Polymer Clay Covered Flatware
41,359
302
53
Posted in CraftClay
Introduction: Polymer Clay Covered Flatware
About: I love creating. I love ART in all its forms. I am a daughter of the 50s, born in 1992. I had the pleasure to be a Featured Author on this fabulous site, and you can read my interview here: https://www.ins...
Have you ever seen all that nice and colored flatware in a store and left thinking that you wanted it but couldn't buy it because you already had too much? Here is an example.
Leaving a store thinking that you couldn't buy something that you want is really disappointing.
Luckily I found out about this cool technique that you can use to cover your flatware and make it look the way you want!
All you need is polymer clay, I used Fimo.
This was the first time I ever used Fimo, but it was so fun that it won't be the last!
Of course you can use this technique to do anything you want, but I covered an old ruined knife along with a teaspoon with the clay that was left, and I am extremely satisfied with the result.
I hope you enjoy this instructable and have fun with clay! :)
Play With Clay Contest
Grand Prize in the
Step 1: What You Need
  • 3 different colors of polymer clay - I used white, blue and red Fimo
  • cutter
  • pasta machine
  • ruler
  • flatware
Step 2: Make 2 Rectangles
I am going to write this tutorial on the basis of the color I chose, but you can adjust it with the colors you like, of course.
Take one piece of white clay and one piece of red clay. They have to be about the same size.
Pass them through the pasta machine one at a time starting from the thicker size, and pass through the other different sizes until you reach the one that makes the clay about 1,5mm thick (0.05 inches).
Cut both of them to create 2 identical rectangles, as you can see in the pictures.
Step 3: The Bicolored Rectangle
Cut the rectangles in 2 from one angle to the other, right where the diagonal should be.
You now have 2 triangles of each color.
Lay one white triangle on the other and press it a little with your fingers so that they will stick together.
Do the same for the other color.
Now join the 2 different colors triangles together to create a new bicolored rectangle.
Step 4: Create a Shade
Pass the new rectangle through the pasta machine once then fold it in half and pass it through the pasta machine again.
Keep folding your rectangles after passing it through the pasta machine many times (maybe even 20) until the 2 colors mix together and create a shade that goes from white to dark red.
Step 5: Roll
Now roll your rectangle starting from the white side until you reach the end (red side).
Make 3 cuts that reach the white center on the whole length of your roll.
Look at the pictures to fully understand how the cuts are made. I started with the central one then made the other 2 ones. They look like an M, or a W upside down :D
Step 6: Cut the Blue Clay
Take a small piece of blue clay and pass it through the pasta machine like you did for the other colors.
Cut 3 identical strips as long as the white-red roll and as large as the cuts you made in the previous step.
Now insert these 3 strips in the 3 cuts.
It can be quite tricky, but you just need a little patience and you'll do it :)
Close your roll and press it with your fingers to give it the shape of a petal (or a drop).
Step 7: Make a Long Pyramid
Take another piece of blue clay and make 2 thin rolls as long as the white-red roll.
Press them with your fingers to give them a pyramid shape.
Place your big roll between these 2 blue pieces as you can see in the pictures.
The thinnest part of the petal/roll must be the top, the thicker/circular side will be at the bottom, where the 2 blue pieces are.
Now press everything with your fingers to make all pieces stick together and create a long and thick pyramid.
Keep pressing and gently pull it a little at a time to make it longer and longer (and thinner at the same time).
When your pyramid is about 1cm thick (0.39 inches), divide it in 6 equal pieces using a ruler.
Step 8: Create the Flower
Join 3 pieces together placing them side by side to create a semicircle.
Remember that the red angle of the pyramid must be at the center of the semicircle.
Do the same with the other 3 pieces left.
Now take a small piece of white clay and make a very thin snake out of it.
Make it about 1mm thick (0.03 inches) and as long as the semicircles.
This will be the center of your flower, so place it in the middle of one semicircle and add the other half of the circle on it to close the circle.
Your flower has formed!
Step 9: Make Many Tiny Flowers
Press your roll to keep the pieces together and gently pull it with your fingers to make it longer and thinner, just like you did in step 7.
This new roll has to become about 5mm thick (0.19 inches).
Cut out the 2 ends now and start to cut many thin slices from the roll. They have to be about 1mm thick (0.03 inches).
You'll notice that these slices of clay show a tiny flower inside...isn't that nice? :)
Rotate the roll as you cut them and be very gentle and careful because the clay is very soft and the roll may flatten. If it does, the flower will lose its circular shape.
Once you understand the proper way of cutting them, it will be much easier and faster.
Place all your flowers next to each other on a rectangle of blue clay.
Step 10: Flatten the Flowers
Once your rectangle is full of flowers, pass it through the pasta machine again.
Remember to always start from the thickest size. If you don't, your flowers will stretch too much.
You are finally done when the rectangle is bigger and thin again.
Step 11: Cover Your Knife
Let's cover your piece of flatware now!
Let's say that you cover a knife, like I did.
Place the grip of your knife on the back of the clay rectangle to figure out about how big the piece of clay you need for it must be.
So cut a piece out of the rectangle, big enough to cover the whole grip of your knife.
Now lay the piece of clay on your knife grip and adjust it with your fingers to be as smooth and adherent to the knife as possible.
Step 12: Bake!
The last thing you have to do is bake it!
You need to find a way to keep the part of the knife you covered with clay up, so that it doesn't touch any surface and the shape won't be ruined. I placed it between 2 bowls, one smaller than the other, as you can see in the picture.
You can do the same, or stick the knife on a potato or find another method :D
When you find the best way to keep the knife up, place it in the oven at 110/120°C - 230F for 15 minutes.
When the time is up, take everything out of the oven and let the knife cool.
You are done!! :)
You can leave it this way now or pass a layer of transparent varnish for Fimo on it to make it shinier.
PS: You can normally wash it in water, but remember that you can't put it in the dishwasher!
PS2: Please vote this instructable if you liked it, I'd really appreciate it :)
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    53 Comments
    Linda...I think I might have missed it. This is so awesome. Hats off to your creativity. And is that the pasta machine you won in italian food contest? :D, just a guess.
    Thank you Tarun!! :) This pasta machine is actually our old pasta machine, which is exactly like the one I won in the Italian Food contest! :D We've had it for so many years and I was surprised to see that the one I won was that same model! Now I'm using the new one for pasta and the old one for my crafts...if I didn't have the new one I doubt that I could make this clay project :)
    That is so cool. Trust me I could never have imagined the use of pasta machine for this project. I am amazed :)
    Oh yes, pasta machines can be very useful with clay! :) There are also specific machines for clay that are just like the ones for pasta, maybe just a little smaller...that is actually better because using the same one for pasta AND clay is not very hygienic :D So I must thank Instructables for sending me a new pasta machine...my mother wouldn't have let me use the old one for this project otherwise :D
    I totally agree :), having a separate pasta machine for craft is a bliss :)
    You are welcome, and thank you! :)
    This is fantastic! How did you manage with the join? Is it near invisible or did you hide it underneath the knife?
    Thank you so much! :)
    Do you mean the sides of clay that touch each other after you have covered the knife? First of all I tried to keep that closing part on one side of the knife so that it would have been less visible, then I smoothed that part with my finger to make sure that there wasn't a line anymore. I was surprised to see that I could hardly notice that part anymore!
    Thank you so much, it means a lot to me! :)
    Wow, thank you for the patch! I love it! :)
    Congratulations! You deserve it! I might try this out sometime :)
    Thank you so much! :) Congratulations to you as well, your creations are amazing!
    Thank you Emily, I am sooooooooooo excited!!! :D
    Great Ible... beautiful work, Lindarose!!!
