While at the hardware store getting some supplies I noticed this carpet and decided I was going to make a pocket yard pool set (makes it more challenging then a standard pocket pool set) in the altoids can I had left over from my last project.  I decided that it should be a classy game with gemstones for balls and brass for the pool stick ball rack.  We only used 4 pockets as not much room to play with any more.
As for supplies we used
Carpet sample (free)
7 Gemstones (we used 6mm beads)
copper rod
Flat copper wire
Step 1: Create the table
Cut the foam base to raise the pool table up to the correct height.  Then trace around the tin and cut the carpet out to fit into the tin as well.  After making sure it is a good fit take it back out and cut the pockets for the balls.
Step 2: Create the rack
Measure the balls and create the rack by bending the flat copper into the correct size triangle this will depend on the size of beads you used.
Step 3: Cut the pool que
Cut a piece of copper rod to create the pool Que
Then glue the carpet and foam down to make it more solid
after the glue dries test it out and see what you think
I posted a small video per request but my camera does not support long videos.
dkbilliards says: Apr 26, 2012. 9:44 AM
What an awesome little table! Using some worsted wool might work for getting a flat surface. It has a much smoother finish than the standard woolen cloth. You can learn more about billiard cloth at http://www.dkbilliards.com/faq/#tab=cloth-colors
ThatKnottyguy says: Mar 17, 2012. 2:58 PM
If you dont want to use a copper rod a good alternative is wooden skewers, cut and sanded.
bbgun_sniper says: Dec 20, 2011. 8:02 PM
nice man thats awesome portable pool table y couldnt i ave thought of that?
vicvelcro says: Nov 22, 2011. 12:29 AM
As of 3:30am EST, the last video in the last step can not be viewed because it is set as 'private' on the host end.
backyardengineer (author) in reply to vicvelcroNov 22, 2011. 12:34 PM
I will take a look at that tonight... sorry about the delay I have been busy at work.
TheRealPeregrinus says: Sep 29, 2011. 7:29 PM
Hey, That's pretty fun. Why did you choose carpet for the surface, it seems like it would be kind of coarse?
backyardengineer (author) in reply to TheRealPeregrinusSep 29, 2011. 7:41 PM
Honestly I did that because I thought it looked cool. But it turned out that it was a good feature as it makes you have to hit the balls harder to get them to go in the holes. I helps make up for the small size:)
It also makes the game a little more challenging as the pool tables flaws change every time you play it. I almost want to cover a full size pool table like this.
TheRealPeregrinus in reply to backyardengineerSep 30, 2011. 10:54 PM
As long as it works. Probably good that it isn't too smooth if the balls would roll too easily.
backyardengineer (author) in reply to TheRealPeregrinusOct 1, 2011. 7:09 AM
It really worked better then I expected. I wish I had done something to level the table though... Maybe for the next version.
The video was after some practice you have to hit the beads a lot harder then normal on a small pool table.
Pickles5000 in reply to backyardengineerNov 11, 2011. 3:41 AM
Green felt might work to provide a flatter surface??
urbanwoodswalker says: Nov 2, 2011. 5:39 AM
AWESOME! The perfect gift for the guys on my list. Only, I hope it works....as they really love to play pool!
do you think smaller gemstone beads might work too? I guess i just have to make and see.
I hope you work on a design for mini darts...cuz I like to play those ~~~:-)
backyardengineer (author) in reply to urbanwoodswalkerNov 7, 2011. 5:50 PM
Let me know if they do work, I only tried the 1 size. Good luck and let me know how you like it. As for the darts I will have to think about it, sounds like a good project when I get caught back up again so I can play.
urbanwoodswalker in reply to backyardengineerNov 8, 2011. 5:08 PM
I will. I have seen pocket dart set...sold at the bookstore...it was magnetic...so to create darts with rare earth magnets and use the altoid tin as target and game box...sounds doable.
Or even real darts (pins?) with a cork target....its all seems like a good project challenge.
Akask says: Oct 12, 2011. 4:48 PM
Would airsoft bb's work instead of the beads?
backyardengineer (author) in reply to AkaskOct 12, 2011. 6:20 PM
I do not know. Part of me says that they would be too light. But as for size they would work. I do not have any to try so let me know if you do.
lordofducttape545 in reply to backyardengineerOct 23, 2011. 9:52 AM
what if you used metal bb's? my friend has some and they are quite heavy. for bb's i mean
backyardengineer (author) in reply to lordofducttape545Oct 25, 2011. 9:00 AM
I would think that they would work.
lordofducttape545 in reply to backyardengineerOct 25, 2011. 9:10 AM
SWEET!!!
sunshiine says: Oct 9, 2011. 8:44 PM
Kewl! Thanks for sharing this! Have a nice day!
sunshiine
backyardengineer (author) in reply to sunshiineOct 10, 2011. 12:21 PM
Thank you, I was hoping somebody would copy me but not yet I guess:)
dajsgames says: Oct 3, 2011. 6:55 PM
Very cool! Certainly going to build this tommorow. You have my vote, trully original. Hope you get that new camera you want!
backyardengineer (author) in reply to dajsgamesOct 3, 2011. 8:17 PM
you should post some pics when your done:)
dajsgames in reply to backyardengineerOct 6, 2011. 10:00 AM
Will do, I just have to find those beads! :)
backyardengineer (author) in reply to dajsgamesOct 6, 2011. 12:30 PM
Micaels or Hobby Lobby would be where I would suggest looking. I stole them from my girlfriend personally :D If you were close I would give them to you.
punkhead58 says: Sep 30, 2011. 3:38 PM
Damn, this is epic; I would patent this if I were you. Then again, perhaps I will first! Muahahaha!!!
backyardengineer (author) in reply to punkhead58Sep 30, 2011. 10:19 PM
I will tell you what, if you want to I will change the agreement so you can try to patent it. I just get to keep mine:P And you have to vote for me :D
punkhead58 in reply to backyardengineerOct 1, 2011. 7:01 AM
I will tell YOU what, check out my instructable, and perhaps vote for me in the survival contest (I entered it, but it hasn't been added yet), and you will have my vote.
punkhead58 in reply to backyardengineerOct 1, 2011. 6:57 AM
I am also entered in the contest, but my main entry is in the Survival contest, so perhaps I will vote for you. After all, I do love pool.
backyardengineer (author) in reply to punkhead58Oct 1, 2011. 7:07 AM
I saw that, I was impressed that you have a more thought out survival pack, you can not survive out of an altoids tin.
And our votes don't pick the winner so you can vote for whoever you want without hurting your chances :)
SHIFT! says: Sep 29, 2011. 12:04 AM
Please post a video!
backyardengineer (author) in reply to SHIFT!Sep 29, 2011. 6:58 AM
My camera sucks but I posted a small video of us hitting one ball.
fallenofyesteryear in reply to backyardengineerSep 30, 2011. 4:55 PM
lol is that why you entered,to get the new camera(grand prize at the time)
backyardengineer (author) in reply to fallenofyesteryearSep 30, 2011. 10:17 PM
Yes I did :D
Might as well be honest my camera sucks I could use a new one.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
