I have entered this in the pocket sized contest. Please vote for me. and subscribe please!
IT WORKS BETTER THAN OTHER POTATO GUNS (POCKET SIZED) shoots farther!
It is six inches long, and an inch wide. It is powered with propane and an electric sparker from a lighter.
I AM NOT RESPONSIBLE FOR ANY INJURIES.
Step 1: Materials
These are the items you will need:
- super glue (may not need it)
- wire
- electrical tape
- duct tape
- thumb tacks
- pen
- pliers
- knife
- sparker (from lighter)
- wire snips
- glue stick
Propellant
-propane
Cleaner
- Q-tip
-alcohol
Ammunition
- 5-10 mm slice of potato
thomasthetankengine says: Dec 18, 2010. 11:42 AM
Do you have to use propane or can you use hair spray or another household item? Also, can you use a part from a bic lighter?
creator 1 (author) says: Feb 10, 2011. 6:32 PM
hey, sorry it's taken me like 2 months to reply! guess i've been... on second thought i don't really have an excuse. anywho, no, you don't just have to use propane. you can use sprays and such, the liquid tends to build up on the igniter pins. that's why i like to use gasses. so if you do use spray, but sure to not use much! also, the bic lighters don't really work, because there is not way to contain the combustion and also safely strike it. hope that helped,
derek
ItzMeLogo says: Feb 14, 2011. 6:44 PM
I also agree, I have not been on instructables in month, there is no excuse!
Ipodfan414 says: Apr 20, 2010. 1:27 PM
when you spray in the hairspray wouldnt the flamible fumes go out the barrel instintly?
moomoocows says: Aug 9, 2010. 7:34 PM
You could load your ammo before you spray or add your selected fumes. This would prevent the barrel leaking.
creator 1 (author) says: Apr 27, 2010. 1:48 PM
that's actually why i don't use hairspray.  i don't think it comes out instantly, but if you don't put the cap on quickly, i'd imagine that it would come out rather quickly.  i use propane, and because its more dense that air, it doesn't come out of the combustion chamber unless you tip it upside down.
hope that helped,
     derek
Ipodfan414 says: Apr 20, 2010. 11:04 AM
Hello could you tell me if you can only use a long lighter or any sparker from any lighter like a small bi lighter ?
creator 1 (author) says: Apr 27, 2010. 1:51 PM
i don't think one of those small lighters would work, because than you can't seal the combustion chamber properly.  i use the long lighter type sparker, because it's the perfect size.  but really, you can use like one of those grill sparkers, or a stove sparker.  it should work as long as the chamber is sealed.
good luck,
     derek
billbobby says: Apr 4, 2010. 10:34 AM
 can you use axe spray for fuel?
creator 1 (author) says: Apr 4, 2010. 7:37 PM
well, i've never tried it, but if it's flammable, then i'd guess it would work.  make sure you use very little fuel.  it should be approximately 15 parts air to 1 part fuel vapor... good luck
iroc_zman says: Mar 29, 2010. 3:15 AM
Butane Lighter Fluid and White Rain Hairspray So Far Are The Best I Found
dragonwarrior3000 says: Feb 26, 2010. 2:24 PM
I AM NOT RESPONSIBLE FOR ANY INJURY..LOL
creator 1 (author) says: Feb 26, 2010. 7:19 PM
well hey, if someones eyes get shot out, i don't want to be in trouble lol (:
homemovies64 says: Jan 24, 2010. 1:33 PM
 Hi,
Mine doesn't fire at all, but sometmes fires fire out the back with the cap on from the side. ANy suggestions?
creator 1 (author) says: Jan 24, 2010. 8:35 PM
Hey,
     This could be a number of different things.  Check to make sure it's sparking inside.  Also, your potato could be too big.  If you use liquid fuel, you may be using too much, so just put a tiny bit.  Try cleaning it with alcohol.
well, with the jumble of sentences above, i hope you found your problem.  if not, just let me know, and i'll try to think of other reason's it wouldn't be working.
good luck,
 creator 1
homemovies64 says: Jan 27, 2010. 5:10 PM
 Thanks for the reply. Sometimes it will fire, and other times won't fire for a long time. I spray in for half a second hairspray, (very flammable kind LOL) and it barely works. It sparks inside, I found that out the hard way by shooting the potato into my face once, but it still sparks. What could cause it to be unresponsive. Does yours work on every fire?
Thanks,
Eric
creator 1 (author) says: Jan 29, 2010. 8:08 PM
uh oh.. got me stumped.  I really don't know what would cause that.  Mine fires every time.  the only time it doesn't spark is when the potato juice gets everything inside the gun wet, then it doesn't work very well.
I hope it all works out for you, and sorry that I couldn't help a bunch...
let me know if you get it figured out,
Derek  (:
creator 1 (author) says: Jan 24, 2010. 8:36 PM
oh, and let me know if it sparks or not  ;)
homemovies64 says: Jan 25, 2010. 4:26 PM
 oh yeah, it sparks, but the thing is that i spray some hairspray for bought half a second, and sometimes works, but sometimes doesn;t. But if you take off the back cap, it shoots out a flame. Weird, idk whats wrong.
creator 1 (author) says: Jan 25, 2010. 9:33 PM
well, i'm not too familiar with the liquid fuels, but you could try to blow in it for a second after you spray the hairspray in it.  then, after you put the cap on it, shake it... other than that, i'm not sure i can help.
hope it helps,
 creator1
ItzMeLogo says: May 11, 2009. 10:52 AM
I made one too, I've only dry fired it whithout potato in dark to see if it works, it does and I'm using axe deodarant spray worrks great
zack247 says: Dec 20, 2009. 5:25 PM
i use tag, i find its seems to be a little more flammable
creator 1 (author) says: May 14, 2009. 9:24 AM
It looks cool in the dark doesn't it?
AWNydam says: Oct 16, 2009. 9:23 PM
i made one of these a few months ago but i used i chapstickcontainer so my combustion chamber is tiny. shoulda thought about a gluestick.
i was thinking abput using one of those small gatorade bottle but the plastic is a little to thin and could melt
creator 1 (author) says: Oct 19, 2009. 7:37 AM
yah, the gatorad thing is not good!!!  you can just buy a cheap  glue stick because they work really well!   good luck
coolerthancool505 says: Jul 26, 2009. 4:00 PM
i made this and it didnt work at all. but the spark worked. do you have any tips that could help me? i used hair spray is that the problem?
creator 1 (author) says: Oct 19, 2009. 7:35 AM
you might have put too much haispray!  try putting a very small spray, then shake it up!!!   good luck
itsthatsguy says: Oct 11, 2009. 11:18 AM
In order for thsi to work you need a 50/50 air to fuel mixture in the compustion chamber, spraying hairspray is WAY to much, if you do this, just tilt the device on its side, wait a little then light it.
creator 1 (author) says: Jul 28, 2009. 11:25 AM
Personally, I don't like liquid fuels because it coats the little tacks with fuel, then it doesn't spark. If it does spark, maybe your spraying too much or too little fuel. Maybe the combustion chamber has a leak, and it wont build pressure. Maybe the little potato is too big. Or, this one makes a difference, is the hairspray flammable? well, I hope that helped creator 1
coolerthancool505 says: Jul 29, 2009. 9:33 AM
thanks
MadBricoleur says: Jun 21, 2009. 11:21 PM
oksay i made it! just a tip: it would be helpful if you got some silicon caulk and smeared it around the "adaptive tape fitting" and on the side that's in the chamber so it's waterproof and all. Oh, and a good fuel would be to put alcohol (i used 70% isopropryl rubbing alchol) in a spray bottle and spray a bit in there. my method: push the spray button halfway down (spray that much), then cap it and shake 7 times, then fire.
creator 1 (author) says: Jun 22, 2009. 7:05 AM
Well, the silicon might be a good idea, but the problem with liquid fuel, is that after a while, it gets burned to the sparking tacks. Then you have take it a park, and clean it. Other than that, I bet it works great!! Thanks for commenting
LILhazY says: May 23, 2009. 3:49 AM
SSSSSSSSSSOOOOOOOOOOOOOOO WANA TRY THIS LMAO
creator 1 (author) says: May 25, 2009. 12:07 PM
Well, I have one answer for you. DO IT! It looks really cool to shoot it against a window. It mashes. That really had nothing to do with your comment.
bylerfamily says: Apr 17, 2009. 4:01 AM
Cool.Made one myself and it shoots pretty far.
creator 1 (author) says: Apr 17, 2009. 7:22 AM
do you use propane or hairspray. that really was the only reason it shoots farther. i use prapane.
bylerfamily says: Apr 17, 2009. 8:09 AM
I use silicon engine lubricant.That stuff is explosive.
creator 1 (author) says: Apr 17, 2009. 8:21 AM
Ive never heard of that. where do you get it?
bylerfamily says: Apr 20, 2009. 4:13 PM
Oh,for some reason your instructable is not in the Epilog challenge.And I can't find a way to vote for you.
creator 1 (author) says: Apr 20, 2009. 5:35 PM
I don't think I made it. O well. I'll still vote for you. you can check out my other stuff. I entered some of my things in the earthjustice thing. You could vote for those. thanks creator 1
bylerfamily says: Apr 21, 2009. 3:46 AM
Okay,I will.
bylerfamily says: Apr 17, 2009. 9:56 AM
An auto supply place.It is very clean burning and leaves no trace.I wish I had some propane to try it with.
butterfly2 says: Apr 20, 2009. 6:19 PM
i don't believe in guns. peace around the world man!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
