Polygon Paper Egg and Spheres
5,314
23
5
Published
Introduction: Polygon Paper Egg and Spheres
About: Nowadays attempting creating small apps to dive into the world of programming and Software Development
Hello,
This is my first instructable. Today I'll show you how to model a geometric approximation of a 12 segment egg and 8/12 segment spheres.
Imagine you cut a round fruit (grapefruit, melon...etc) into quarter, eights, twelves and so on... Each piece has a seckle shape. It's the same method I used for this project. From a book for technical drafts(wo)men I've found out how to convert it into a geometric shape.
Geometry was my favourite subject in the school, it's one of many methods to express aesthetics of shapes and forms.
I'll try  to explain as easy as possible how to create this model.
For the spheres there are for each 2 possibilities how to craft. The first one is the segment method but I wonder how to glue the last segment. The glueing points are unreachable. The other one is to divide the segments into two halfs to ease glueing and increase stability. For this instructable I have chosen the 2nd method.
Let's get started
Step 1: Step1
What you need:
- PDF-Reader (e.g. Acrobat Reader)
- a homeprinter
- scissors, glue
- a bit patience, creativity and skill
Step 2: Download the Crease Pattern
Download the crease pattern and print it out.
As in the pdf described:
-the red lines are valley folds and the black ones cutting edges
-the flaps are glueing areas
Step 3: Cut, Fold and Glue
You need a little bit patience to cut these 'flowers'. It should look like these in the screenshots.
Then you fold the 'blossoms' through the folding lines and bring them to the center and glue them together.
Step 4: The Result
Then you should get two halfs of an ellipsoid and a sphere like shown in the pic.
Glue the two halfs an you get something that looks like an egg.
Happy crafting!
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    5 Comments
    If you want to make a globe and be able to choose the amount of rings and segments:
    http://www.templatemaker.nl/sphere
    Thought I'd throw this into the mix.
    Got the idea here:
    http://www.3dgeography.co.uk/#!make-a-globe/cdox
    When I was trying to make a paper ball for my cat.
    There are some that don't have flaps.
    That's because if you tape them along their edges, they naturally curve.
    No flaps necessary.
    So, I put together this (attached) template (PDF) based on the same
    idea. It takes four of them to make an 8x8 egg.
    That's two pages and LOTS of tape.
    Scale can be adjusted downward for smaller eggs using Inkscape.
    I used a Blender UV Sphere to create the egg, then whittled it down
    to one quarter (so for an 8x8 egg, one quarter is 4x4).
    Also attached is an egg in progress using this method.
    (Sorry about the double post - mouse problem)
    I used Pepakura to unfold the model because it allows me
    the flexibility of turning off the flaps and re-topologizing the
    shape by joining and unjoining shapes.
    It's basically a cone with a rounded peak (like a bullet) cut in
    half.
    Technically, it's a:
    Prolate Heptacontadihedron
    http://www.korthalsaltes.com/model.php?name_en=heb...
    It's just easier to call it a cone with a rounded tip, cut in
    half. Or, a quarter egg.
    Whatever.
    For what it's worth.
    yep, I'll try to post an instructable how to make the hyperbol cup
    Cool - are you going to post the egg-cup as well?
