever rotary tool heads you need to get the old tool apart
- Soldering Iron
- Solder
- Glue
- Electrical tape
- 2 neodymium magnets (optional)
- 9v battery snap
- 9v battery
- Voltage regulator (depends on the voltage your rotary tool requires)
- Switch
- Wire
Step 2: Taking Apart the Rotary Tool
- Carefully break apart the old rotary tool to expose the motor and shaft that holds the bits; that is what we want
- Check the voltage required by the rotary tool; this will determine the voltage regulator you buy
- Purchase a voltage regulator that has an output close to the voltage required by your rotary tool; I got mine at Mouser Electronics
Step 3: Making the Circuit
- Solder the battery snap, voltage regulator, switch and motor together like in the picture
- Add the battery and test it out
Step 4: Finishing Up
- Use a small amount of glue to hold the battery in place and tape around it
- Use a small amount of glue to hold the switch to the battery and tape around it
Adding the Magnets (Optional)
- Take the 2 magnets and place them on the sides of the motor
- Tape over the magnets
- You can use the magnets to hold spare bits
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    i want a sample video of that?
    There you go.
    now i see that in action!
    can i suggest? make a case for your rotary tool!!
    nice work.. friend , i want motor specification so that i can buy some equivalent spec. motor from local trader...
    I'm sorry, I don't know the specifications apart from that it needs 7.2v an operates at
    20 000rpm.
    This is cool. The ubiquitous nature of the 9V battery is great. But, if I want endurance, I might try this with 2x LR123A lithium batteries. Gives you about 8V @ 2000mAh. They are about 1" tall. So they could be taped around the motor and not increase the length of the tool.
    Cool idea. Thanks!
    Thanks for the suggestion! I might just have to get some lithium batteries now.
