3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Sized Soldering Kit (Cold Heat Hack)
It's the final two minutes of the best football game of the season, your team is up by seven and the opposition has the ball on your 10 yard line. The football is hiked, and as instantly as the ball leaves the centers hands, the TV looses power due to that loose wire you have been putting off fixing for months. Even worse, your regular soldering setup is all the way in the basement and will take too long to retrieve. What do you do?
Luckily for you, you have followed this instructable, and created the most useful tool package of all time, and even better, it is small enough to fit in your pocket, specifically, the pocket of the pants you are wearing right now. With a minute to go, the TV is up and running and your team has intercepted the ball. Way to go.
Sound like a situation you would like to avoid or a solution you would like to have on you at all times? Good, read on.
This instructable will document the steps necessary to modify and fit every tool and useful accessory required for an emergency soldering job in the hacker-essential, pocket-sized, minty-smelling, Altoids tin container.
Within one tin, you will be able to fit:
One Cold Heat soldering iron with two extra batteries and a spare tip (hardware store)
One clip anywhere helping hand (hardware store)
Several inches of multiple sized heat-shrink tubing (hardware store)
Several feet of electrical tape (hardware store)
Cable ties (hardware store)
Flexible standing light and laser pointer (because it's not worth doing if it doesn't have lasers) (pharmacy; tool aisle)
Small Phillips and flat head screwdriver (hardware store)
Small Wire stripper and cutter (electronic or hardware store)
This instructable will feature:
Hack your Cold Heat soldering iron
Hack your alligator clip wire leads
Hack your Strippers
The Rest
Pack your box
Video on Final Page *coming soon*
Step 1Hack your Cold Heat soldering iron (1 - Disassemble)
Contrary to popular belief, this Johnny 5 is meant to be disassembled.
For this step you will need the following parts:
Cold Heat Soldering Iron ($19.99 from a hardware store)
Two CR2 Lithium-Ion batteries ($9.99 from your film processing/prescription providing superstore)
Short length of thin gage wire (24 or smaller)
Solder
Electrical Tape
Altoids Smalls box
And the following tools:
Soldering Iron
Small Phillips screwdriver
Wire cutter and/or stripper
Dremel with standard accessories
First and foremost, in the words of Norm Abram, "Before we use any power tools, let's take a moment to talk about shop safety. Be sure to read, understand, and follow all the safety rules that come with your power tools. Knowing how to use your power tools properly will greatly reduce the risk of personal injury. And remember this: there is no more important safety rule than to wear these - safety glasses." What good is a mini soldering iron if you have no eyes?
Begin by disassembling your cold heat soldering iron (CHSI). Even though I will post photos of my iron, it is recommended that you photograph your CHSI before cutting any wires or removing any components. This way, if your CHSI differs from the example, you will be able to track the changes later when you discover the differences.
Remove the screws holding the CHSI together, including the screw accessed from the battery compartment holding the blue grip to the housing. Separate the two halves of the unit, and observe. You will note the tip apparatus in the front of the unit, several wires running to the back circuit board, battery terminals, a switch, and a few LED's. All of these parts will be saved and reused, so as you remove them, place them in your handy pocket sized Altoids tin screw organizer that will soon become the case for this project. To remove the wires from beneath the fused plastic fastening method chosen by the manufacturer, use an X-acto knife. To avoid cutting the wires, hold the knife at an angle, and pull the wires behind the blade before applying pressure (see photo below). You will find a few more screws holding the tip in place, remove these and remove the internal components in one piece.
56 comments
1-40 of 56next »
Jan 10, 2011. 9:23 AMTheAntiHeroHimself says:
You added HST, but nothing to shrink it. Wouldn't it need a lighter?
Jan 10, 2011. 7:00 AMkannanstark53 says:
hi this is cool man
i like it man.
thanx
Sep 7, 2010. 10:51 PMtzq33tdq says:
i think this is a great instructable!!!
Aug 7, 2010. 6:42 PMthreewheela says:
great ible. but im gonna have to make an iron in a can with some old school iron because i could never get my cold heat one hot enough to melt any solder :(
Jul 20, 2009. 9:48 AMcapn_midnight says:
Your sentence, "Hack your alligator clip wire leads (or crocodile clip leads for those of you in FL)" makes no sense. Florida has alligators, not crocodiles.
Sep 23, 2009. 5:58 PMPaki7491 says:
actually, in south Florida, we have both. The everglades is the only place in the world where alligators and crocodiles live in the same place.
Jul 23, 2009. 9:03 AMarduinoe says:
meh , there both big , long and dnagerous , this reminds me of something...
Jul 23, 2009. 2:55 AMagis68 says:
technicalities my friend! ;)))
Jul 23, 2009. 9:31 AMcapn_midnight says:
Uhm, I hope you can appreciate the value of paying the utmost attention to "technicalities" when dealing with basically anything related to the purpose of this site. I'm just saying, taking a laissez faire approach to technicalities is how one gets a 120V surprise.
Jul 28, 2009. 2:19 PMagis68 says:
OK maybe u have right but any other site than here, go to electo-tech.com and say this and then i will agree with u 150% but here no. Focus on the job, the spirit and the gnessis of this idea coming project. And don't spoil the spirit of any member here. They deserve the best, and from us looki an advice and some claps, to aplause their job, else u remember me the guy who was looking the tree and was forgot all the f.... forest. Iam not bitter in my feelings or havi bad language but that's the spirit of www.istructables.com.....elso go to the MIt forums...and make yourself feel better;)))
Jul 27, 2009. 4:51 PMJavin007 says:
You know what REALLY "makes no sense?" Your statement that "Florida has alligators, not crocodiles." Yes, Florida has alligators TOO, but it also happens to be the only place in the U.S. that HAS CROCODILES. The Florida crocodiles are estimated to be some 400-500 and are on the rise. I find your whole "You shouldn't say crocodile clips instead of alligator clips YER JOKE ISN TEH FUNNAY" to not only be asinine, and pointless, but you're also "technically" wrong. Despite his statement being an obvious joke that you, for whatever reason, decided to get your panties in a twist over, his statement was also "technically" correct. You didn't do your homework and decided to jump on him for his correct and tongue-in-cheek joke. I won't even get into the fact that you then go on to suggest that by his joke (allegedly) being incorrect that this could equate to someone getting electrocuted. Are you for real?
Jul 27, 2009. 4:56 PMJavin007 says:
Ah, I stand corrected... Their numbers are now in the thousands, and they're being considered for removal from the endangered species list according to National Geographic and the NPR.
Jul 28, 2009. 2:20 PMagis68 says:
HAHAAHAHAHAHA.........excellent risponce dude
Sep 15, 2009. 5:41 PMFunkNattidelic says:
So much for "i dont have bad language" eh?
Sep 16, 2009. 4:10 AMagis68 says:
:D
Jul 21, 2009. 9:57 PMmettaurlover says:
they have a coherence checker?
Jul 23, 2009. 7:03 PMRimwulf says:
Jul 23, 2009. 7:59 PMmettaurlover says:
yay!
Jul 22, 2009. 7:34 PMqballcat says:
yup, and someone wrote gullible at the top of this ible'
Jul 22, 2009. 8:00 PMmettaurlover says:
no; i was just wondering cause it would be nice if they did, in fact, have one.
Jul 22, 2009. 9:16 PMqballcat says:
oh, lolz
Jul 20, 2009. 10:37 AMbustedit says:
i think he was being politically correct so as not to insult the alligators. you wasted your time arguing semantics, and i just wasted time replying to you.
Sep 21, 2009. 6:04 PMColonel88 says:
Lol you had me laughing at "Hack your Strippers" no offense.
Aug 30, 2009. 6:21 PMWarSaw says:
awesome intro
Jul 23, 2009. 10:20 AMArbitror says:
I really hated the Coldheat... The brittle tips kept breaking, and I couldn't do micro soldering easily...
Jul 30, 2009. 1:55 AMstatic says:
II find the cold heat unit a dissapointing purchase myself. I had one of these http://www.gigaweb.com/products/view/3585/60-pro-charge-cordless-rechargeable-soldering-iron.html when I was doing a lot repairs in the field. I loved it but, it looks like inflation occurred in the mean time, and they where a boring gray color back then.
Jul 31, 2009. 2:19 PMstruckbyanarrow says:
i got a WELLER butane soldering iron for 15 bucks at home depot and i love
Aug 12, 2009. 12:23 AMstatic says:
I have been eyeballing those. I like the Wahl because it was quick to come up to operating temp.Also quich to cool down so so worries about melting any plastic in came in contact with after putting it in the tool box.
Aug 9, 2009. 6:10 PMalbylovesscience says:
so how good does that cold heat soldering iron work does it do as much as a regular soldering iron
Aug 1, 2009. 1:13 PMarjo says:
yeah yeah i know, no diss intended.
just letting the folks know of a useful purpose of the tool intended and how to use it properly or an alternative with broader uses
*peace* bro :-D
Jul 27, 2009. 11:36 PMarjo says:
just a point on those wire strippers. they suck pretty bad for normal wire, but they're designed for removing the outer layer of insulation from coax or multicore wire such as cat5. the plastic bracket applys just enough force to cut most of the way through the outer layer so it can be easily removed with a bend and a yank. personally id be looking for somthing like some fold-out scissors from a sewing kit. that covers you for all manner of stripping, cutting and gouging, all sure to be useful in an emergency. look around for a good set tho, there are some very bad examples that will only make you cuss and or hurt your fingers. a better pair wont be much easier to use (teensy tools in man-size hands never are), but at least will work.
Jul 27, 2009. 4:58 PMJavin007 says:
Iculus: Great 'ible, and I'm sorry I didn't manage to see it previously. (Glad you're in the finalists stage, and good luck in the judging!) I think I may have to actually do exactly this with my cold heat gun. Currently, my "soldering kit" consists of a shoe box with a bunch of crap in it. The other day I needed to do a quick and simple solder job to test a hobby engine and ended up having to pull everything out and make a wreck of my table. This is just brilliant.
Jul 25, 2009. 1:51 PMSkittles22 says:
Such an awesome idea, so cool!
Jul 20, 2009. 10:22 PM1up says:
With all these awesome pocket-sized entrys, I'm running out of pockets to put them all in! :D Nice Instructable.
Jul 23, 2009. 11:59 PMadamvan2000 says:
*cough*cargopants*cough* ;O) ~adamvan2000
1-40 of 56next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:iculus
