If you have a pocket, you can take it with you!
I did everything with things I had lying around the house. Along the way I will suggest alternatives to the tools used and the materials included.
Inside you will find:
-A mechanical pencil
-leads
-pastels or crayons in a separate compartment
-variety of wooden pencils (be it drawing or coloring pencils)
-pencil sharpener (fixed to one side with a hole so you don't have to open the box each time you sharpen a pencil)
-chalk (I like to paint in the Blackboard if I arrive early to a lecture, can also be used in a rough dark surface)
-vine and compressed charcoal
-kneaded and rubber eraser
-Blending Stump
-small brush
-small pen with masking tape (I show you how I did it, but usually don't carry it around)
-Sanding paper on one side
-Ruler marked in another side
Entertaining BONUS
-magnetic chess set
-magnetic Domino set
Required Materials:
-1/4" Thin wood sheet (a 3/4" x 6" piece will do)
-Strong glue (wood and metal)
-metal clip and a stripped jumper wire (for holding the clip, you could also solder it)
-Fridge magnetic sheet
Tools used:
-Thin Permanent marker
-Rotary tool [or anything for sanding (wood) and cutting (wood and metal)]
-Pliers
Remove these ads by
Signing UpStep 1Separate the main compartment
First we have to divide the box in two:
Cut a 3/4" x 6" rectangle of thin wood.
Divide it into one 3 5/8" x 3/4" and two 3/4" x 1" pieces
If you want a secret compartment, make a hole in the longer piece as the image shows. (so you can put the sharpener looking towards the other compartment and use the remaining space to store stuff)
comments
Add Comment
Add Comment
