3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Tripod
Pocket Tripod
A useful tripod that's easy to make and fits in your pocket. It uses stiff wire wrapped in electrical tape as legs, and taped to a bolt. I have like 4 now so i'll give one to my friend that wanted one.
Step 1Get Supplies
Get Supplies
you need 4 things:
3 Stiff pieces of wire, 10+ inches long (old coat hangers, copper house wiring)
a 1/4" bolt that fits camera mounts, they're pretty common
electrical tape
pliers
58 comments
1-40 of 58next »
May 1, 2007. 12:55 PMSean Et Cetera says:
What about using duct tape instead of electrical tape? Wouldn't that hold up better or at least improve the grip of the legs when they are wrapping aroudn something?
Mar 10, 2008. 6:31 PMspork969 says:
it would not improve the grip, but it might be more durable
Aug 26, 2010. 11:59 PMshakna says:
I've actually made a tripod using only duct tape, no etape, and it's worked fine for me for a while... You just need to be patient while applying the duct tape so you get it straight, it can be plenty tight enough.
Feb 22, 2011. 4:39 PMxhephaestusx says:
the point is etape stretches, allowing for a very tight grip, whereas ductape can't stretch well b/c of its internal fabric - what duct-tape DOES have is a stronger adhesive
@theRIAA: very nice, i've been looking at those "gorillapods" and my girlfriend actually has one - this is that and for cheap! i'm getting up as soon as i press post to make one! i can hardly believe i never thought of this, i'm personally a strong proponent of stiff wire and tape
Feb 19, 2007. 1:48 PMvikarious says:
I've made mine like this :
Nov 15, 2010. 11:35 AMtimshapiro says:
Uh... hey, Vikarious... why the heck don't you post your "how to" project in making your redesign of the tripod? I think yours looks amazing.
Sep 24, 2010. 4:43 AMconfuscated says:
I'm curious to know: what type of wire did you use for the legs? Those don't look like wire coat hangers to me and appear to be covered with a coating?
Mar 28, 2010. 6:59 AMscoatw says:
I wonder if one could solder the coat hanger to the bolt ?
Jan 4, 2010. 9:19 PMstephenniall says:
I use this method quite alot I was looking at gorilla pods But the slr one is about 20£ in my county so i needed to make my own and came across something like this
May 22, 2009. 6:19 AMarikyeo says:
For those of you who live in Singapore, I got it from my usual hardware store(in Singapore, that is). It's called Chong Brother Hardware Supply. There's one in CCK and 1 in Teck Whye. The CCK one (CCK is Choa Chu Kang, Google it) cos' it has more things in it... but... it's more dusty...
Dec 6, 2006. 6:18 AM_soapy_ says:
What size & thread is the bolt? They aren't common outside the US as far as I know, because it is an old imperial size and pitch. Neat idea, regardless.
May 22, 2009. 6:14 AMarikyeo says:
where do u live?
Dec 6, 2006. 8:31 AMMyself says:
1/4"-20, which means quarter inch, twenty threads per inch. The most common thread in the US, if not the rest of the world. It's on cameras no matter where you go, so nyah nyah! ;)
Dec 11, 2006. 3:14 PM_soapy_ says:
Thanks. I'll be able to either track one down, or get one made. I have no objection to special cases, as long as they are consistent and available.
Aug 24, 2008. 3:00 PMspork969 says:
The 1/4"-20 is obsolete nowadays and only used for tripods. (To the most of my knowledge.) I would love to be corrected however.
My source: "The de facto standard threading for the screw that attaches the camera to the tripod is Whitworth 1/4"-20 for small cameras or Whitworth 3/8"-16 for larger cameras. (This otherwise obsolete thread system is similar to the Unified Thread Standard still used in the USA, but with a different thread angle.)" - http://en.wikipedia.org/wiki/Tripod_(photography)
Aug 25, 2008. 12:30 PMspork969 says:
Well I tried using a "standard" bolt, and it won't go in. However, when using a real tripod, it works fine. So I'm thinking the "different thread angle" means a different number of threads per inch. I'll take a picture in a few next to a ruler and find out.
Aug 25, 2008. 12:39 PMspork969 says:
Ok. I feel stupid. Turns out it does fit perfectly and I'm just an idiot. Great instructable and idea.
Jun 6, 2008. 7:16 PMdafastlife says:
my first use of the website thanx works great!
Apr 10, 2009. 3:13 AMLance Mt. says:
Bit late but welcome
Apr 30, 2009. 2:26 AMLance Mt. says:
Sorry i ment i'm a bit late My bad.. Just read
I love it, seriously. Cheap, easy and looks heap durable
Jan 14, 2009. 8:12 AMscoatw says:
Another vote for a Great idea. I was thinking of purchasing a gorilla pod until I saw this. I just made one. Total cost $4. I stopped off at the Dry Cleaners and picked up some wire hangers. I added a wingnut with a 1/4" fender washer to snug up against the camera. I also added some little rubber thingys that I took off of a bungee cord I had and made little feet for it. Thanks for the idea.
Apr 24, 2008. 12:14 AMshilohjim says:
I was thinking about making something like this and you beat me to it. Cheap and simple,I like it.
May 2, 2007. 1:17 PMunjust says:
great idea. i'd make the following changes: -use romex type solid core insulated wires. (free scrap!) -bend the non-bolt end into a tight loop. -cover with heat shrink, with the free end tucked back in before shrinking for a clean end look (depends on how good you are with bending the loop pretty. -use 2 heavy duty zip ties and cover in a few wraps of self adherent silicione tape --no adhesive to squish out, no stretch, not going to come apart in a hot car -use a wing head bolt. -maybe mount the wires to a bushing around the bolt. -2 thin nuts or 1 nut with locktite to hold the bushing on and prevent over penetration into camera guts. think i'm gonna have to make me one of these.
Apr 4, 2008. 2:44 AMezrabones says:
What are romex type solid core insulated wires, and where can I get them?
Apr 4, 2008. 6:17 PMunjust says:
typical new construction household electrical wire. small bits you can probably scrounge from housing construction dumpsters.
May 2, 2007. 1:24 PMunjust says:
i should add that e tape is great stuff -for it's designed purpose- which is insulating wires, however it is not heat stable over ~140F and does not do well under shear or abrasive forces. while more $$ self adhering silicone tape is comperable for this purpose, and won't get glue on everything. some zip/wire ties do come with a strength rating, while e tape does not, and while laminated tape is pretty damn strong, it's not going to be as stable.
Nov 5, 2007. 4:16 PMsam_rocks321 says:
This is a very nice tripod it holds my Cannon dslr and it almost holds my xlh1. very pprotable and easy good instructable
Jul 7, 2007. 10:25 AMBicyclette says:
Do you think this would hold an SLR?
Jun 16, 2007. 2:48 PMWhatnot says:
That bolt might be common in the US but in areas where they use ISO metric bolts (ie much of the EU), you have a hard time finding these lying around. In fact the quickest way of finding one is.. a cheap tripod :)
Mar 28, 2007. 1:59 PMoldbogus says:
I think you mean "nuts" in this sentence: you can screw on a bolt to snug up your camera, or 2 bolts screwed together as a stop. I gotta make one (or two) of these!
Mar 11, 2007. 9:34 AMevy-wevy says:
awww man? i just bought a gorillapod!
Mar 9, 2007. 12:56 PMMercat says:
Wow, this is a great idea! I've been looking at a gorillapod, but this actually looks like it's going to be a much better "pocket" version, which is what I'm looking for. Thanks!
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
118
Author:theRIAA
