3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket size Espresso Machine with integrated alcohol stove.
Step 6Build part 1
Build part 1
Since the pictures I took sometimes don’t show very clearly what’s going on and also because a blueprint is worth 6 pages of directions, I drew one with the espresso machine cut in halve, and all the part measurements and hole sizes.
1. Drill the 4 holes into the 1 to ½in reducer
2. Ugly solder the ½ in pipe into the 1 to ½in reducer
Ugly solder?
Design constraint 3 says that only simple, cheap tools could be used. I considered that a blowtorch would not fit the bill because not everyone has one, and I would probably burn myself using one. Also, if one of the younger members wanted to make one of these as a Christmas present, I would have to find another way to solder everything together in a safer way. The only other tool that came to mind that fit the bill was a soldering iron. But nothing is free in life. It’s slow and the end product is really ugly.
I had to file the solder to make them look a bit nicer, but it was the only way to stay on the good side of the constraints.
So, I decided to call this “technique” ugly solder.
Note: Use only lead-free solder.
9 comments
Nov 30, 2011. 3:52 PMcodongolev says:
I'd recommend a butane blowtorch. it'll probably give you better joints, and ones can be found for extremely cheap online (dealextreme has some for around two dollars, if you're willing to wait around a while for shipping). I know you said you wanted to stay away from torches, but I wasn't sure if you just mean the huge propane ones.
I paid a little more and got a bit bigger one for ten dollars. I'm kind of wishing I'd have gone with the two dollar one, though; the igniter broke pretty easy. (I still use it, I just have to light it with an empty lighter's flint.)
Nov 24, 2011. 11:28 AMtig1 says:
Hello
Bear with me here
first off butt ugly construction, given the tools you used and the lack of soldering
skills you did an amazing job, I’m impressed, I have been working with a vast variety of metals for the last 30 years I can see the passion you put into this project, If you like working with projects as much as your article shows, I would suggest taking a welding course, T.I G. in particular it's a very precise type of welding that would bode well with your talent ,this project would be intense with Titanium,you could anodize it a multitude of colors, or even stainless steel, seriously dude check out.
Tungsten Inert Gas welding.
A fan
Nov 24, 2011. 12:18 PMIlan Voyager says:
TIG would be very nice, but it's rather expensive (I know as I TIG weld every day...) as the material and argon are far from cheap. Titanium is a pain to weld if you have not gas lenses and pulse. TIG needs also a lot of training...
A simpler but not so cheap alternative is a stainless steel 304 brazed with a alimentary silver alloy. A jewelry oxy-mapp torch is far more affordable than a TIG welder. You can find all the fittings in SS similar as copper.
It's a small DIY project so Copper with a lead free soldering alloy is enough. Just a lighter hand for soldering and more "elbow oil" for polishing.
Nov 27, 2011. 4:27 PMjtimmaj says:
You may want to try re-flowing the solder over a kitchen burner. Apply some extra flux over the ugly solder, reheat, cool, and clean.
Nov 26, 2011. 6:29 AMbob.the.devil says:
I like the solder it makes it look kinda steam punk.
Nov 25, 2011. 3:33 PMgotparsley says:
Any chance you could elaborate a little on the four holes drilled into the 1" to 1/2" reducer? Perhaps take a picture or something? I'm just a little confused. Thanks!
Nov 25, 2011. 6:52 AMLectric Wizard says:
Calling a doctor, now that's going the extra mile ! Nice to see a concerned poster. Cheers !
Nov 23, 2011. 10:41 AMLectric Wizard says:
You might want to mention the lead free thing in the body of the 'structable, it's really important when "food" is involved. Many people don't read the comments. Other that that, great job !!
Nov 22, 2011. 12:43 PMDNAgent says:
I'm curious as to what kind of solder you used. Is it an alloy that doesn't contain any lead?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:urant
A tinker since the cradle, I love looking at things and trying to figure out how they work and the best way to mod them
