3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket sized Water color kit made from plastic first aid kit with a brush that deassembles
I had so much fun making the Mixed Media art kit that I thought I'd give it a try with water colors. I've seen some pretty cool one's on here and thought I'd give it my own little spin. I also tried to use the "sawed off paintbrush" and realized that the lack of handle really messed me up. So I thought of an idea to reassemble to store and reassemble when I needed. This is a rough idea but it does work, and if you have any better ideas or modifications let me know. Since this is kind of a work in progress I'd love to see what you think. I tried a new "fix" on an attached easel as well.
Step 1Gathering Materials
Gathering Materials
For the water color kit. You are going to need a set of water colors that will fit into the box/receptacle that you chose. I had a set of Prang water colors the semi moist kind that come in the cute little box. Imagine my delight when I realized you can totally take them out. So I just removed the blue, red, yellow, black and brown. It also had green, orange and purple/violet. Next I needed a water holder, that wouldn't leak all over my paints. I found a tiny "paint" cup that came with a huge paint pallet where you could store the paint. I bought the lil cups and the pallet from the Dick Blick catalouge a long time ago. I'm sure you can still purchase them. If not there are other cool items you could use just look around. Last time I used holes and twist ties to hold my drawing utensils this time I wanted to try something else. It was suggested to me to try elastic, but alas I lost the piece I had planned to try with. I came up with little "pockets" made from felt and hot glue. For the easel I just cut a groove out of a section of wooden chop stick, I sure do have enough of those laying randomly around. I also found a little red pouch from Walgreens that used to have first aid stuff in it but makes an awesome water proof "portfolio" perfect for the small size of the water color/ thick drawing paper for this kit.
Materials I used ( You can use whatever is most useful to you)
- plastic first aid kit (pocket sized)
- section of wooden chop stick
- old paint brush
- a tiny clasp for necklace looks like a barrel with two small loops one on either end
- hot glue gun and sticks
- felt (lets the door open for bad pick up lines)
- water colors (in whatever colors you like. I chose primary colors , black , and brown, My kit wouldn't fit all of them.
- tooth picks ( I like to use weird things as paint brushes)
- Eye make up applicators (again I like to use weird things as paint brushes. For cool texture tie some pine needles together and run them through water, water colors and onto paper)
- water color/ thick drawing paper
- fine grade sand paper
- a knife to cut the groove for easel
2 comments
Jul 5, 2009. 7:13 PMgoatgirly says:
What is the little white thing in the middle of the box? Nice ideas on how to get different textures and the jewelry clasp thing is a way better Idea than I would have come up with. I've got to make this.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:TeachNdahood
