This project uses an Arduino, a pair of speakers, and a laser pointer to create a laser projector able to trace out designs in a dark room. To power it, I've cannibalized a PC ATX power supply capable...
This instructable is a guide for setting up an automated gardening system using an arduino and other cheap electronic parts. It allows sustainable gardening by using sensors to determine soil moistur...
***********************VIDEO: ****************************** Once upon a time, 2 girls greatly enjoyed walking in the rain with umbrellas. They decided the enjoyment of this experience could be maxi...
We wanted to build a model police car with working lights and sirens. Then we decided to add a motor and instead of using a switch to turn everything and off we used a photodiode. For our car the phot...
Summary: The following is a step by step guide on how to make a Heat-Seeking Desk Fan from an Arduino microcontroller, a computer fan, a servo, and an infrared temperature sensor. The device scans the...
This instructable will tell you how to make your own set of air drums using little more than an Arduino microcontroller and a few accelerometers. Here's a video of the drums I based this design off o...
Using an Arduino, it is easy to make a speedometer/tachometer for virtually any man-powered vehicle. I made one for my skateboard that used a small magnet to count revolutions and utilized an LCD di...
Summary This is an intense, synth-like distortion effect designed for the bass guitar. The project is not intended to be a complete guide to constructing a stand-alone pedal; rather, it is a guide to ...
Hello all! This is a quick guide on how to use an Arduino© to control whether a cooling fan and a heater is turned on depending on the detected temperature from a TC74 Arduino sensor. This is for a ...
Your four main parts for this project are an Arduino, a LoLshield, and an amplifier The LoLshield is a circuit board that comes with a library that enables one to individually control a matrix of LED...
Here we will be learning how to make a color sensor. my model consists of three cardboard compartments containing an LED - one red, one blue, and one green - and an OP550B phototransistor. The LED's s...
This is a guide on how to make a motion detector with an arduino! Enjoy!
This is a great gadget for a secret clubhouse and for people like me who always seem to loose their keys! This project is based on the original Secret Knock Lock instructable by Grathio (available bel...
This instructable will guide you through the process of making your very own star-cluster from LEDs and acrylic. I made this piece for my electronics final project at college and had access to a mach...
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
