Pocket sized Iron Man Arc Reactor
 by Alex Jalland
Featured
If I win the Hurricane Laser Competition this project could be repeated and all of the internal design as well as the outer rings could be cut to the perfect and needed size. if you already have a laser cutter you should experiment with lots of different designs as most will be possible even if they are very detailed. Give it a go!!
After seeing all of the Marvel Films, Iron Man, The Avengers etc... i decided to attempt to make a small arc reactor which i could use for a costum party or something. so i began by taking measurement, drawing and modleing a few differnt materials. so here goes!
Materials:
-aluminuim tubes( differnt diameters)
-Thin Insulated copper wire
-electritioans wire(red, black and blue/purple)
-electritions tape
-clear 10mm plastic sheet
-steel bolts
-steel nuts
-black acrylic plastic
-black high density foam
-11 Blue SMLED's or EL Wire(0.5m)
-a Push switch
-batteries
-battery holder
-aroldyt glue
Tools you will need:
-screw driver
-spanner
-jigsaw
-scisors
-solder
-soldering iron
-wire cutters
-file
-sand paper
-drill with hole cutting drill bits
- pencil
- measuring tape
Step 1: Cutting to size
Depending on your size you may need to increase the diameter of the base or decrease it. For mine the diameter was 100mm across. using a compass half the diameter to get the radius and set your compass using a ruler. it should now be set at 50mm. place it on the wood and draw the circle in pencil. you can cut this out by free hand or using a circular drill bit. the circular drill bit cutts out a perfect circle so this is probably best. once it is cut sand all the edges and surfaces as this is the part touching you skin.
tesla man says: Jun 22, 2012. 3:52 PM
you do realize that you entered it into the pocket sized contest, not the hurricane laser contest, right?
Alex Jalland (author) in reply to tesla manJun 23, 2012. 1:25 AM
I did enter it in both, one just came through later.
Alex Jalland (author) in reply to tesla manJun 23, 2012. 1:24 AM
My mistake I though I had entered it in both.
xinistrom in reply to Alex JallandJun 25, 2012. 12:49 PM
i'm interested in how you could comment your last comment earlier than your early comment ( look at time mark)
tesla man in reply to xinistromJun 25, 2012. 3:37 PM
i know, i thought the same thing the other day when i looked at your comment
tesla man in reply to xinistromJun 25, 2012. 3:35 PM
The instructables timer thing is messed up.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
