Introduction: Polymer Clay Eggs
This year for Easter I decided to try something a little different from the traditional dip dyed eggs I make each year.
In this instructable you'll learn how to create beautiful polymer clay Easter eggs. This is a fairly simple project and is something that can be done by both adults and children. This Instructable will detail the tools and materials you will need, the process of making the polymer clay cane that is used to create the pattern on the egg, the process of applying the clay to the egg, and tips on finishing so that your egg looks perfect and polished when you are finished. Along the way I've provided tips and tricks I learned while creating my polymer clay Easter eggs so that you can gain from my experience and hopefully avoid any issues I may have had.
Enjoy!
Step 1: Materials
- Polymer Clay - For this project I used Sculpy brand polymer clay but I would assume other brands like Fimo would work equally well. I used the 2 oz packs for this project which gave me plenty of clay to work with and left me with a lot of extra clay for future projects. you'll need 4 different colors, for my design I used yellow, orange, blue and white, but you could use whatever colors you like.
- Egg - Nothing special here, just a typical white egg from the grocery store.
- Cut Point Nail - This serves as the drill bit for creating the hollows in the top and bottom of the egg so that the edible part can be blown out. (you could also use a small twist drill bit for this process.)
- Pasta Machine - Used to roll the polymer clay into sheets. If you don't have a pasta machine you can use a rolling pin.
- Knife/Razor Blade - For cutting the polymer clay, you'll want to use a thin bladed knife such as a Xacto knife or paring knife.
- Polymer Clay Roller - this is used to form the polymer clay around the egg. The acrylic ones sold specifically for working with polymer clay are nice but you can use something like the barrel of a pen or marker with equal amounts of success.
- Sand Paper 220 - 600 Grit - Used to smooth and finish the surface of the polymer clay egg after it has been hardened in the oven.
Step 2: Preparing the Egg
Tip: Once the egg is blown out you can use something like a syringe to rinse it out. Simply fill the syringe with water, squirt it into the hollow egg while holding a finger over the hole in the bottom, and give it a few shakes to wash out the remaining bits of yolk and egg white.
Step 3: Making the Polymer Clay Cane Step 1: the Yellow Center
Step 4: Making the Polymer Clay Cane Step 2: the Orange Ring
Step 5: Making the Polymer Clay Cane Step 3: the Blue and White Part
Set the blue cylinders aside and use the pasta machine to role out a sheet of white clay. Use your knife to chop the white clay into 6 or 7 thin strips that are 2" long and about 1/4" wide, (you'll need one strip for each of your blue cylinders.)
Next, lay the white polymer clay strips into the cuts you made in the blue cylinders as shown in the pictures. Once the white polymer clay is in place, gently pinch the blue cylinder closed around the white clay strip so that they are fully enclosed inside the blue cylinders.
Lastly, position the blue cylinders around the yellow and orange core so that the sides with the white strips are closest to the core. With the blue cylinders in place, give the whole bundle a gentle squeeze to fix the various components in place.
Note: as you work through this step you may find that you don't have enough blue cylinders to make it the whole way around the core, if so you have two options:
- Make more blue cylinders.
- Role the core to decrease it's thickness so that the cylinders you do have fit the whole way around.
Step 6: Making the Polymer Clay Cane Step 4: the White Outside Ring
Once you have the white clay wrapped around the bundle, give everything a gentle squeeze starting from the middle of the cane and working towards the ends. the goal of this is to stick everything in place and to work out any air bubbles that might have been trapped while creating the cane.
Step 7: Rolling It Out
Tip: To help keep things as uniform as possible I sandwich the cane between the table and a sheet of acrylic as I roll it back and forth.
Step 8: Making the Medallions
Tip: turn the cane one quater turn after each cut to keep your medallions from having a flat bottom.
Try to cut the medallions so that they are all the same thickness, (roughly 1/8"). You'll need approximately 20 to 25 medallions to cover one egg and as you can see from the pictures there will be plenty of cane left over for future projects or to make additional eggs.
Step 9: Covering the Egg
Step 10: Smoothing
Check out the pictures for an example of this process.
Continue using the roller to close gaps until the entire egg is covered. do you best to keep the surface of the clay a uniform thickness as doing so will give you less to sand after hardening the clay.
Important Tip: As you roll the clay to cover the egg, make sure that you leave one of the holes used to blow out the egg uncovered. This will allow the egg to vent pressure while the clay is being baked to keep it from expanding and cracking.
Step 11: Baking
After baking, remove the clay from your oven and allow it to cool which should take about 20 minutes.
Step 12: Sanding
Optional: Once you've finished sanding with your finest grit you can use something like a rotary tool to polish your polymer clay egg and if you're looking for an even shinier finish you can apply special polymer class glazes that range from satin to gloss. These glazes can be purchased from most craft stores that sell polymer clay materials and supplies.
Step 13: Done
Best Regards!!
