3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket potato gun
Pocket potato gun
I have entered this in the pocket sized contest. Please vote for me. and subscribe please!
IT WORKS BETTER THAN OTHER POTATO GUNS (POCKET SIZED) shoots farther!
It is six inches long, and an inch wide. It is powered with propane and an electric sparker from a lighter.
I AM NOT RESPONSIBLE FOR ANY INJURIES.
Step 1Materials
materials
These are the items you will need:
- super glue (may not need it)
- wire
- electrical tape
- duct tape
- thumb tacks
- pen
- pliers
- knife
- sparker (from lighter)
- wire snips
- glue stick
Propellant
-propane
Cleaner
- Q-tip
-alcohol
Ammunition
- 5-10 mm slice of potato
43 comments
1-40 of 43next »
Dec 18, 2010. 11:42 AMthomasthetankengine says:
Do you have to use propane or can you use hair spray or another household item? Also, can you use a part from a bic lighter?
Feb 14, 2011. 6:44 PMItzMeLogo says:
I also agree, I have not been on instructables in month, there is no excuse!
Apr 20, 2010. 1:27 PMIpodfan414 says:
when you spray in the hairspray wouldnt the flamible fumes go out the barrel instintly?
Aug 9, 2010. 7:34 PMmoomoocows says:
You could load your ammo before you spray or add your selected fumes. This would prevent the barrel leaking.
Apr 20, 2010. 11:04 AMIpodfan414 says:
Hello could you tell me if you can only use a long lighter or any sparker from any lighter like a small bi lighter ?
Apr 4, 2010. 10:34 AMbillbobby says:
 can you use axe spray for fuel?
Mar 29, 2010. 3:15 AMiroc_zman says:
Butane Lighter Fluid and White Rain Hairspray So Far Are The Best I Found
Feb 26, 2010. 2:24 PMdragonwarrior3000 says:
I AM NOT RESPONSIBLE FOR ANY INJURY..LOL
Jan 24, 2010. 1:33 PMhomemovies64 says:
 Hi,
Mine doesn't fire at all, but sometmes fires fire out the back with the cap on from the side. ANy suggestions?
Jan 27, 2010. 5:10 PMhomemovies64 says:
 Thanks for the reply. Sometimes it will fire, and other times won't fire for a long time. I spray in for half a second hairspray, (very flammable kind LOL) and it barely works. It sparks inside, I found that out the hard way by shooting the potato into my face once, but it still sparks. What could cause it to be unresponsive. Does yours work on every fire?
Thanks,
Eric
Jan 25, 2010. 4:26 PMhomemovies64 says:
 oh yeah, it sparks, but the thing is that i spray some hairspray for bought half a second, and sometimes works, but sometimes doesn;t. But if you take off the back cap, it shoots out a flame. Weird, idk whats wrong.
May 11, 2009. 10:52 AMItzMeLogo says:
I made one too, I've only dry fired it whithout potato in dark to see if it works, it does and I'm using axe deodarant spray worrks great
Dec 20, 2009. 5:25 PMzack247 says:
i use tag, i find its seems to be a little more flammable
Oct 16, 2009. 9:23 PMAWNydam says:
i made one of these a few months ago but i used i chapstickcontainer so my combustion chamber is tiny. shoulda thought about a gluestick.
i was thinking abput using one of those small gatorade bottle but the plastic is a little to thin and could melt
Jul 26, 2009. 4:00 PMcoolerthancool505 says:
i made this and it didnt work at all. but the spark worked. do you have any tips that could help me? i used hair spray is that the problem?
Oct 11, 2009. 11:18 AMitsthatsguy says:
In order for thsi to work you need a 50/50 air to fuel mixture in the compustion chamber, spraying hairspray is WAY to much, if you do this, just tilt the device on its side, wait a little then light it.
Jul 29, 2009. 9:33 AMcoolerthancool505 says:
thanks
Jun 21, 2009. 11:21 PMMadBricoleur says:
oksay i made it! just a tip: it would be helpful if you got some silicon caulk and smeared it around the "adaptive tape fitting" and on the side that's in the chamber so it's waterproof and all. Oh, and a good fuel would be to put alcohol (i used 70% isopropryl rubbing alchol) in a spray bottle and spray a bit in there. my method: push the spray button halfway down (spray that much), then cap it and shake 7 times, then fire.
May 23, 2009. 3:49 AMLILhazY says:
SSSSSSSSSSOOOOOOOOOOOOOOO WANA TRY THIS LMAO
Apr 17, 2009. 4:01 AMbylerfamily says:
Cool.Made one myself and it shoots pretty far.
Apr 17, 2009. 8:09 AMbylerfamily says:
I use silicon engine lubricant.That stuff is explosive.
Apr 20, 2009. 4:13 PMbylerfamily says:
Oh,for some reason your instructable is not in the Epilog challenge.And I can't find a way to vote for you.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:creator 1
