3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Polystyrene throw airplane
Airplane from polystyrene fruit/meat plates. Cheap quick fun.
Step 1Cut the polystyrene
Cut the polystyrene
Cut the edges off the polystyrene plate so that you have a flat rectangular piece.
14 comments
Oct 27, 2008. 12:18 PMThelonelysandwitch says:
go and get those zip zap motors from radio shack and use those. There light and powerful.
Oct 21, 2008. 9:54 AMShadow Brujah says:
How about attach a electric engine in this plane? I have some little engines and i guess it can fly by itself using it. What do you think?
Sep 20, 2008. 11:20 PMtrlgal says:
is that polystyrene you used different from expanded polystyrene?
Sep 12, 2008. 10:27 PMyeerk21 says:
CLAY???!!!!!! y not a paper clip LOL
Sep 4, 2008. 4:47 PMrc jedi says:
you left out decalage, a slight incidence between the stab (rear wing) and the wing. You could just bend the trailing edge of the stab up. You also need dihedral. a bend at the center of the wing. Or basically, bending the tips up. see how the wings angle up on the model in my pic. It's fun to work out the trim on a glider. moving weight around, bending surfaces to effect roll, pitch or yaw. Look up the terms and see how to effect them.
Sep 5, 2008. 4:08 AMmicroman171 says:
Where did you get the knowledge to build that plane? I looks really good but I havent been able to figure out how to make 'em
Sep 8, 2008. 12:19 PMmicroman171 says:
I was meaning the Basla plane. Looks like a lot of fun! What do they normally cost in the US? (Inc servos, reciever, ESC)
Sep 8, 2008. 4:13 PMrc jedi says:
for this just a 3 channel radio. a single conversion reciever is all that's needed. A radio is an investment that lasts for years, hopefully.
This plane is balsa with plastic cling wrap covering. the tail is blue foam with tape hinges. can fly really slow. check out these sites.
http://www.bphobbies.com/view.asp?id=V815101
http://www.towerhobbies.com/index.html
https://www.hobbycity.com/hobbycity/store/uh_index.asp
http://www.wattflyer.com/forums/forumdisplay.php?s=7cbf05b30cf163b59d0476f42c6c8aa2&f=9
Sep 9, 2008. 2:32 AMmicroman171 says:
Thanks!
Sep 3, 2008. 6:49 AMrobgonzo says:
Nice.When I was a kid they used to print these on the lids of egg cartons.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:njacksx
