Pool Noodle Man
2,658
21
4
Published
Introduction: Pool Noodle Man
An armature to dress, move and shape. Waterproof. Save and use over and over. Feel free to improve on this design. Everything is a work in progress.
Step 1: Lets Begin
You will need 6 Pool Noodles and 1 dust pan from your Dollar Store. Medium gauge wire, something that will bend and a brick.
Step 2: Measurements
Pool Noodle Measurements
1 NOODLE = 3 SPINES EACH 15 INCHES.
1 NOODLE = COLLAR BONE AND UPPER ARMS EACH 15 INCHES.
1 NOODLE = PELVIS AND UPPER LEGS EACH 15 INCHES.
1 NOODLE = CUT IN HALF = 2 BOTTOM LEGS.
1 NOODLE = 2 LOWER ARMS EACH 12 INCHES AND 1 NECK/HEAD 12 INCHES.
1 NOODLE = 2 HANDS AND 2 FEET ABOUT 5 INCHES EACH.
Step 3: Step 1
Step 1
Measure half way across the Pelvis section and poke a hole through the noodle.
Make an X with your knife on both sides and push through the PELVIS
Step 4: Step 2
Step 2
Side Spine over dustpan handle.
Step 5: Step 3
Step 3
Measure half way across Collar Bone section and cut Hole.
Slide Collar Bone over dustpan handle.
Step 6: Step 4
Step 4
Thread wire through upper and lower leg. Poke hole with wire through Pelvis. Repeat.
The two wires should be about 90 inches long.
Step 7: Step 5
Step 5
Pierce the Pelvis and bring wire from leg thru the wire thru the hole in noodle and attach the remaining spines to the Collar Bone.
Pierce noodle and pull thru.
Step 8: Step 6
Step 6
Add Upper Arms by running one long piece of wire through Noodle Holes.
Wire should be long enough on both sides to attach lower arms.
Step 9: Step 7
Step 7
Attach lower arms. Leave enough wire to ad hands and feet if you want.
Step 10: Step 8
Step 8
Slide Head/Neck over the Dustpan Handle and add Hands and Feet.
Ta Da!
Save and use over and over. But wait...there is more....
Note: if you bend the wire over at the end it is easier to slide through noodles.
Step 11: Add the Brick
Add the Brick for more stability.
Step 12: Extras
Take a plastic milk gallon jug...rinse clean and cut a hole to fit the noodle. Fit jug over head for a base.
Step 13: Witchy Woman
Here is my finished product. Masked, and dressed and ready for the party. Have fun and hope you can improve on this idea!
    • Casting Contest
      Casting Contest
    • Pets Challenge
      Pets Challenge
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Thank You...I am now obsessed with creative uses for this strange object. Nice to know someone else shares my view of the world!
    not a bad idea at all, I might just use this one for what I'm planning on doing. Now to find some pool noodles. hmmm
    Living in Florida they are pretty plentiful. If you have a dollar store near you they can order them and have them shipped to their store...of course the are a $1.00 each. http://www.dollartree.com/Wham-O-Round-Foam-Water-Noodles-49-/p308025/index.pro
    hope this helps.
