loading
Step 5: Glue It Together and Cut the Shape Out
Glue the back on - (not sure why mine decided to crack) cut out the shape, plane, and sand and smooth off thoroughly. I went all medieval on mine with a belt sander.
There is only. 7
<p>You can have as many frets as you like in theory. Physics says an infinite number but in practice it is usually much smaller. When playing I rarely use more than 5, and only then, when I am showing off. The more frets you have the more notes you can play. 12 frets would give you an octave on each string and this is pretty standard for ukuleles. Banjos can go up to about 26. </p>
thanks,this was helpful
Shouldn't there be 12 frets
<p>good</p>
How thick is the neck?<br>
The neck is as thick as the scrap of wood i started with. <br>Measured dimensions are <br> 40 mm wide <br> 15 mm thick <br> <br>The neck thickness is not really that important as the tension of nylon strings is not that great. On the fancier ukes I have made the thickness usually tapers from about 20 mm at the body down to 15 mm at the nut.
What are the strings?
20 lb fishing line on this, but feel free to experiment. The soprano in the video is currently strung with a combination of 40, 80, 60 and 40 lb line for GCEA tuning.
This is wonderfully rough-and-ready. Your instrument is very accessible . . . even I think I could make one! This 'ible demonstrates many of the characteristics that make this site so very useful: the end result is kinda ugly, but works fine, the materials can be found cheap or free, and the steps are broken down into simple tasks that are easy to describe. Finally, the step that describes how to test the sound with one string anticipates a common point of failure. I am really impressed! <br> <br>Oh, the pictures are great, and the video is really fun to watch.
Video or audio would be nice. A router might be a better way of excavating the back. It would definitely allow you to make a more precise depth.
dodgy video up <br>Will work on something better
I am also interested in how this sounds; not particularly loud and fairly dull is my guess.. but I am not expert :p
every time I try to download a PDF it takes me to the login. so I login hit download PDF and it takes me back to login. I don't mind going around in circles when I'm on a merry-go-round but this is ridicules. <br />robartcrafts
how does it sound? maybe upload a video?
About This Instructable
43,767views
165favorites
License:
More by titchtheclown:Gang Saw Thin Rasp Using a vegetable peeler as a spokeshave Love crackers
Add instructable to:
