Pokemon Sapphire Battery Replacement
88,820
56
26
Posted in PlayNintendo
Introduction: Pokemon Sapphire Battery Replacement
The pokemon sapphire game for game boy advance has an internal battery. If this battery runs down, you lose certain features of the game and you will get messages on the screen complaining of a dead battery. The battery is not really meant to be a user replaceable item but if you have a soldering iron and a little soldering experience it isn't too bad. Do be aware though that you have to be a little careful as you can damage the game. If you have worked on circuit boards before it isn't bad but if not, you may wish to practice soldering and desoldering a little on something else first. Please note that one reader has commented "you can lose your save data". I do not have sufficient data to confirm or deny that so I'm putting it out there as a warning. I am not sure if the data is saved in flash memory or if it relies on the battery fully to preserve the save data.
You will need:
- tri-wing screwdriver for removing the cover
- CR1616 replacement battery with solder tabs (Batteries Plus carries the battery and will put the solder tabs on for you). Note, it appears that amazon also now carries CR1616 with the tabs on it already.
- soldering iron and a small amount of electrical use (NOT plumbing use) solder
- desoldering wick
- tweezers, needle nose pliers, or a toothpick
- old scissors (you will trim some thin metal so leave your sewing scissors in your sewing table!)
Step 1: Remove Cover
Before starting on this step you should find a good place to work.  Solder contains lead and as such a kitchen or dining room table really is not appropriate.  Also there is some concern over static electricity.  If you have an anti-static electronics workbench that is the best.  However most people don't have this in their house.  I don't and I work in electronics....  I just work on an old plywood top work bench in the basement but I don't pet my cat at the same time (or do other things which would generate a lot of static electricity).
To remove the cover you will find you need a special screwdriver.  I used this screwdriver http://www.amazon.com/gp/product/B000S6AG9G from amazon.   If that link doesn't make it search for "Tri-wing Screwdriver for Nintendo Wii, Gamecube, Gameboy Advance".  I paid about $5 for it.
Cover removal is simple.  First take out the screw and then slide the back up relative to the front and they will easily lift apart.  You do not need to pry anything.  The second picture shows the back and front slid relative to each other.
Step 2: Desolder the Battery
To perform the next step, you should first lift the circuit board out of the plastic case to avoid melting it.  Then desolder the battery.  What I did was to take some metal tweezers that are dedicated to electronics use in my shop and apply  gentle upward pressure on the far right battery terminal while heating the solder joint with the soldering iron.  Once the solder melts that battery tab will lift right off.  The key is gentle lifting here because you don't want to pull the board apart by pulling hard before the solder melts.  If you don't have tweezers, you can use a toothpick to lift.
After the first corner is desoldered, heat the 2nd joint with the soldering iron and when the solder melts, just lift the battery off.  Again, I used tweezers.  Needlenose pliers are also appropriate tools and if you don't have either, you can use your toothpick again.
Note that the top of the battery is labeled as the "-" (minus) terminal and goes to the upper right pad on the board.
Step 3: Prepare the New Battery
The battery is a CR1616.  These are fairly common place.  The trick is that in this game cart the battery has 2 solder tabs which have been spot welded on.  You really don't want to try and solder directly to the battery (due to the heat and questionable ability to make a decent solder joint anyway).  Also you probably don't have a spot welder in your basement.  I know I don't.  Luckily I found that my local Batteries Plus store was able to add the solder strips for me.  If you don't have that store locally, I'd suggest looking at a hobby shop or other dedicated battery store.  You may be able to get this online from Batteries Plus.  I'm guessing you'd have to call them for it.
The solder tabs (strips of metal) that the battery shop spot welded on for me were fatter than the originals and not shaped the same.  It was fairly easy to trim them to size using some scissors for trimming and needle nose pliers for shaping.  Also you will want to add a small piece of electrical tape on the right hand edge of the battery to make sure that the top tab won't ever short to the edge of the battery.
Step 4: Prepare the Circuit Board
There are likely blobs (that is the technical term) of solder left on the pads where the old battery was.  These should be cleaned up.  The right way to do it is use some desoldering braid (also known as desoldering wick).  This is some thin wires woven together usually with a chemical in it and when you place it on the solder blob and heat with the tip of the soldering iron it will wick up the solder.  You can by the wick at any electronics store and probably also your local Radio Shack.  You don't need super clean, just wick up the bulk of it.  Also you don't want to keep the iron on the board for a long time or you can soften up the adhesive which holds the copper pad on the board.  An appropriate amount of time is just a few seconds (2 or so) after the solder begins to flow.
Step 5: Solder Down the New Battery
Being very careful to not let the battery leads touch other parts of the circuit board (they may not appreciate it), set the battery in place.  Carefully solder each of the two joints.  After soldering the first joint, wait a bit for it to cool before soldering the second.  The reason for the wait is so that you don't disturb the first during cooling which would compromise it somewhat.
After soldering down the battery, there will be some rosin (a.k.a. flux) left on the board near the solder joint.  That is the darker gunk in the picture.  This should be cleaned off.  Some solders use a water washable flux.  I used a Q-tip dipped in rubbing alcohol (90% isopropol alcohol) and scrubbed lightly.  Make sure you let it dry, however you clean it.
Put the board back in the case, put the lid back on, slide it into place, and put the screw back being careful to not strip the plastic threads.
All done!
In Pokemon Sapphire the way you can tell it worked is the "internal battery has run dry" message no longer appears when you start the game.
    • Slow Cooker Challenge
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    26 Comments
    You can get a CR1616 battery already prepared for pokemon games on Amazon.com
    You are correct. They seem to have those now and that is a better option for a source of a battery with tabs. Thanks!
    Lets try that again since it didn't reply yesterday. :) I have changed out thousands of these batteries and have never lost a save. You can actually watch a video I made on changing them out at https://www.youtube.com/watch?v=0i-19vVTtjI&t=753s. Not sure what you did to lose your saves.
    my previous comment should be interpreted as "you can lose your save data" so you better be willing to take the chance.
    I added your comment to the first section of the instructable as a caution. In the case of the one I changed I don't think there was any save data or else the owner of it (one of my kids) was more interested in getting the time based stuff to work than losing any save data.
    Actually, you can't lose the save data. The battery is not used for save game information. It is only used for time based events.
    refer to my other reply.
    you will lose your save data when you replace the battery. I know I did. And yes I am talking about a sapphire version. Just thought I'd let all you know in case you are like me and trusted this article. There is no mega memory card for gba games so you will have to find a pc to cartridge adapter to backup your save.
    This is absolutely incorrect for Gameboy Advance Pokemon games. The battery does not have anything to do with the save games.
    The battery is not the only variable is this repair. The heat, the cartridge motherboard solder connections and components, and the game's programming also plays a part. I did lose my save. This may be a result of programming because I tested the cartridge without a battery in to make sure I didn't do any damage when removing it. Or maybe the heat from the soldering gun affected nearby soldering points or destabilized the memory cells for save chip. Either way something did go wrong and I DID lose my save. I have since replaced three batteries on a used sapphire, ruby, and emerald version. The key was messing with only the solder and as little as possible. Also don't add solder either. The solder there is plenty. I can add images if you like.
    Hey, I changed the batteries in 3 games, everything seems correct but it still tells me that time based events wont trigger. Any suggestions of what might be wrong?
    I don't know about games other than the Pokemon series, but the Pokemon games have a timestamp that ticks up as you play the game and this is saved to your file when you save the game. When you replace the battery in the cartridge that timestamp returns to zero and because the timestamp doesn't match what is recorded on your save file, time based events don't happen. There are some ways to fix it: the quickest way is to start a new save file and overwrite your previous one. The new game's timestamp will start at zero and the problem will be fixed. If you don't want to start from scratch you can leave the game running until the timestamp catches up with what is recorded on your save file, but if you had been playing for a long time this can take a while. There are also methods to manual set the timestamp on the cartridge or on your game file, however these methods require extra hardware and I am not familiar with how to do it.
    I know it's been months since you replied to that other user (just noticed a dead battery on my dusty old Sapphire cartridge) but when you say you can "let the game run until the timestamp catches up" do you mean to start a new game and let it run, then shut it off without saving? Otherwise I can't see how to figure out how it would catch up to the save timestamp. Not wanting to buy the extra hardware to manually fix this timestamp problem, but also not wanting to lose the save data I have. Let me know if you can, thanks!
    The battery that is inside the cartridge.
    I think a lot of people are getting confused between GameBoy [Color] and GameBoy Advance games. In the GameBoy games there IS a save battery. So if you are playing say Pokemon Silver and that battery dies you wont be able to save your data again until you replace it. GameBoy Advance doesnt need a Save battery because it uses a different system. Instead, the battery for a GBA game is basically a digital clock battery. GameBoy Advance AND GameBoy Advance SP don't have their own internal clocks like newer consoles do. So anything that is specifically time related (eg. Growing berries, daytime/night time events) wont happen. You wont find a battery in all GBA games because not all games need to know what time it is. So there is nothing illegitimate between any of these variables.
    Probably you are not a real nintendo game player.. or you must have recently started playing on a nintendo
    Few real nintendo games actually do have a battery.
    What happens if you don't replace the battery?
