3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Poor Man's Radio Telescope
Poor Man\
A way to peer into the radiosky using little more then junk found on the side of the road.
Remembering back to my 10th birthday. I recall receiving a book on outer space. I believe it was published by National Geographic. This was by far my most prized book in my somewhat limited collection of the time.
In it there was a rough outline of a radio telescope. This diagram so intrigued me that for years in the back of my mind I dreamed of being able to play with one.
Indeed years have past, careers, children, and everyday life was by far the most important of responsibilities. Then it happened. I spotted a 10 foot satellite dish in someone's trash.. I quickly made off with it and all its components.
The mount was in pretty bad shape. It appears to have some serious wind damage, and the pedals of the dish are in less then what I would consider acceptable shape.
None the less I slapped it all together. In the picture you can see my stinky trashcan mount. It was good for a quick test but boy did it stink.
Step 1An examination of the feed assembly
Here we see the feed horn and low noise amplifier. All the dish components were hauled to the curb except the actual receiver unit. The bolts holding the wave guide and the amp onto the feed horn had to be purchased. Getting this feed horn back into working order took a little bit of time. It seems that the feed horn assembly was home to a community of wasps. I never realized this before but wasps build there nests to last. It took a good bit of probing and a little 409 to clean it up nice.
This is basically the meat of the system. It takes the focused energy of the dish and downconverts it into a usable signal and then amplifys it.
How is all this powered you might ask? The voltage actually travels down the coax cable that is delivering the signal to the next stage.
The polorizing servo is basically left alone, but for those of you that are curious it's a little motor that turns the antenna inside the feedhorn for better reception.
34 comments
Oct 26, 2011. 11:38 AMjiripolivka says:
I have made similar radio telescopes using satellite TV LNBs, at 4 GHz (C-band) and at 11 GHz (Ku-band). All work well.
I am confused to read that your C-band radio telescope was sensitive to cloud cover. It should not be, clouds and rain affect only Ku-band.
Using the Sat Finder is possible but as this device is designed to indicate satellite signals, solar noise response is quite non-linear with the knob setting. I prefer in my designs adding an inline IF amplifier ($4 at MCM Electronics), and I make a detector followed by an opamp, to adjust zero and gain for an analog indicator.
In addition to solar-noise demonstrations, such simple radio telescopes are interesting remote sensors. One can indicate his/her body temperature, emission of microwaves by walls, vegetation, clouds/rain and fluorescent tubes.
Oct 13, 2011. 10:18 PMrevelation says:
CAN A Dish be used to make a Death Star type weapon to blow up stuff ?
Oct 11, 2011. 8:42 PMilpug says:
I did a spit-take on my keyboard when I saw that you labeled the dog crap.
Just shows my maturity level tonight.
Anyway, great idea. I have no idea of the electronics involved, but if you ever get some coherent images, i would love to see them.
Dec 5, 2010. 6:48 PMwanna be macgyver says:
Hi zOrb,
Thankyou for uploading this project. My father-in-law installs dishes and decoders. He's going to love doing this project with me.
Thankyous to the people who have added comments for this project
Regards
Oct 19, 2009. 11:50 PMspecopps117 says:
is there a way to conect this to s screen to see the shapes of the radio transmitations of extra terrestrial phenomena?
Ouch
...to see the shapes of radio tranmission of other worldly objects....
Sep 10, 2009. 3:22 PMmuunkky says:
You can use this setup for more than seeing the sun. Just plug the raw feed into an oscilloscope and jack up the 21cm bandwidth and you've basically got yourself a high powered radio telescope. Not sure how the LNB is affecting your signal, might want to take that off to get raw analogue goodness.
Sep 10, 2009. 5:54 PMmuunkky says:
Haha, good point. An analogue UHF video receiver should do the trick though.
Sep 11, 2009. 9:33 AMmuunkky says:
It depends on the Low Noise Downconverter (LNB) on the dish. The raw feed from the 21 cm line (1420 MHz) will be downconverted to probably around 1400 kHz which could be picked up on an AM radio I believe, but you need to check the specs.
It may block everything below 4 GHz which means you'll never see the 21 cm bandwidth (*sob*). If this is the case and you really want that hydrogen line, you're better off removing the LNB and installing your own feedhorn, band-pass, and low noise amplifier and downconverter for the 21 cm.
You can get all these parts at http://www.radioastronomysupplies.com/radio_astronomy_supplies.php
Aug 10, 2009. 9:01 PMChwlo says:
z0rb can you take several dish network dishes and align them to make a more powerful and or longer range radio sat. If so can you point me in the right direction for this project. I can get plenty of them for nothing. I thought if I could space them out say over a hundred sq yards and align them I could pick up much more distant noise. Yes no hmmm.
Sep 7, 2007. 8:37 AMSolamenteDoug says:
My science project through most of high school involved a homemade radio telescope. It was a 2-meter helical antenna with a modified police scanner, amp and multimeter. It was sensitive enough to pick up the Sun and Jupiter as well. It was less a scientific instrument and more an experiment itself. I'd like to get back into scope making when I get a yard. Keep up the good work!
Jul 20, 2009. 11:00 AMthepelton says:
It would be interesting to map the sky, and find out where the "hottest" parts are. I suspect that the center of the galaxy would probably put out more radio waves that other places.
Jul 22, 2009. 9:27 AMthepelton says:
Jupiter I heard is also quite noisy.
Nov 25, 2008. 10:41 AMrod_sutter says:
I need a little help, im building a lbt can you give me more detail instruction on how to power the satellite finder with the 12 volt converter, and how can I hook up my laptop to the satellite finder to record the signals that come from the object were looking at.
Sep 18, 2008. 6:51 PMXellers says:
If I don't have a satellite dish, and all I want to do is "see the sun", then how would I be able to build an antenna? Would I be able to make one? Please help.
Sep 19, 2008. 12:41 PMXellers says:
I just found a small dish today; only a few feet in diameter.
All I want to do is to be able to point it at something like the sun, and to be able to detect that.
The dish had a coaxial cable connection.
I am looking at using this: http://www.satpro.tv/index.asp?PageAction=VIEWPROD&ProdID=192
to interpret the signal.
It would be easy for me to construct the power supply that you described, so all that I need to know is how I should connect everything. From the explanations within your instructable, I was unable to figure that out.
Please help.
TY :-)
Sep 23, 2008. 4:04 PMXellers says:
So basically, I should set it up like this:
Sep 23, 2008. 4:06 PMXellers says:
And by "outside of cable", I mean the channel that comes out as a ring on the coaxial cable.
Dec 22, 2007. 5:52 AMmaker12 says:
"I SAW THE SUN" the telscope is singing that LoL
Aug 5, 2007. 11:33 PMSHIFT! says:
Hey Hey Hey! It's Krusty The Klown!
Dec 22, 2007. 5:43 AMmaker12 says:
it is LOL
Sep 2, 2007. 3:24 AMgamma_fear says:
I was looking at this and a thought popped into my head (finally!). i have a couple of satellite dishes on my roof if i replaced the built in receiver with a usb WiFi device with a usb extension cord (bad WiFi reception from my house) and some really cool servos to change its direction, would the dish reflect WiFi signals or would i have to add some sort of mesh?
Aug 1, 2007. 3:10 PMMattTheGeek says:
would a dish network work for this project or do i need a bigger satellite dish?
Mar 14, 2007. 10:57 AMHamO says:
Great start... What are your plans for a receiver, what frequencies are you interested in? Keep us posted. Thanks for sharing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:z0rb
I like to tinker and I like to learn, and if one can support the other then thats great.
