Difficulty: easy
In this instructable, I'll show you how to mod your boring flash drives into a fun, poker chip flash drive. Your co-workers will love it!
Step 1: Materials
You will need:
Flash drive
3-4 poker chips, color is up to you
super glue, epoxy, JB Weld, or other plastic bonding adhesive
band saw, jig saw, hack saw or other small hand held or electric saw
Dremel or some sort of plastic file
What I used:
I got my flash drive from Wal-mart. Its a 1Gb Lexar, 3 for $15
My poker chips were from a cheap set, unweighted plastic. If you have an expensive set, they are likely weighted with a metal disc in the middle and will not work. You can get cheap ones at dollar stores.
I used JB Weld, an all purpose two-part adhesive.
A small table mounted jig saw works best, and maybe a Dremel.
Paladin257 says: Mar 19, 2012. 8:01 AM
This has a Fallout: New Vegas vibe to it, and I like it :). If only it was a silverly colour...
brandegor says: Mar 6, 2012. 7:14 AM
Hot glue works very well & you don't have to worry about short circuits. Awesome idea - I'm making them for poker playing pals. Love it.
uzombee says: Jul 2, 2011. 4:01 AM
Truly nice! I have modded several usb drives, and never thought about a poker chip one. Thanks for the inspiration
CrLz says: Sep 25, 2010. 10:44 PM
Nice, has a cool Jame Bond-ish vibe. What the smooth player carries.
doughnutguy1 in reply to CrLzOct 7, 2010. 1:06 PM
It would be even more awesome if it was retractable and had a cap so it would just look like some poker chips.
Niemanator (author) in reply to CrLzSep 26, 2010. 11:57 AM
Yes, it is rather James Bond-esque. Maybe I will make a flash drive in a Walther PPK next?
chrizw123 in reply to NiemanatorDec 29, 2010. 5:07 PM
yeah, you should buy an all metal airsoft pistol the take out the internals and put the hardware from the drive in the mag slot.
totos in reply to chrizw123Mar 7, 2012. 8:34 AM
It would be even better to make some flash drive mags instead and maybe implant the actual connector into the pistol, so you can connect it to the computer and swap the drives with the mags.
totos in reply to totosMar 7, 2012. 8:37 AM
Implanting a memory card in each mag and a card reader into the pistol would be much cooler than that :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
