Step 2: Remove the pocket
You will be using the kangaroo pocket as material for the ears. Remove the stitching on the top and sides with a seam ripper, then cut across the bottom. Ripping the bottom seam may also remove the band around the bottom of the sweatshirt depending on the construction, so don't do that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
