Pogo Stick From 2x4s
8,668
163
42
Posted
Introduction: Pogo Stick From 2x4s
2x4 Contest
Runner Up in the
2x4 Contest
With two 2x4s, two rubber bands, and two hours, you can make a working, adult-size pogo stick.
A couple years ago I made a pretty hard-core metal pogo stick for school (see this instructable), but that project required welding, machining, and about $100 worth of materials.
My goal for this project was to make things as simple (and cheap) as possible: all the materials cost about $30 and everything took me less than 2 hours to build (while taking pictures, not counting a few iterations of re-design).
If you're looking for the perfect DIY Christmas gift for your sad, dejected friend who weeps every time they see the weight limit on a Walmart pogo stick, then look no further.
Step 1: Gather Your Materials
Tools
  • Saw
  • Drill
Materials
  • Two 8-ft 2x4s
  • Several 2-1/2 inch wood-screws
  • Four 3-1/2 inch lag screws
  • Two heavy-duty rubber bands ($10 each at McMaster Carr, or $15 each at Amazon)
    • Alternatively, you could try surgical tubing, bicycle inner tubes, etc.
Step 2: Bottom
Use eight screws to assemble the bottom crosspiece.
Step 3: Middle
Use another eight screws to make the middle.
Step 4: Attach Brace
Use four toe-nailed screws and a 9-inch brace to attach the bottom and middle pieces together.
Step 5: Attach Post
Use six screws to attach the post.
Step 6: Check Plunger Fit
Cut the plunger and make sure it slides freely through the holes in the bottom and middle pieces.
Step 7: Attach Plunger Top
Use two lag screws to attach the plunger top (this piece needs a little extra support).
Step 8: Attach Handle
Use another two lag screws to attach the handle.
Step 9: Optional: Round the Plunger Top
Use a file, sandpaper, etc. to round the top of the plunger. This might prolong the life of your rubber bands.
Step 10: Attach the Rubber Bands
The main idea here is to
  1. Loop one end of a rubber band around the bottom crosspiece
  2. Stretch it over the top of the plunger
  3. Loop again
  4. Stretch again
  5. ...
How many passes you make depends on how heavy you are, how high you want to bounce, how long your rubber band is, and how good you are at stretching rubber bands.
I had pretty good luck with tying two rubber bands together, then making six passes (I weigh 175 pounds).
Step 11: Jump on It
Hop on and have some fun!
PS: While it shouldn't really have to be said, bounce at your own risk. The design seems pretty sturdy to me, but I'm sure you could find a way to hurt yourself with it.
And, as always, use a helmet. People who don't use helmets are idiots. I can't believe those people :)
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
38 Comments
Hey, I love it! I made it with one of my students, but I have a problem, I do not have amazon in Egypt, would exercise bands like TRX and resistance bands work?
Awesome! Yes, I think they would; there's a variety of companies that sell resistance bands to help with pullups that are basically the same thing. I haven't used TRX bands but they look similar. You'll just have to experiment with how you wrap the bands to adjust the resistance.
Post a picture of what you made if you get a chance!
No problem
solobo, great job on the pogo stick. Your instructions and pictures will make it easy for anyone to build a pogo stick from 2x4. Good luck in the contest.
thanks!
way to use those 2X4's I will need to look into some heavy duty rubber bands or bungie cords, I am a bit heavier than you... but I want to play on a pogo stick again.
