This instructable has been removed by the author.
13
comments
Add Comment
Can any one please be kind enough to tell me why the spell check is "stood- down" or is that a facility open to flying first class on this airline.
don't use parade gloss because it melts easy in hot weather once
youve got lots of coats on your boots. Always use a proper polishing cloth if
you can't get one use a 100% cotton shirt, and dip your cloth in water then
rub the cloth in the wax so it moistens the wax then apply small circles on the leather it should get shiny as a mirror
in about 30 minuites depending on the leather texture, then when it gets shiny to finish it off get aqua velva after shave and use the teq I described above using aqua velva instead of water and it gets a really clean polish..
then if you want to dub (waterproof) the boot use spray on kiwi
waterproofing stuff and it should keep the boot's shiny...
if you use wax type dubbing it will lose the shine on the boots...
and if your boot polish starts to crack put it on the stove top or ontop
off a wood stove and let it melt but dont leave it too long after it melts other wise it will set alight.
*hint* if you want to "cheat" a little bit, get a decent shine on your boot and add one VERY THIN layer of kiwi NEUTRAL(clear) polish- if you take too much you'll ruin your boots, but if done correctly, it makes for an awsome shine. happy polishing1
