Ponghatduino: Play pong using your hat
While its not exactly the OCZ NIA. The Pong-hat-duino is way to play pong using only the power of your mind. Well, your eyebrows anyway...
This is basically a modification of Tom Igoe's Monski Pong project from the excellent book Making Things Talk (O'Reilly). When I bought this book from the maker shed, it came with an arduino and a protoshield (both of which you can see at attached by velcro to the top of the ball hat as well as two force sensitive resistors. Unfortunately, the Monski pong in chapter two of MTT uses 2 flex sensor resistors to be embedded in the cuddly monkey (he is the Monski on the book's cover). So, I modified the circuit to use the FSRs instead, these are attached with velcro tape to the inside of the hat's band. The whole thing makes for a challenge as you play pong against yourself using your eyebrows.
Step 1Modify Monski Circuit
Make the basic Monski pong circuit from chapter two of Making Things Talk. See the Making Things Talk site for full details on this, or buy the book! Use Force Sensitive Resistors instead of Flex sensors. Check it works initially directly on the protoshield using the code that comes with the book or the processing code (the pde file) attached to this step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:RonanOD
http://www.blogger.com/profile/16071056478549745053
