3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Sized Soldering Kit (Cold Heat Hack)
Step 7Pack Your Box
Pack Your Box
Now that your helping hand and CHSI are complete, they can be packed into the main Altoids housing.
Gather together:
Hacked CHSI
Helping hand
Heat shrink tubing
Hacked Wire cutters
Small screwdriver, multi tip or other
Small electrical tape
Solder coil
Wire coil
Spare batteries
Flashlight w/ laser
Start by inserting the CHSI into the case such that the aspect ratio of the small box matches that of the large box. If it doesn't fit, press the internal components further into the box, or remove the tip.
Place the flashlight in the case so it is parallel to the long side of the box and perpendicular to and covering the CHSI tip.
Place the cable ties and helping hand on top of the light.
Insert the batteries perpendicular to this light at the end of the container.
Insert all other components however they fit best. If done right, the container should close with no issue, and stay shut on it's own. If needed, wrap the container in electrical tape to ensure closure.
Finally, place this in your pocket. You will not need it until you forget this final step.
1 comment
Jan 10, 2011. 9:23 AMTheAntiHeroHimself says:
You added HST, but nothing to shrink it. Wouldn't it need a lighter?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:iculus
